Help with performance: ABYSALL slow upload and loading after upgrade to nc30. Docker container connected to local Apache reverse proxy
    • 30.0.5
    • Debian 12 bookworm
    • Apache/2.4.62 (Debian)
    • Apache
    • 8.2.27 inside the docker container (community docker image), 8.2.26 on the server
    • Yes
    • this morning, after a series of upgrade to bring the instance up to date the server is running super slow. Way slower than before.
    • Docker
    • not that I know of
:arrow_right: Summary of the issue I’m facing:
I upgraded from v27 to v30 with Docker, upgrading one version after the other. Now the server is super slow. Unusably slow.
My files are being sent super super super slower than before and the performance has plummeted. We are talking hours to send 60mo of data.
I’ve tried to setup Redis to see if it would solve it (I did not use it before that). As it seemed more recommended for the kind of setup I have, I ran it throug unixsocket. As I have website hosted on the same server it made sense (I think?). So I’m not running a docker container for that but just connecting Nextcloud container to it (config included further down).
I don’t have a warning in the Overview panel anymore but it does not seem to have solved it.
Files take several seconds to be send, :fire: CPU is spiking to 150% usage by one mariadb process (command /bin/bash /usr/local/bin/docker-entrypoint.sh mariadb) everytime I load the interface or try to sync with my local machine.
I have 3 types of debug repeated in the logs (included in the following) but I’m not sure I understand what they are saying. Help more than welcome.
More info on my setup:
  1. OS: Debian 12 bookworm
    Kernel: x86_64 Linux 6.1.0-29-amd64
    CPU: Intel Atom C2338 @ 2x 2.1GHz
    CRAM: 2501MiB / 3911MiB
  2. Debian / Apache server running virtual hosts and acting as reverse proxy (SSL with Let’s Encrypt). I have websites hosted on the same server, not using docker, and run Nextcloud alongside those.
  3. Nextcloud:30 running on docker container alongside its mariadb container
  4. Container is setup to use the reverse proxy running on the host machine.
  5. Tried to run Redis for the file locking, as recommended by Nextcloud
I know I have changed one thing in the reverse proxy after upgrade because it was mentionned by Nextcloud that the following was no longer accepted (full config shared further down):
'trusted_proxies' =>
     0 => '127.0.0.1',
      1 => 'cloud.example.com',
{"reqId":"hYNKzDKu8UpI1XPfN417","level":0,"time":"2025-01-29T23:10:37+00:00","remoteAddr":"172.22.0.1","user":"julien","app":"no app in context","method":"PUT","url":"/remote.php/dav/files/julien/{redacted}Email.php","message":"dirty table reads: SELECT `path` FROM `*PREFIX*filecache` WHERE (`storage` = :dcValue1) AND (`fileid` = :dcValue2)","userAgent":"Mozilla/5.0 (Linux) mirall/3.15.0daily (Nextcloud, manjaro-6.1.119-1-MANJARO ClientArchitecture: x86_64 OsArchitecture: x86_64)","version":"30.0.5.1","exception":{"Exception":"Exception","Message":"dirty table reads: SELECT `path` FROM `*PREFIX*filecache` WHERE (`storage` = :dcValue1) AND (`fileid` = :dcValue2)","Code":0,"Trace":[{"file":"/var/www/html/lib/private/DB/ConnectionAdapter.php","line":50,"function":"executeQuery","class":"OC\\DB\\Connection","type":"->","args":["SELECT `path` FROM `*PREFIX*filecache` WHERE (`storage` = :dcValue1) AND (`fileid` = :dcValue2)",{"dcValue1":2,"dcValue2":"*** sensitive parameters replaced ***"},{"dcValue1":1,"dcValue2":1}]},{"file":"/var/www/html/lib/private/DB/QueryBuilder/QueryBuilder.php","line":289,"function":"executeQuery","class":"OC\\DB\\ConnectionAdapter","type":"->","args":["SELECT `path` FROM `*PREFIX*filecache` WHERE (`storage` = :dcValue1) AND (`fileid` = :dcValue2)",{"dcValue1":2,"dcValue2":"*** sensitive parameters replaced ***"},{"dcValue1":1,"dcValue2":1}]},{"file":"/var/www/html/lib/private/DB/QueryBuilder/ExtendedQueryBuilder.php","line":285,"function":"executeQuery","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->","args":[{"__class__":"OC\\DB\\ConnectionAdapter"}]},{"file":"/var/www/html/lib/private/DB/QueryBuilder/ExtendedQueryBuilder.php","line":53,"function":"executeQuery","class":"OC\\DB\\QueryBuilder\\ExtendedQueryBuilder","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/lib/private/Files/Cache/Cache.php","line":1098,"function":"execute","class":"OC\\DB\\QueryBuilder\\ExtendedQueryBuilder","type":"->","args":[]},{"file":"/var/www/html/lib/private/Files/Cache/Cache.php","line":393,"function":"getPathById","class":"OC\\Files\\Cache\\Cache","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/lib/private/Files/Cache/Scanner.php","line":281,"function":"update","class":"OC\\Files\\Cache\\Cache","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/lib/private/Files/Cache/Scanner.php","line":217,"function":"addToCache","class":"OC\\Files\\Cache\\Scanner","type":"->","args":["*** sensitive parameters replaced ***","*** sensitive parameters replaced ***","*** sensitive parameters replaced ***"]},{"file":"/var/www/html/lib/private/Files/Cache/Scanner.php","line":329,"function":"scanFile","class":"OC\\Files\\Cache\\Scanner","type":"->","args":["*** sensitive parameters replaced ***",3,1284571,{"__class__":"OC\\Files\\Cache\\CacheEntry"},false]},{"file":"/var/www/html/lib/private/Files/Cache/Updater.php","line":110,"function":"scan","class":"OC\\Files\\Cache\\Scanner","type":"->","args":["*** sensitive parameters replaced ***",false,3,false]},{"file":"/var/www/html/apps/dav/lib/Connector/Sabre/File.php","line":330,"function":"update","class":"OC\\Files\\Cache\\Updater","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php","line":1137,"function":"put","class":"OCA\\DAV\\Connector\\Sabre\\File","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":492,"function":"updateFile","class":"Sabre\\DAV\\Server","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpPut","class":"Sabre\\DAV\\CorePlugin","type":"->","args":[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->","args":["method:PUT",[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]]},{"file":"/var/www/html/apps/dav/lib/Connector/Sabre/Server.php","line":43,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->","args":[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/html/apps/dav/lib/Server.php","line":371,"function":"start","class":"OCA\\DAV\\Connector\\Sabre\\Server","type":"->","args":[]},{"file":"/var/www/html/apps/dav/appinfo/v2/remote.php","line":19,"function":"exec","class":"OCA\\DAV\\Server","type":"->","args":[]},{"file":"/var/www/html/remote.php","line":146,"args":["/var/www/html/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/var/www/html/lib/private/DB/Connection.php","Line":402,"message":"dirty table reads: SELECT `path` FROM `*PREFIX*filecache` WHERE (`storage` = :dcValue1) AND (`fileid` = :dcValue2)","tables":["filecache"],"reads":["filecache"],"exception":[],"CustomMessage":"dirty table reads: SELECT `path` FROM `*PREFIX*filecache` WHERE (`storage` = :dcValue1) AND (`fileid` = :dcValue2)"},"id":"679ab578c47c3"}
{"reqId":"9rtujxoA3DC7p2SuQE7x","level":0,"time":"2025-01-29T23:12:07+00:00","remoteAddr":"172.22.0.1","user":"--","app":"webdav","method":"PROPFIND","url":"/remote.php/dav/principals/users/julien/","message":"No public access to this resource., No 'Authorization: Bearer' header found. Either the client didn't send one, or the server is mis-configured, No 'Authorization: Basic' header found. Either the client didn't send one, or the server is misconfigured","userAgent":"Mozilla/5.0 (X11; Linux x86_64) KIO/6.8 kioworker/6.8.0","version":"30.0.5.1","exception":{"Exception":"Sabre\\DAV\\Exception\\NotAuthenticated","Message":"No public access to this resource., No 'Authorization: Bearer' header found. Either the client didn't send one, or the server is mis-configured, No 'Authorization: Basic' header found. Either the client didn't send one, or the server is misconfigured","Code":0,"Trace":[{"file":"/var/www/html/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"beforeMethod","class":"Sabre\\DAV\\Auth\\Plugin","type":"->","args":[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php","line":456,"function":"emit","class":"Sabre\\DAV\\Server","type":"->","args":["beforeMethod:PROPFIND",[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]]},{"file":"/var/www/html/apps/dav/lib/Connector/Sabre/Server.php","line":43,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->","args":[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/html/apps/dav/lib/Server.php","line":371,"function":"start","class":"OCA\\DAV\\Connector\\Sabre\\Server","type":"->","args":[]},{"file":"/var/www/html/apps/dav/appinfo/v2/remote.php","line":19,"function":"exec","class":"OCA\\DAV\\Server","type":"->","args":[]},{"file":"/var/www/html/remote.php","line":146,"args":["/var/www/html/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Auth/Plugin.php","Line":152,"message":"No public access to this resource., No 'Authorization: Bearer' header found. Either the client didn't send one, or the server is mis-configured, No 'Authorization: Basic' header found. Either the client didn't send one, or the server is misconfigured","exception":[],"CustomMessage":"No public access to this resource., No 'Authorization: Bearer' header found. Either the client didn't send one, or the server is mis-configured, No 'Authorization: Basic' header found. Either the client didn't send one, or the server is misconfigured"},"id":"679ab5ca4e7a1"}
{"reqId":"WEh1hfRiiw7q8J6uHzAj","level":0,"time":"2025-01-29T23:12:07+00:00","remoteAddr":"172.22.0.1","user":"--","app":"no app in context","method":"PROPFIND","url":"/remote.php/dav/principals/users/julien/","message":"The loading of lazy AppConfig values have been requested","userAgent":"Mozilla/5.0 (X11; Linux x86_64) KIO/6.8 kioworker/6.8.0","version":"30.0.5.1","exception":{"Exception":"RuntimeException","Message":"ignorable exception","Code":0,"Trace":[{"file":"/var/www/html/lib/private/AppConfig.php","line":1180,"function":"loadConfig","class":"OC\\AppConfig","type":"->","args":[null]},{"file":"/var/www/html/lib/private/AppConfig.php","line":100,"function":"loadConfigAll","class":"OC\\AppConfig","type":"->","args":[]},{"file":"/var/www/html/lib/private/AllConfig.php","line":169,"function":"getKeys","class":"OC\\AppConfig","type":"->","args":["bruteForce"]},{"file":"/var/www/html/lib/private/Security/Bruteforce/Throttler.php","line":95,"function":"getAppKeys","class":"OC\\AllConfig","type":"->","args":["bruteForce"]},{"file":"/var/www/html/lib/private/Security/Bruteforce/Throttler.php","line":175,"function":"isBypassListed","class":"OC\\Security\\Bruteforce\\Throttler","type":"->","args":["172.22.0.1"]},{"file":"/var/www/html/lib/private/Security/Bruteforce/Throttler.php","line":192,"function":"getAttempts","class":"OC\\Security\\Bruteforce\\Throttler","type":"->","args":["172.22.0.1","login"]},{"file":"/var/www/html/lib/private/Security/Bruteforce/Throttler.php","line":265,"function":"getDelay","class":"OC\\Security\\Bruteforce\\Throttler","type":"->","args":["172.22.0.1","login"]},{"file":"/var/www/html/lib/private/User/Session.php","line":383,"function":"sleepDelayOrThrowOnMax","class":"OC\\Security\\Bruteforce\\Throttler","type":"->","args":["172.22.0.1","login"]},{"file":"/var/www/html/apps/dav/lib/Connector/Sabre/Auth.php","line":87,"function":"logClientIn","class":"OC\\User\\Session","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Auth/Backend/AbstractBasic.php","line":103,"function":"validateUserPass","class":"OCA\\DAV\\Connector\\Sabre\\Auth","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/apps/dav/lib/Connector/Sabre/Auth.php","line":198,"function":"check","class":"Sabre\\DAV\\Auth\\Backend\\AbstractBasic","type":"->","args":[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/html/apps/dav/lib/Connector/Sabre/Auth.php","line":112,"function":"auth","class":"OCA\\DAV\\Connector\\Sabre\\Auth","type":"->","args":[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Auth/Plugin.php","line":179,"function":"check","class":"OCA\\DAV\\Connector\\Sabre\\Auth","type":"->","args":[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Auth/Plugin.php","line":135,"function":"check","class":"Sabre\\DAV\\Auth\\Plugin","type":"->","args":[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/html/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"beforeMethod","class":"Sabre\\DAV\\Auth\\Plugin","type":"->","args":[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php","line":456,"function":"emit","class":"Sabre\\DAV\\Server","type":"->","args":["beforeMethod:PROPFIND",[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]]},{"file":"/var/www/html/apps/dav/lib/Connector/Sabre/Server.php","line":43,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->","args":[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/html/apps/dav/lib/Server.php","line":371,"function":"start","class":"OCA\\DAV\\Connector\\Sabre\\Server","type":"->","args":[]},{"file":"/var/www/html/apps/dav/appinfo/v2/remote.php","line":19,"function":"exec","class":"OCA\\DAV\\Server","type":"->","args":[]},{"file":"/var/www/html/remote.php","line":146,"args":["/var/www/html/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/var/www/html/lib/private/AppConfig.php","Line":1194,"message":"The loading of lazy AppConfig values have been requested","exception":[],"CustomMessage":"The loading of lazy AppConfig values have been requested"},"id":"679ab5ca4e703"}
Apache access logs (no errors):
xx.xx.xx.xx - - [30/Jan/2025:00:24:27 +0100] "GET /apps/serverinfo/update HTTP/2.0" 200 348 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:134.0) Gecko/20100101 Firefox/134.0"
xx.xx.xx.xx - - [30/Jan/2025:00:24:30 +0100] "GET /apps/serverinfo/update HTTP/2.0" 200 381 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:134.0) Gecko/20100101 Firefox/134.0"
xx.xx.xx.xx - - [30/Jan/2025:00:24:32 +0100] "GET /ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0" 304 95 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:134.0) Gecko/20100101 Firefox/134.0"
xx.xx.xx.xx - - [30/Jan/2025:00:24:33 +0100] "GET /apps/serverinfo/update HTTP/2.0" 200 348 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:134.0) Gecko/20100101 Firefox/134.0"
xx.xx.xx.xx - - [30/Jan/2025:00:24:33 +0100] "GET /apps/logreader/api/poll?lastReqId=GMgyKkZiOCK96LZIKn7v HTTP/2.0" 200 79 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:134.0) Gecko/20100101 Firefox/134.0"
xx.xx.xx.xx - - [30/Jan/2025:00:24:34 +0100] "GET /ocs/v2.php/apps/serverinfo/api/v1//basicdata?format=json HTTP/2.0" 200 243 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:134.0) Gecko/20100101 Firefox/134.0"
xx.xx.xx.xx - - [30/Jan/2025:00:24:36 +0100] "GET /apps/serverinfo/update HTTP/2.0" 200 348 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:134.0) Gecko/20100101 Firefox/134.0"
xx.xx.xx.xx - - [30/Jan/2025:00:24:38 +0100] "GET /apps/serverinfo/update HTTP/2.0" 200 350 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:134.0) Gecko/20100101 Firefox/134.0"
xx.xx.xx.xx - - [30/Jan/2025:00:24:16 +0100] "PROPFIND /remote.php/dav/principals/users/julien/ HTTP/2.0" 207 1412 "-" "Mozilla/5.0 (X11; Linux x86_64) KIO/6.8 kioworker/6.8.0"
xx.xx.xx.xx - - [30/Jan/2025:00:24:16 +0100] "PROPFIND /remote.php/dav/principals/users/julien/ HTTP/2.0" 207 1407 "-" "Mozilla/5.0 (X11; Linux x86_64) KIO/6.8 kioworker/6.8.0"
xx.xx.xx.xx - - [30/Jan/2025:00:24:38 +0100] "PROPFIND /remote.php/dav/calendars/julien/ HTTP/2.0" 401 1649 "-" "Mozilla/5.0 (X11; Linux x86_64) KIO/6.8 kioworker/6.8.0"
xx.xx.xx.xx - - [30/Jan/2025:00:24:38 +0100] "PROPFIND /remote.php/dav/addressbooks/users/julien/ HTTP/2.0" 401 1645 "-" "Mozilla/5.0 (X11; Linux x86_64) KIO/6.8 kioworker/6.8.0"
xx.xx.xx.xx - - [30/Jan/2025:00:24:40 +0100] "GET /apps/serverinfo/update HTTP/2.0" 200 350 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:134.0) Gecko/20100101 Firefox/134.0"
xx.xx.xx.xx - - [30/Jan/2025:00:24:43 +0100] "GET /apps/serverinfo/update HTTP/2.0" 200 344 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:134.0) Gecko/20100101 Firefox/134.0"
xx.xx.xx.xx - - [30/Jan/2025:00:24:44 +0100] "GET /ocs/v2.php/apps/serverinfo/api/v1//basicdata?format=json HTTP/2.0" 200 422 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:134.0) Gecko/20100101 Firefox/134.0"
xx.xx.xx.xx - - [30/Jan/2025:00:24:44 +0100] "GET /apps/logreader/api/poll?lastReqId=GMgyKkZiOCK96LZIKn7v HTTP/2.0" 200 1478 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:134.0) Gecko/20100101 Firefox/134.0"
xx.xx.xx.xx - - [30/Jan/2025:00:24:45 +0100] "GET /apps/serverinfo/update HTTP/2.0" 200 343 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:134.0) Gecko/20100101 Firefox/134.0"
xx.xx.xx.xx - - [30/Jan/2025:00:24:47 +0100] "GET /apps/serverinfo/update HTTP/2.0" 200 348 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:134.0) Gecko/20100101 Firefox/134.0"
xx.xx.xx.xx - - [30/Jan/2025:00:24:51 +0100] "GET /apps/serverinfo/update HTTP/2.0" 200 348 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:134.0) Gecko/20100101 Firefox/134.0"
xx.xx.xx.xx - - [30/Jan/2025:00:24:53 +0100] "GET /apps/serverinfo/update HTTP/2.0" 200 465 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:134.0) Gecko/20100101 Firefox/134.0"
xx.xx.xx.xx - - [30/Jan/2025:00:24:55 +0100] "GET /ocs/v2.php/apps/serverinfo/api/v1//basicdata?format=json HTTP/2.0" 200 246 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:134.0) Gecko/20100101 Firefox/134.0"
xx.xx.xx.xx - - [30/Jan/2025:00:24:55 +0100] "GET /apps/serverinfo/update HTTP/2.0" 200 324 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:134.0) Gecko/20100101 Firefox/134.0"
xx.xx.xx.xx - - [30/Jan/2025:00:24:56 +0100] "GET /apps/logreader/api/poll?lastReqId=5zW6mqG8NYyDPb52V9Gb HTTP/2.0" 200 103 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:134.0) Gecko/20100101 Firefox/134.0"
xx.xx.xx.xx - - [30/Jan/2025:00:24:58 +0100] "GET /apps/serverinfo/update HTTP/2.0" 200 349 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:134.0) Gecko/20100101 Firefox/134.0"
xx.xx.xx.xx - - [30/Jan/2025:00:24:39 +0100] "PROPFIND /remote.php/dav/addressbooks/users/julien/ HTTP/2.0" 207 1453 "-" "Mozilla/5.0 (X11; Linux x86_64) KIO/6.8 kioworker/6.8.0"
xx.xx.xx.xx - - [30/Jan/2025:00:24:39 +0100] "PROPFIND /remote.php/dav/calendars/julien/ HTTP/2.0" 207 2065 "-" "Mozilla/5.0 (X11; Linux x86_64) KIO/6.8 kioworker/6.8.0"
xx.xx.xx.xx - - [30/Jan/2025:00:25:00 +0100] "GET /apps/serverinfo/update HTTP/2.0" 200 349 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:134.0) Gecko/20100101 Firefox/134.0"
xx.xx.xx.xx - - [30/Jan/2025:00:25:03 +0100] "GET /apps/serverinfo/update HTTP/2.0" 200 348 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:134.0) Gecko/20100101 Firefox/134.0"
xx.xx.xx.xx - - [30/Jan/2025:00:25:03 +0100] "GET /ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0" 304 95 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:134.0) Gecko/20100101 Firefox/134.0"
xx.xx.xx.xx - - [30/Jan/2025:00:25:05 +0100] "GET /ocs/v2.php/apps/serverinfo/api/v1//basicdata?format=json HTTP/2.0" 200 242 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:134.0) Gecko/20100101 Firefox/134.0"
xx.xx.xx.xx - - [30/Jan/2025:00:25:06 +0100] "GET /apps/serverinfo/update HTTP/2.0" 200 349 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:134.0) Gecko/20100101 Firefox/134.0"
xx.xx.xx.xx - - [30/Jan/2025:00:25:07 +0100] "GET /apps/logreader/api/poll?lastReqId=5zW6mqG8NYyDPb52V9Gb HTTP/2.0" 200 1235 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:134.0) Gecko/20100101 Firefox/134.0"
xx.xx.xx.xx - - [30/Jan/2025:00:25:09 +0100] "GET /apps/serverinfo/update HTTP/2.0" 200 348 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:134.0) Gecko/20100101 Firefox/134.0"
xx.xx.xx.xx - - [30/Jan/2025:00:25:12 +0100] "GET /apps/serverinfo/update HTTP/2.0" 200 373 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:134.0) Gecko/20100101 Firefox/134.0"
xx.xx.xx.xx - - [30/Jan/2025:00:21:44 +0100] "PUT /remote.php/dav/files/julien/{redacted}/LanguageRouter.php HTTP/1.1" 204 732 "-" "Mozilla/5.0 (Linux) mirall/3.15.0daily (Nextcloud, manjaro-6.1.119-1-MANJARO ClientArchitecture: x86_64 OsArchitecture: x86_64)"
xx.xx.xx.xx - - [30/Jan/2025:00:25:15 +0100] "GET /apps/serverinfo/update HTTP/2.0" 200 341 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:134.0) Gecko/20100101 Firefox/134.0"
xx.xx.xx.xx - - [30/Jan/2025:00:25:16 +0100] "GET /ocs/v2.php/apps/serverinfo/api/v1//basicdata?format=json HTTP/2.0" 200 242 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:134.0) Gecko/20100101 Firefox/134.0"
xx.xx.xx.xx - - [30/Jan/2025:00:25:17 +0100] "GET /apps/logreader/api/poll?lastReqId=OmfedQwlfFCwkLh6LOMy HTTP/2.0" 200 333 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:134.0) Gecko/20100101 Firefox/134.0"
xx.xx.xx.xx - - [30/Jan/2025:00:25:18 +0100] "GET /apps/serverinfo/update HTTP/2.0" 200 347 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:134.0) Gecko/20100101 Firefox/134.0"
xx.xx.xx.xx - - [30/Jan/2025:00:25:21 +0100] "GET /apps/serverinfo/update HTTP/2.0" 200 349 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:134.0) Gecko/20100101 Firefox/134.0"
xx.xx.xx.xx - - [30/Jan/2025:00:21:47 +0100] "PUT /remote.php/dav/files/julien/{redacted}/LanguageRoutes.php HTTP/1.1" 204 732 "-" "Mozilla/5.0 (Linux) mirall/3.15.0daily (Nextcloud, manjaro-6.1.119-1-MANJARO ClientArchitecture: x86_64 OsArchitecture: x86_64)"
xx.xx.xx.xx - - [30/Jan/2025:00:25:12 +0100] "PROPFIND /remote.php/dav/files/julien/ HTTP/1.1" 207 1112 "-" "Mozilla/5.0 (Linux) mirall/3.15.0daily (Nextcloud, manjaro-6.1.119-1-MANJARO ClientArchitecture: x86_64 OsArchitecture: x86_64)"
xx.xx.xx.xx - - [30/Jan/2025:00:25:22 +0100] "GET /ocs/v2.php/apps/notifications/api/v2/notifications?format=json HTTP/1.1" 200 1019 "-" "Mozilla/5.0 (Linux) mirall/3.15.0daily (Nextcloud, manjaro-6.1.119-1-MANJARO ClientArchitecture: x86_64 OsArchitecture: x86_64)"
xx.xx.xx.xx - - [30/Jan/2025:00:25:24 +0100] "GET /apps/serverinfo/update HTTP/2.0" 200 349 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:134.0) Gecko/20100101 Firefox/134.0"
xx.xx.xx.xx - - [30/Jan/2025:00:21:55 +0100] "PUT /remote.php/dav/files/julien/{redacted}/LanguageRules.php HTTP/1.1" 204 732 "-" "Mozilla/5.0 (Linux) mirall/3.15.0daily (Nextcloud, manjaro-6.1.119-1-MANJARO ClientArchitecture: x86_64 OsArchitecture: x86_64)"
xx.xx.xx.xx - - [30/Jan/2025:00:25:27 +0100] "GET /apps/serverinfo/update HTTP/2.0" 200 347 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:134.0) Gecko/20100101 Firefox/134.0"
xx.xx.xx.xx - - [30/Jan/2025:00:25:27 +0100] "GET /ocs/v2.php/apps/serverinfo/api/v1//basicdata?format=json HTTP/2.0" 200 220 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:134.0) Gecko/20100101 Firefox/134.0"
xx.xx.xx.xx - - [30/Jan/2025:00:25:29 +0100] "GET /apps/logreader/api/poll?lastReqId=7xfU3SmR2iKFF4ezBXUm HTTP/2.0" 200 1528 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:134.0) Gecko/20100101 Firefox/134.0"
xx.xx.xx.xx - - [30/Jan/2025:00:25:29 +0100] "GET /apps/serverinfo/update HTTP/2.0" 200 324 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:134.0) Gecko/20100101 Firefox/134.0"
  'apps_paths' =>
    0 =>
      'url' => '/apps',
      'writable' => false,
    1 =>
      'url' => '/custom_apps',
      'writable' => true,
  'upgrade.disable-web' => false,
  'instanceid' => 'xxxxx',
  'passwordsalt' => 'xxxxx',
  'secret' => 'xxxxx',
    0 => 'cloud.example.com',
  'overwrite.cli.url' => 'https://cloud.example.com',
  'forwarded_for_headers' =>
    0 => 'X-Forwarded-For',
    1 => 'HTTP_X_FORWARDED_FOR',
    0 => '127.0.0.1'
  'version' => '30.0.5.1',
  'dbname' => 'cloud_db',
  'dbhost' => 'cloud-db',
  'dbtableprefix' => '',
  'dbuser' => 'cloud_user',
  'dbpassword' => 'xxxxx',
  'updater.secret' => 'xxxx',
  'loglevel' => 0,
  'mail_from_address' => 'julien',
  'mail_smtpmode' => 'smtp',
  'mail_domain' => 'email.com',
  'mail_smtphost' => 'ssl0.ovh.net',
  'mail_smtpport' => '465',
  'mail_smtpsecure' => 'ssl',
  'mail_smtpauth' => 1,
  'mail_smtpname' => 'user@email.com',
  'mail_smtppassword' => 'xxxx',
  'theme' => '',
  'default_phone_region' => 'ISO 3166-2:FR',
  'memcache.distributed' => '\OC\Memcache\Redis',
  'memcache.locking' => '\OC\Memcache\Redis',
  'redis' => [
    'host'     => '/var/run/redis/redis-server.sock',
    'port'     => 0,
  'log_rotate_size' => 10000000,
  'app_install_overwrite' =>
    0 => 'maps',
Virtual Host
<IfModule mod_ssl.c>
<VirtualHost *:443>
       ServerAdmin xxxx
       ServerName cloud.example.com
       ProxyPreserveHost On
       SSLEngine On
#       SSLProxyEngine On
       SSLProxyVerify none
       SSLProxyCheckPeerCN off
       SSLProxyCheckPeerName off
       SSLProxyCheckPeerExpire off
       ProxyPass / http://127.0.0.1:8083/
       ProxyPassReverse / http://127.0.0.1:8083/
       ProxyPassReverseCookieDomain 127.0.0.1 cloud.example.com
       ErrorLog /srv/logs/error/cloud.example.com.log
       CustomLog /srv/logs/access/cloud.example.com.log combined
       RewriteEngine On
       RewriteRule ^/\.well-known/carddav https://%{SERVER_NAME}/remote.php/dav/ [R=301,L]
       RewriteRule ^/\.well-known/caldav https://%{SERVER_NAME}/remote.php/dav/ [R=301,L]
        <IfModule mod_headers.c>
        Header always set Strict-Transport-Security "max-age=15552000; includeSubDomains; preload"
        </IfModule>
        SSLCertificateFile /etc/letsencrypt/live/cloud.example.com/fullchain.pem
        SSLCertificateKeyFile /etc/letsencrypt/live/cloud.example.com/privkey.pem
</VirtualHost>
</IfModule>
<VirtualHost *:80>
    ServerAdmin xxxx
#    ProxyPreserveHost On
#    ProxyPass / http://127.0.0.1:8083/
#    ProxyPassReverse / http://127.0.0.1:8083/
#    ProxyPassReverseCookieDomain 127.0.0.1 cloud.example.com
    RewriteEngine on
    # Some rewrite rules in this file were disabled on your HTTPS site,
    # because they have the potential to create redirection loops.
    RewriteCond %{SERVER_NAME} =cloud.example.com
    RewriteRule ^ https://%{SERVER_NAME}%{REQUEST_URI} [END,NE,R=permanent]
    # Doublon?
   # Redirect permanent / https://cloud.example.com/
    RewriteRule ^/\.well-known/carddav http://%{SERVER_NAME}/remote.php/dav/ [R=301,L]
    RewriteRule ^/\.well-known/caldav http://%{SERVER_NAME}/remote.php/dav/ [R=301,L]
</VirtualHost>
</IfModule>
Docker-compose.yml
services:
   cloud-db:
     container_name: ${DB_CONTAINER_NAME}
     image: mariadb:latest
     restart: unless-stopped
     volumes:
        - ${LOCAL_DB_DIR}:/var/lib/mysql
     environment:
       MYSQL_DATABASE: ${MYSQL_DATABASE}
       MYSQL_ROOT_PASSWORD: ${MYSQL_ROOT_PASSWORD}
       MYSQL_USER: ${MYSQL_USER}
       MYSQL_PASSWORD: ${MYSQL_PASSWORD}
   cloud-app:
     depends_on:
       - cloud-db
     container_name: ${APP_CONTAINER_NAME}
     image: nextcloud:30
     ports:
       - "8083:80"
     volumes:
       - ${LOCAL_DATA_DIR}:/var/www/html
       - ${LOCAL_CONF_DIR}:/var/www/html/config
       - ${LOCAL_APPS_DIR}:/var/www/html/apps
       - ./config/vhost.conf:/etc/apache2/sites-enabled/vhost-ssl.conf
       - /etc/letsencrypt:/etc/letsencrypt:ro
       - /var/run/redis/redis-server.sock:/var/run/redis/redis-server.sock
     environment:
       NEXTCLOUD_ADMIN_USER: ${NEXTCLOUD_ADMIN_USER}
       NEXTCLOUD_ADMIN_PASSWORD: ${NEXTCLOUD_ADMIN_PASSWORD}
       NEXTCLOUD_DATA_DIR: ${NEXTCLOUD_DATA_DIR}
       NEXTCLOUD_TABLE_PREFIX: ${NEXTCLOUD_TABLE_PREFIX}
       VIRTUAL_HOST: ${VIRTUAL_HOST}
       MYSQL_HOST: ${MYSQL_HOST}
  - admin_audit: 1.20.0
  - calendar: 5.0.9
  - contacts: 6.1.3
  - contactsinteraction: 1.11.0
  - dashboard: 7.10.0
  - dav: 1.31.1
  - files: 2.2.0
  - files_downloadlimit: 3.0.0
  - files_pdfviewer: 3.0.0
  - files_reminders: 1.3.0
  - files_sharing: 1.22.0
  - files_trashbin: 1.20.1
  - gpoddersync: 3.11.0
  - logreader: 3.0.0
  - notifications: 3.0.0
  - oauth2: 1.18.1
  - provisioning_api: 1.20.0
  - related_resources: 1.5.0
  - serverinfo: 2.0.0
  - settings: 1.13.0
  - theming: 2.5.0
  - updatenotification: 1.20.0
  - viewer: 3.0.0
  - weather_status: 1.10.0
  - welcome: 1.2.1
  - workflowengine: 2.12.0
  - activity: 3.0.0 (installed 2.11.0)
  - app_api: 4.0.5 (installed 4.0.5)
  - bruteforcesettings: 3.0.0 (installed 2.4.0)
  - circles: 30.0.0 (installed 27.0.0)
  - comments: 1.20.1 (installed 1.8.0)
  - encryption: 2.18.0
  - federation: 1.20.0 (installed 1.8.0)
  - files_external: 1.22.0
  - files_rightclick: 0.15.1 (installed 1.6.0)
  - files_versions: 1.23.0 (installed 1.11.0)
  - firstrunwizard: 3.0.0 (installed 2.7.0)
  - maps: 1.5.0 (installed 1.5.0)
  - news: 25.2.0 (installed 25.2.0)
  - nextcloud_announcements: 2.0.0 (installed 1.7.0)
  - nextpod: 0.7.6 (installed 0.7.6)
  - notes: 4.11.0 (installed 4.11.0)
  - password_policy: 2.0.0 (installed 1.8.0)
  - photos: 3.0.2 (installed 3.0.2)
  - privacy: 2.0.0 (installed 1.2.0)
  - recommendations: 3.0.0 (installed 0.6.0)
  - sharebymail: 1.20.0 (installed 1.8.0)
  - support: 2.0.0 (installed 1.1.0)
  - survey_client: 2.0.0 (installed 1.6.0)
  - suspicious_login: 8.0.0
  - systemtags: 1.20.0 (installed 1.8.0)
  - text: 4.1.0 (installed 4.1.0)
  - twofactor_totp: 12.0.0-dev
  - user_ldap: 1.21.0
  - user_status: 1.10.0 (installed 1.0.1)
  - webhook_listeners: 1.1.0-dev (installed 1.1.0-dev)
A couple things stand out to me:
  • you mentioned you have a reverse proxy, but you also appear to be terminating TLS on your app container too and have overridden the distributed Apache config. That’s… Unusual and I’m not clear what you’re getting out of that other than extra work and resource usage (i.e. more maintenance, higher likelihood of introducing problems during image upgrade, and additional CPU usage from the double HTTPS :wink:
  • adjust your loglevel so that it’s not at 0 (this is debug level and will slow things down). 2 is the default so i suggest that.
  • the config you posted is likely not your real one; use occ config:list system as described in the image docs here
  • you’re likely using an unsupported version of MariaDB given your image tag is set to latest. That can introduce problems (particularly if it’s a non-LTS release). That may even be the culprit given the details you described. Switching back is likely possible, but will require a manual db dump and restore (at a minimum) to be done safely.
To further diagnose your current situation:
  • Check your db container log
  • Check your app (NC) container log
Hi @jtr thanks for answering.
  • about the reverse proxy: I have to admit I fiddled over the years to make it work and the solution I have had been working since 2021 without hickups since I migrated from another server. I mentioned it and explained maybe a little better the reasoning in my only previous post here. If I could I would dedicate a single server only to Nextcloud but I can’t.
    I dont understand what you mean by “terminating TLS on your app container too and have overridden the distributed Apache config”. Can you clarify?
    If you see something obviously dumb/useless I’d be happy to be corrected. The gist of what I’m trying to do is having Nextcloud in that docker container and direct outside traffic through https to the Apache Reverse proxy that uses the Lets Encrypt SSL certificate. But between the .conf of the virtual host and the Nextcloud config there is probably things I did the wrong way.
  • I adjusted the log level. and after restarting I had a little issue with Redis that gave a good chunk of errors. Seems like the permissions had been restored when I restarted everything. Once I redid sudo chown -R redis:www-data /var/run/redis on the host and chown -R redis:www-data /var/run/redis inside the container it’s working again. I will look into making it persist but that’s not the real issue here.
  • here is the config from the occ command (did not know about it, it’s more practical indeed)
        "htaccess.RewriteBase": "\/",
        "apps_paths": [
                "url": "\/apps",
                "writable": false
                "url": "\/custom_apps",
                "writable": true
        "upgrade.disable-web": false,
        "overwrite.cli.url": "http:\/cloud.example.com",
        "overwriteprotocol": "https",
        "forwarded_for_headers": [
            "X-Forwarded-For",
            "HTTP_X_FORWARDED_FOR"
            "cloud.example.com"
        "dbtype": "mysql",
        "version": "30.0.5.1",
        "dbtableprefix": "",
        "dbport": "",
        "mysql.utf8mb4": true,
        "updater.secret": "***REMOVED SENSITIVE VALUE***",
        "loglevel": 2,
        "mail_smtpmode": "smtp",
        "mail_smtpport": "465",
        "mail_smtpsecure": "ssl",
        "mail_smtpauthtype": "LOGIN",
        "mail_smtpauth": 1,
        "theme": "",
        "default_phone_region": "ISO 3166-2:FR",
        "filelocking.enabled": true,
        "redis": {
            "port": 0
        "log_rotate_size": 10000000,
        "app_install_overwrite": [
            "maps"
        "data-fingerprint": "5b0aa8fd17e9acc9cf681077be6da67a"
  • I indeed had a warning in the admin overview panel about the mariaDB version. I fell back to the 11.4 version. No warning anymore.
So now here is the situation: I got a green checkmark :white_check_mark: in the /settings/admin/overview page in the admin.
The DB container log is not returning anything.
The NC container log is returning PROFIND and GET logs for hours… trying to sync / check changes in a folder of 50mo with 1000 subfolders and 1500 files.
The issue is not solved unfortunatly. Seing the green checkmark (and A+ on the security check) is great though.
But I don’t know what I can do to solve the issue of slowlyness. Is there a routine I could run to restore the DB, refresh something or purge some cache or something?
I’ve stumbled upon this issue where it is recommend to read a page I have already read about reverse proxies and I don’t see any new info I could use in there to help debug this :frowning:
After running 10 hours, the Nextcloud instance has output some error (log level 2)
here they are and in the next comment:
{"reqId":"BPzqS4dB4em8u209olw5","level":3,"time":"2025-01-30T05:31:45+00:00","remoteAddr":"172.22.0.1","user":"julien","app":"no app in context","method":"PUT","url":"/remote.php/dav/files/julien/InstantUpload/Camera/IMG_20250129_224719%20(2).jpg","message":"Taille du fichier attendue : 2296466 octets mais taille du fichier lue (depuis le client Nextcloud) et \u00e9crit (dans le stockage Nextcloud) : 24576 octets. Cela peut \u00eatre un probl\u00e8me de r\u00e9seau au niveau du client ou un probl\u00e8me de stockage au niveau du serveur.","userAgent":"Mozilla/5.0 (Android) Nextcloud-android/3.30.8","version":"30.0.5.1","exception":{"Exception":"Sabre\\DAV\\Exception\\BadRequest","Message":"Taille du fichier attendue : 2296466 octets mais taille du fichier lue (depuis le client Nextcloud) et \u00e9crit (dans le stockage Nextcloud) : 24576 octets. Cela peut \u00eatre un probl\u00e8me de r\u00e9seau au niveau du client ou un probl\u00e8me de stockage au niveau du serveur.","Code":0,"Trace":[{"file":"/var/www/html/apps/dav/lib/Connector/Sabre/Directory.php","line":110,"function":"put","class":"OCA\\DAV\\Connector\\Sabre\\File","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php","line":1098,"function":"createFile","class":"OCA\\DAV\\Connector\\Sabre\\Directory","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":504,"function":"createFile","class":"Sabre\\DAV\\Server","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpPut","class":"Sabre\\DAV\\CorePlugin","type":"->","args":[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->","args":["method:PUT",[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]]},{"file":"/var/www/html/apps/dav/lib/Connector/Sabre/Server.php","line":43,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->","args":[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/html/apps/dav/lib/Server.php","line":371,"function":"start","class":"OCA\\DAV\\Connector\\Sabre\\Server","type":"->","args":[]},{"file":"/var/www/html/apps/dav/appinfo/v2/remote.php","line":19,"function":"exec","class":"OCA\\DAV\\Server","type":"->","args":[]},{"file":"/var/www/html/remote.php","line":146,"args":["/var/www/html/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/var/www/html/apps/dav/lib/Connector/Sabre/File.php","Line":259,"message":"Taille du fichier attendue : 2296466 octets mais taille du fichier lue (depuis le client Nextcloud) et \u00e9crit (dans le stockage Nextcloud) : 24576 octets. Cela peut \u00eatre un probl\u00e8me de r\u00e9seau au niveau du client ou un probl\u00e8me de stockage au niveau du serveur.","exception":{},"CustomMessage":"Taille du fichier attendue : 2296466 octets mais taille du fichier lue (depuis le client Nextcloud) et \u00e9crit (dans le stockage Nextcloud) : 24576 octets. Cela peut \u00eatre un probl\u00e8me de r\u00e9seau au niveau du client ou un probl\u00e8me de stockage au niveau du serveur."}}
{"reqId":"CgMz7S1IdeqfPosTTre4","level":3,"time":"2025-01-30T05:33:56+00:00","remoteAddr":"","user":"--","app":"files","method":"","url":"--","message":"Error while trying to scan mount as /julien/:An exception occurred while executing a query: SQLSTATE[HY000]: General error: 1205 Lock wait timeout exceeded; try restarting transaction","userAgent":"--","version":"30.0.5.1","exception":{"Exception":"Doctrine\\DBAL\\Exception\\LockWaitTimeoutException","Message":"An exception occurred while executing a query: SQLSTATE[HY000]: General error: 1205 Lock wait timeout exceeded; try restarting transaction","Code":1205,"Trace":[{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Connection.php","line":1939,"function":"convert","class":"Doctrine\\DBAL\\Driver\\API\\MySQL\\ExceptionConverter","type":"->","args":[{"__class__":"Doctrine\\DBAL\\Driver\\PDO\\Exception"},{"__class__":"Doctrine\\DBAL\\Query"}]},{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Connection.php","line":1881,"function":"handleDriverException","class":"Doctrine\\DBAL\\Connection","type":"->","args":[{"__class__":"Doctrine\\DBAL\\Driver\\PDO\\Exception"},{"__class__":"Doctrine\\DBAL\\Query"}]},{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Connection.php","line":1213,"function":"convertExceptionDuringQuery","class":"Doctrine\\DBAL\\Connection","type":"->","args":[{"__class__":"Doctrine\\DBAL\\Driver\\PDO\\Exception"},"UPDATE `filecache` SET `mtime` = GREATEST(`mtime`, ?), `etag` = '679b0f082163f' WHERE (`storage` = ?) AND (`path_hash` = ?)",[1738215163,2,"fb66dca5f27af6f15c1d1d81e6f8d28b"],[1,1]]},{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Connections/PrimaryReadReplicaConnection.php","line":292,"function":"executeStatement","class":"Doctrine\\DBAL\\Connection","type":"->","args":["UPDATE `filecache` SET `mtime` = GREATEST(`mtime`, ?), `etag` = '679b0f082163f' WHERE (`storage` = ?) AND (`path_hash` = ?)",[1738215163,2,"fb66dca5f27af6f15c1d1d81e6f8d28b"],[1,1]]},{"file":"/var/www/html/lib/private/DB/Connection.php","line":462,"function":"executeStatement","class":"Doctrine\\DBAL\\Connections\\PrimaryReadReplicaConnection","type":"->","args":["UPDATE `filecache` SET `mtime` = GREATEST(`mtime`, :time), `etag` = '679b0f082163f' WHERE (`storage` = :dcValue1) AND (`path_hash` = :hash)",{"dcValue1":2,"time":1738215163,"hash":"fb66dca5f27af6f15c1d1d81e6f8d28b"},{"dcValue1":1,"time":1}]},{"file":"/var/www/html/lib/private/DB/ConnectionAdapter.php","line":67,"function":"executeStatement","class":"OC\\DB\\Connection","type":"->","args":["UPDATE `filecache` SET `mtime` = GREATEST(`mtime`, :time), `etag` = '679b0f082163f' WHERE (`storage` = :dcValue1) AND (`path_hash` = :hash)",{"dcValue1":2,"time":1738215163,"hash":"fb66dca5f27af6f15c1d1d81e6f8d28b"},{"dcValue1":1,"time":1}]},{"file":"/var/www/html/lib/private/DB/QueryBuilder/QueryBuilder.php","line":306,"function":"executeStatement","class":"OC\\DB\\ConnectionAdapter","type":"->","args":["UPDATE `*PREFIX*filecache` SET `mtime` = GREATEST(`mtime`, :time), `etag` = '679b0f082163f' WHERE (`storage` = :dcValue1) AND (`path_hash` = :hash)",{"dcValue1":2,"time":1738215163,"hash":"fb66dca5f27af6f15c1d1d81e6f8d28b"},{"dcValue1":1,"time":1}]},{"file":"/var/www/html/lib/private/DB/QueryBuilder/QueryBuilder.php","line":268,"function":"executeStatement","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->","args":[{"__class__":"OC\\DB\\ConnectionAdapter"}]},{"file":"/var/www/html/lib/private/Files/Cache/Propagator.php","line":210,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->","args":[]},{"file":"/var/www/html/lib/private/Files/Utils/Scanner.php","line":164,"function":"commitBatch","class":"OC\\Files\\Cache\\Propagator","type":"->","args":[]},{"file":"/var/www/html/apps/files/lib/Command/Scan.php","line":151,"function":"backgroundScan","class":"OC\\Files\\Utils\\Scanner","type":"->","args":["/julien"]},{"file":"/var/www/html/apps/files/lib/Command/Scan.php","line":214,"function":"scanFiles","class":"OCA\\Files\\Command\\Scan","type":"->","args":["julien","/julien",null,{"__class__":"Symfony\\Component\\Console\\Output\\ConsoleOutput"},true,true,false]},{"file":"/var/www/html/3rdparty/symfony/console/Command/Command.php","line":326,"function":"execute","class":"OCA\\Files\\Command\\Scan","type":"->","args":[{"__class__":"Symfony\\Component\\Console\\Input\\ArgvInput"},{"__class__":"Symfony\\Component\\Console\\Output\\ConsoleOutput"}]},{"file":"/var/www/html/core/Command/Base.php","line":161,"function":"run","class":"Symfony\\Component\\Console\\Command\\Command","type":"->","args":[{"__class__":"Symfony\\Component\\Console\\Input\\ArgvInput"},{"__class__":"Symfony\\Component\\Console\\Output\\ConsoleOutput"}]},{"file":"/var/www/html/3rdparty/symfony/console/Application.php","line":1078,"function":"run","class":"OC\\Core\\Command\\Base","type":"->","args":[{"__class__":"Symfony\\Component\\Console\\Input\\ArgvInput"},{"__class__":"Symfony\\Component\\Console\\Output\\ConsoleOutput"}]},{"file":"/var/www/html/3rdparty/symfony/console/Application.php","line":324,"function":"doRunCommand","class":"Symfony\\Component\\Console\\Application","type":"->","args":[{"__class__":"OCA\\Files\\Command\\Scan"},{"__class__":"Symfony\\Component\\Console\\Input\\ArgvInput"},{"__class__":"Symfony\\Component\\Console\\Output\\ConsoleOutput"}]},{"file":"/var/www/html/3rdparty/symfony/console/Application.php","line":175,"function":"doRun","class":"Symfony\\Component\\Console\\Application","type":"->","args":[{"__class__":"Symfony\\Component\\Console\\Input\\ArgvInput"},{"__class__":"Symfony\\Component\\Console\\Output\\ConsoleOutput"}]},{"file":"/var/www/html/lib/private/Console/Application.php","line":183,"function":"run","class":"Symfony\\Component\\Console\\Application","type":"->","args":[{"__class__":"Symfony\\Component\\Console\\Input\\ArgvInput"},{"__class__":"Symfony\\Component\\Console\\Output\\ConsoleOutput"}]},{"file":"/var/www/html/console.php","line":87,"function":"run","class":"OC\\Console\\Application","type":"->","args":[{"__class__":"Symfony\\Component\\Console\\Input\\ArgvInput"}]},{"file":"/var/www/html/occ","line":11,"args":["/var/www/html/console.php"],"function":"require_once"}],"File":"/var/www/html/3rdparty/doctrine/dbal/src/Driver/API/MySQL/ExceptionConverter.php","Line":42,"Previous":{"Exception":"Doctrine\\DBAL\\Driver\\PDO\\Exception","Message":"SQLSTATE[HY000]: General error: 1205 Lock wait timeout exceeded; try restarting transaction","Code":1205,"Trace":[{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Driver/PDO/Statement.php","line":132,"function":"new","class":"Doctrine\\DBAL\\Driver\\PDO\\Exception","type":"::","args":[{"__class__":"PDOException","errorInfo":["HY000",1205,"Lock wait timeout exceeded; try restarting transaction"]}]},{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Connection.php","line":1207,"function":"execute","class":"Doctrine\\DBAL\\Driver\\PDO\\Statement","type":"->","args":[]},{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Connections/PrimaryReadReplicaConnection.php","line":292,"function":"executeStatement","class":"Doctrine\\DBAL\\Connection","type":"->","args":["UPDATE `filecache` SET `mtime` = GREATEST(`mtime`, ?), `etag` = '679b0f082163f' WHERE (`storage` = ?) AND (`path_hash` = ?)",[1738215163,2,"fb66dca5f27af6f15c1d1d81e6f8d28b"],[1,1]]},{"file":"/var/www/html/lib/private/DB/Connection.php","line":462,"function":"executeStatement","class":"Doctrine\\DBAL\\Connections\\PrimaryReadReplicaConnection","type":"->","args":["UPDATE `filecache` SET `mtime` = GREATEST(`mtime`, :time), `etag` = '679b0f082163f' WHERE (`storage` = :dcValue1) AND (`path_hash` = :hash)",{"dcValue1":2,"time":1738215163,"hash":"fb66dca5f27af6f15c1d1d81e6f8d28b"},{"dcValue1":1,"time":1}]},{"file":"/var/www/html/lib/private/DB/ConnectionAdapter.php","line":67,"function":"executeStatement","class":"OC\\DB\\Connection","type":"->","args":["UPDATE `filecache` SET `mtime` = GREATEST(`mtime`, :time), `etag` = '679b0f082163f' WHERE (`storage` = :dcValue1) AND (`path_hash` = :hash)",{"dcValue1":2,"time":1738215163,"hash":"fb66dca5f27af6f15c1d1d81e6f8d28b"},{"dcValue1":1,"time":1}]},{"file":"/var/www/html/lib/private/DB/QueryBuilder/QueryBuilder.php","line":306,"function":"executeStatement","class":"OC\\DB\\ConnectionAdapter","type":"->","args":["UPDATE `*PREFIX*filecache` SET `mtime` = GREATEST(`mtime`, :time), `etag` = '679b0f082163f' WHERE (`storage` = :dcValue1) AND (`path_hash` = :hash)",{"dcValue1":2,"time":1738215163,"hash":"fb66dca5f27af6f15c1d1d81e6f8d28b"},{"dcValue1":1,"time":1}]},{"file":"/var/www/html/lib/private/DB/QueryBuilder/QueryBuilder.php","line":268,"function":"executeStatement","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->","args":[{"__class__":"OC\\DB\\ConnectionAdapter"}]},{"file":"/var/www/html/lib/private/Files/Cache/Propagator.php","line":210,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->","args":[]},{"file":"/var/www/html/lib/private/Files/Utils/Scanner.php","line":164,"function":"commitBatch","class":"OC\\Files\\Cache\\Propagator","type":"->","args":[]},{"file":"/var/www/html/apps/files/lib/Command/Scan.php","line":151,"function":"backgroundScan","class":"OC\\Files\\Utils\\Scanner","type":"->","args":["/julien"]},{"file":"/var/www/html/apps/files/lib/Command/Scan.php","line":214,"function":"scanFiles","class":"OCA\\Files\\Command\\Scan","type":"->","args":["julien","/julien",null,{"__class__":"Symfony\\Component\\Console\\Output\\ConsoleOutput"},true,true,false]},{"file":"/var/www/html/3rdparty/symfony/console/Command/Command.php","line":326,"function":"execute","class":"OCA\\Files\\Command\\Scan","type":"->","args":[{"__class__":"Symfony\\Component\\Console\\Input\\ArgvInput"},{"__class__":"Symfony\\Component\\Console\\Output\\ConsoleOutput"}]},{"file":"/var/www/html/core/Command/Base.php","line":161,"function":"run","class":"Symfony\\Component\\Console\\Command\\Command","type":"->","args":[{"__class__":"Symfony\\Component\\Console\\Input\\ArgvInput"},{"__class__":"Symfony\\Component\\Console\\Output\\ConsoleOutput"}]},{"file":"/var/www/html/3rdparty/symfony/console/Application.php","line":1078,"function":"run","class":"OC\\Core\\Command\\Base","type":"->","args":[{"__class__":"Symfony\\Component\\Console\\Input\\ArgvInput"},{"__class__":"Symfony\\Component\\Console\\Output\\ConsoleOutput"}]},{"file":"/var/www/html/3rdparty/symfony/console/Application.php","line":324,"function":"doRunCommand","class":"Symfony\\Component\\Console\\Application","type":"->","args":[{"__class__":"OCA\\Files\\Command\\Scan"},{"__class__":"Symfony\\Component\\Console\\Input\\ArgvInput"},{"__class__":"Symfony\\Component\\Console\\Output\\ConsoleOutput"}]},{"file":"/var/www/html/3rdparty/symfony/console/Application.php","line":175,"function":"doRun","class":"Symfony\\Component\\Console\\Application","type":"->","args":[{"__class__":"Symfony\\Component\\Console\\Input\\ArgvInput"},{"__class__":"Symfony\\Component\\Console\\Output\\ConsoleOutput"}]},{"file":"/var/www/html/lib/private/Console/Application.php","line":183,"function":"run","class":"Symfony\\Component\\Console\\Application","type":"->","args":[{"__class__":"Symfony\\Component\\Console\\Input\\ArgvInput"},{"__class__":"Symfony\\Component\\Console\\Output\\ConsoleOutput"}]},{"file":"/var/www/html/console.php","line":87,"function":"run","class":"OC\\Console\\Application","type":"->","args":[{"__class__":"Symfony\\Component\\Console\\Input\\ArgvInput"}]},{"file":"/var/www/html/occ","line":11,"args":["/var/www/html/console.php"],"function":"require_once"}],"File":"/var/www/html/3rdparty/doctrine/dbal/src/Driver/PDO/Exception.php","Line":28,"Previous":{"Exception":"PDOException","Message":"SQLSTATE[HY000]: General error: 1205 Lock wait timeout exceeded; try restarting transaction","Code":"HY000","Trace":[{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Driver/PDO/Statement.php","line":130,"function":"execute","class":"PDOStatement","type":"->","args":[null]},{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Connection.php","line":1207,"function":"execute","class":"Doctrine\\DBAL\\Driver\\PDO\\Statement","type":"->","args":[]},{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Connections/PrimaryReadReplicaConnection.php","line":292,"function":"executeStatement","class":"Doctrine\\DBAL\\Connection","type":"->","args":["UPDATE `filecache` SET `mtime` = GREATEST(`mtime`, ?), `etag` = '679b0f082163f' WHERE (`storage` = ?) AND (`path_hash` = ?)",[1738215163,2,"fb66dca5f27af6f15c1d1d81e6f8d28b"],[1,1]]},{"file":"/var/www/html/lib/private/DB/Connection.php","line":462,"function":"executeStatement","class":"Doctrine\\DBAL\\Connections\\PrimaryReadReplicaConnection","type":"->","args":["UPDATE `filecache` SET `mtime` = GREATEST(`mtime`, :time), `etag` = '679b0f082163f' WHERE (`storage` = :dcValue1) AND (`path_hash` = :hash)",{"dcValue1":2,"time":1738215163,"hash":"fb66dca5f27af6f15c1d1d81e6f8d28b"},{"dcValue1":1,"time":1}]},{"file":"/var/www/html/lib/private/DB/ConnectionAdapter.php","line":67,"function":"executeStatement","class":"OC\\DB\\Connection","type":"->","args":["UPDATE `filecache` SET `mtime` = GREATEST(`mtime`, :time), `etag` = '679b0f082163f' WHERE (`storage` = :dcValue1) AND (`path_hash` = :hash)",{"dcValue1":2,"time":1738215163,"hash":"fb66dca5f27af6f15c1d1d81e6f8d28b"},{"dcValue1":1,"time":1}]},{"file":"/var/www/html/lib/private/DB/QueryBuilder/QueryBuilder.php","line":306,"function":"executeStatement","class":"OC\\DB\\ConnectionAdapter","type":"->","args":["UPDATE `*PREFIX*filecache` SET `mtime` = GREATEST(`mtime`, :time), `etag` = '679b0f082163f' WHERE (`storage` = :dcValue1) AND (`path_hash` = :hash)",{"dcValue1":2,"time":1738215163,"hash":"fb66dca5f27af6f15c1d1d81e6f8d28b"},{"dcValue1":1,"time":1}]},{"file":"/var/www/html/lib/private/DB/QueryBuilder/QueryBuilder.php","line":268,"function":"executeStatement","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->","args":[{"__class__":"OC\\DB\\ConnectionAdapter"}]},{"file":"/var/www/html/lib/private/Files/Cache/Propagator.php","line":210,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->","args":[]},{"file":"/var/www/html/lib/private/Files/Utils/Scanner.php","line":164,"function":"commitBatch","class":"OC\\Files\\Cache\\Propagator","type":"->","args":[]},{"file":"/var/www/html/apps/files/lib/Command/Scan.php","line":151,"function":"backgroundScan","class":"OC\\Files\\Utils\\Scanner","type":"->","args":["/julien"]},{"file":"/var/www/html/apps/files/lib/Command/Scan.php","line":214,"function":"scanFiles","class":"OCA\\Files\\Command\\Scan","type":"->","args":["julien","/julien",null,{"__class__":"Symfony\\Component\\Console\\Output\\ConsoleOutput"},true,true,false]},{"file":"/var/www/html/3rdparty/symfony/console/Command/Command.php","line":326,"function":"execute","class":"OCA\\Files\\Command\\Scan","type":"->","args":[{"__class__":"Symfony\\Component\\Console\\Input\\ArgvInput"},{"__class__":"Symfony\\Component\\Console\\Output\\ConsoleOutput"}]},{"file":"/var/www/html/core/Command/Base.php","line":161,"function":"run","class":"Symfony\\Component\\Console\\Command\\Command","type":"->","args":[{"__class__":"Symfony\\Component\\Console\\Input\\ArgvInput"},{"__class__":"Symfony\\Component\\Console\\Output\\ConsoleOutput"}]},{"file":"/var/www/html/3rdparty/symfony/console/Application.php","line":1078,"function":"run","class":"OC\\Core\\Command\\Base","type":"->","args":[{"__class__":"Symfony\\Component\\Console\\Input\\ArgvInput"},{"__class__":"Symfony\\Component\\Console\\Output\\ConsoleOutput"}]},{"file":"/var/www/html/3rdparty/symfony/console/Application.php","line":324,"function":"doRunCommand","class":"Symfony\\Component\\Console\\Application","type":"->","args":[{"__class__":"OCA\\Files\\Command\\Scan"},{"__class__":"Symfony\\Component\\Console\\Input\\ArgvInput"},{"__class__":"Symfony\\Component\\Console\\Output\\ConsoleOutput"}]},{"file":"/var/www/html/3rdparty/symfony/console/Application.php","line":175,"function":"doRun","class":"Symfony\\Component\\Console\\Application","type":"->","args":[{"__class__":"Symfony\\Component\\Console\\Input\\ArgvInput"},{"__class__":"Symfony\\Component\\Console\\Output\\ConsoleOutput"}]},{"file":"/var/www/html/lib/private/Console/Application.php","line":183,"function":"run","class":"Symfony\\Component\\Console\\Application","type":"->","args":[{"__class__":"Symfony\\Component\\Console\\Input\\ArgvInput"},{"__class__":"Symfony\\Component\\Console\\Output\\ConsoleOutput"}]},{"file":"/var/www/html/console.php","line":87,"function":"run","class":"OC\\Console\\Application","type":"->","args":[{"__class__":"Symfony\\Component\\Console\\Input\\ArgvInput"}]},{"file":"/var/www/html/occ","line":11,"args":["/var/www/html/console.php"],"function":"require_once"}],"File":"/var/www/html/3rdparty/doctrine/dbal/src/Driver/PDO/Statement.php","Line":130}},"message":"Error while trying to scan mount as /julien/:An exception occurred while executing a query: SQLSTATE[HY000]: General error: 1205 Lock wait timeout exceeded; try restarting transaction","exception":{},"CustomMessage":"Error while trying to scan mount as /julien/:An exception occurred while executing a query: SQLSTATE[HY000]: General error: 1205 Lock wait timeout exceeded; try restarting transaction"}}
{"reqId":"ugS87UrGVJ0XIke2mjLZ","level":3,"time":"2025-01-30T05:49:10+00:00","remoteAddr":"172.22.0.1","user":"julien","app":"webdav","method":"PUT","url":"/remote.php/dav/files/julien/InstantUpload/Camera/IMG_20250128_220524%20(2)%20(2)%20(2)%20(2)%20(2)%20(2).jpg","message":"An exception occurred while executing a query: SQLSTATE[HY000]: General error: 1205 Lock wait timeout exceeded; try restarting transaction","userAgent":"Mozilla/5.0 (Android) Nextcloud-android/3.30.8","version":"30.0.5.1","exception":{"Exception":"Doctrine\\DBAL\\Exception\\LockWaitTimeoutException","Message":"An exception occurred while executing a query: SQLSTATE[HY000]: General error: 1205 Lock wait timeout exceeded; try restarting transaction","Code":1205,"Trace":[{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Connection.php","line":1939,"function":"convert","class":"Doctrine\\DBAL\\Driver\\API\\MySQL\\ExceptionConverter","type":"->","args":[{"__class__":"Doctrine\\DBAL\\Driver\\PDO\\Exception"},{"__class__":"Doctrine\\DBAL\\Query"}]},{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Connection.php","line":1881,"function":"handleDriverException","class":"Doctrine\\DBAL\\Connection","type":"->","args":[{"__class__":"Doctrine\\DBAL\\Driver\\PDO\\Exception"},{"__class__":"Doctrine\\DBAL\\Query"}]},{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Connection.php","line":1213,"function":"convertExceptionDuringQuery","class":"Doctrine\\DBAL\\Connection","type":"->","args":[{"__class__":"Doctrine\\DBAL\\Driver\\PDO\\Exception"},"UPDATE `filecache` SET `mtime` = ?, `storage_mtime` = ? WHERE (`fileid` = ?) AND (`storage` = ?) AND (((`mtime` <> ?) OR (`mtime` IS NULL)) OR ((`storage_mtime` <> ?) OR (`storage_mtime` IS NULL)))",[1738216091,1738216091,"*** sensitive parameters replaced ***",2,1738216091,"And 1 more entries, set log level to debug to see all entries"],[2,2,1,1,2,"And 1 more entries, set log level to debug to see all entries"]]},{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Connections/PrimaryReadReplicaConnection.php","line":292,"function":"executeStatement","class":"Doctrine\\DBAL\\Connection","type":"->","args":["UPDATE `filecache` SET `mtime` = ?, `storage_mtime` = ? WHERE (`fileid` = ?) AND (`storage` = ?) AND (((`mtime` <> ?) OR (`mtime` IS NULL)) OR ((`storage_mtime` <> ?) OR (`storage_mtime` IS NULL)))",[1738216091,1738216091,"*** sensitive parameters replaced ***",2,1738216091,"And 1 more entries, set log level to debug to see all entries"],[2,2,1,1,2,"And 1 more entries, set log level to debug to see all entries"]]},{"file":"/var/www/html/lib/private/DB/Connection.php","line":462,"function":"executeStatement","class":"Doctrine\\DBAL\\Connections\\PrimaryReadReplicaConnection","type":"->","args":["UPDATE `filecache` SET `mtime` = :dcValue5, `storage_mtime` = :dcValue6 WHERE (`fileid` = :dcValue1) AND (`storage` = :dcValue2) AND (((`mtime` <> :dcValue3) OR (`mtime` IS NULL)) OR ((`storage_mtime` <> :dcValue4) OR (`storage_mtime` IS NULL)))",{"dcValue1":"*** sensitive parameters replaced ***","dcValue2":2,"dcValue3":1738216091,"dcValue4":1738216091,"dcValue5":1738216091,"0":"And 1 more entries, set log level to debug to see all entries"},{"dcValue1":1,"dcValue2":1,"dcValue3":2,"dcValue4":2,"dcValue5":2,"0":"And 1 more entries, set log level to debug to see all entries"}]},{"file":"/var/www/html/lib/private/DB/ConnectionAdapter.php","line":67,"function":"executeStatement","class":"OC\\DB\\Connection","type":"->","args":["UPDATE `filecache` SET `mtime` = :dcValue5, `storage_mtime` = :dcValue6 WHERE (`fileid` = :dcValue1) AND (`storage` = :dcValue2) AND (((`mtime` <> :dcValue3) OR (`mtime` IS NULL)) OR ((`storage_mtime` <> :dcValue4) OR (`storage_mtime` IS NULL)))",{"dcValue1":"*** sensitive parameters replaced ***","dcValue2":2,"dcValue3":1738216091,"dcValue4":1738216091,"dcValue5":1738216091,"0":"And 1 more entries, set log level to debug to see all entries"},{"dcValue1":1,"dcValue2":1,"dcValue3":2,"dcValue4":2,"dcValue5":2,"0":"And 1 more entries, set log level to debug to see all entries"}]},{"file":"/var/www/html/lib/private/DB/QueryBuilder/QueryBuilder.php","line":306,"function":"executeStatement","class":"OC\\DB\\ConnectionAdapter","type":"->","args":["UPDATE `*PREFIX*filecache` SET `mtime` = :dcValue5, `storage_mtime` = :dcValue6 WHERE (`fileid` = :dcValue1) AND (`storage` = :dcValue2) AND (((`mtime` <> :dcValue3) OR (`mtime` IS NULL)) OR ((`storage_mtime` <> :dcValue4) OR (`storage_mtime` IS NULL)))",{"dcValue1":"*** sensitive parameters replaced ***","dcValue2":2,"dcValue3":1738216091,"dcValue4":1738216091,"dcValue5":1738216091,"0":"And 1 more entries, set log level to debug to see all entries"},{"dcValue1":1,"dcValue2":1,"dcValue3":2,"dcValue4":2,"dcValue5":2,"0":"And 1 more entries, set log level to debug to see all entries"}]},{"file":"/var/www/html/lib/private/DB/QueryBuilder/ExtendedQueryBuilder.php","line":289,"function":"executeStatement","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->","args":[{"__class__":"OC\\DB\\ConnectionAdapter"}]},{"file":"/var/www/html/lib/private/DB/QueryBuilder/ExtendedQueryBuilder.php","line":55,"function":"executeStatement","class":"OC\\DB\\QueryBuilder\\ExtendedQueryBuilder","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/lib/private/Files/Cache/Cache.php","line":358,"function":"execute","class":"OC\\DB\\QueryBuilder\\ExtendedQueryBuilder","type":"->","args":[]},{"file":"/var/www/html/lib/private/Files/Cache/Updater.php","line":248,"function":"update","class":"OC\\Files\\Cache\\Cache","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/lib/private/Files/Cache/Updater.php","line":125,"function":"correctParentStorageMtime","class":"OC\\Files\\Cache\\Updater","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/apps/dav/lib/Connector/Sabre/File.php","line":330,"function":"update","class":"OC\\Files\\Cache\\Updater","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/apps/dav/lib/Connector/Sabre/Directory.php","line":110,"function":"put","class":"OCA\\DAV\\Connector\\Sabre\\File","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php","line":1098,"function":"createFile","class":"OCA\\DAV\\Connector\\Sabre\\Directory","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":504,"function":"createFile","class":"Sabre\\DAV\\Server","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpPut","class":"Sabre\\DAV\\CorePlugin","type":"->","args":[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->","args":["method:PUT",[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]]},{"file":"/var/www/html/apps/dav/lib/Connector/Sabre/Server.php","line":43,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->","args":[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/html/apps/dav/lib/Server.php","line":371,"function":"start","class":"OCA\\DAV\\Connector\\Sabre\\Server","type":"->","args":[]},{"file":"/var/www/html/apps/dav/appinfo/v2/remote.php","line":19,"function":"exec","class":"OCA\\DAV\\Server","type":"->","args":[]},{"file":"/var/www/html/remote.php","line":146,"args":["/var/www/html/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/var/www/html/3rdparty/doctrine/dbal/src/Driver/API/MySQL/ExceptionConverter.php","Line":42,"Previous":{"Exception":"Doctrine\\DBAL\\Driver\\PDO\\Exception","Message":"SQLSTATE[HY000]: General error: 1205 Lock wait timeout exceeded; try restarting transaction","Code":1205,"Trace":[{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Driver/PDO/Statement.php","line":132,"function":"new","class":"Doctrine\\DBAL\\Driver\\PDO\\Exception","type":"::","args":[{"__class__":"PDOException","errorInfo":["HY000",1205,"Lock wait timeout exceeded; try restarting transaction"]}]},{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Connection.php","line":1207,"function":"execute","class":"Doctrine\\DBAL\\Driver\\PDO\\Statement","type":"->","args":[]},{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Connections/PrimaryReadReplicaConnection.php","line":292,"function":"executeStatement","class":"Doctrine\\DBAL\\Connection","type":"->","args":["UPDATE `filecache` SET `mtime` = ?, `storage_mtime` = ? WHERE (`fileid` = ?) AND (`storage` = ?) AND (((`mtime` <> ?) OR (`mtime` IS NULL)) OR ((`storage_mtime` <> ?) OR (`storage_mtime` IS NULL)))",[1738216091,1738216091,"*** sensitive parameters replaced ***",2,1738216091,"And 1 more entries, set log level to debug to see all entries"],[2,2,1,1,2,"And 1 more entries, set log level to debug to see all entries"]]},{"file":"/var/www/html/lib/private/DB/Connection.php","line":462,"function":"executeStatement","class":"Doctrine\\DBAL\\Connections\\PrimaryReadReplicaConnection","type":"->","args":["UPDATE `filecache` SET `mtime` = :dcValue5, `storage_mtime` = :dcValue6 WHERE (`fileid` = :dcValue1) AND (`storage` = :dcValue2) AND (((`mtime` <> :dcValue3) OR (`mtime` IS NULL)) OR ((`storage_mtime` <> :dcValue4) OR (`storage_mtime` IS NULL)))",{"dcValue1":"*** sensitive parameters replaced ***","dcValue2":2,"dcValue3":1738216091,"dcValue4":1738216091,"dcValue5":1738216091,"0":"And 1 more entries, set log level to debug to see all entries"},{"dcValue1":1,"dcValue2":1,"dcValue3":2,"dcValue4":2,"dcValue5":2,"0":"And 1 more entries, set log level to debug to see all entries"}]},{"file":"/var/www/html/lib/private/DB/ConnectionAdapter.php","line":67,"function":"executeStatement","class":"OC\\DB\\Connection","type":"->","args":["UPDATE `filecache` SET `mtime` = :dcValue5, `storage_mtime` = :dcValue6 WHERE (`fileid` = :dcValue1) AND (`storage` = :dcValue2) AND (((`mtime` <> :dcValue3) OR (`mtime` IS NULL)) OR ((`storage_mtime` <> :dcValue4) OR (`storage_mtime` IS NULL)))",{"dcValue1":"*** sensitive parameters replaced ***","dcValue2":2,"dcValue3":1738216091,"dcValue4":1738216091,"dcValue5":1738216091,"0":"And 1 more entries, set log level to debug to see all entries"},{"dcValue1":1,"dcValue2":1,"dcValue3":2,"dcValue4":2,"dcValue5":2,"0":"And 1 more entries, set log level to debug to see all entries"}]},{"file":"/var/www/html/lib/private/DB/QueryBuilder/QueryBuilder.php","line":306,"function":"executeStatement","class":"OC\\DB\\ConnectionAdapter","type":"->","args":["UPDATE `*PREFIX*filecache` SET `mtime` = :dcValue5, `storage_mtime` = :dcValue6 WHERE (`fileid` = :dcValue1) AND (`storage` = :dcValue2) AND (((`mtime` <> :dcValue3) OR (`mtime` IS NULL)) OR ((`storage_mtime` <> :dcValue4) OR (`storage_mtime` IS NULL)))",{"dcValue1":"*** sensitive parameters replaced ***","dcValue2":2,"dcValue3":1738216091,"dcValue4":1738216091,"dcValue5":1738216091,"0":"And 1 more entries, set log level to debug to see all entries"},{"dcValue1":1,"dcValue2":1,"dcValue3":2,"dcValue4":2,"dcValue5":2,"0":"And 1 more entries, set log level to debug to see all entries"}]},{"file":"/var/www/html/lib/private/DB/QueryBuilder/ExtendedQueryBuilder.php","line":289,"function":"executeStatement","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->","args":[{"__class__":"OC\\DB\\ConnectionAdapter"}]},{"file":"/var/www/html/lib/private/DB/QueryBuilder/ExtendedQueryBuilder.php","line":55,"function":"executeStatement","class":"OC\\DB\\QueryBuilder\\ExtendedQueryBuilder","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/lib/private/Files/Cache/Cache.php","line":358,"function":"execute","class":"OC\\DB\\QueryBuilder\\ExtendedQueryBuilder","type":"->","args":[]},{"file":"/var/www/html/lib/private/Files/Cache/Updater.php","line":248,"function":"update","class":"OC\\Files\\Cache\\Cache","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/lib/private/Files/Cache/Updater.php","line":125,"function":"correctParentStorageMtime","class":"OC\\Files\\Cache\\Updater","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/apps/dav/lib/Connector/Sabre/File.php","line":330,"function":"update","class":"OC\\Files\\Cache\\Updater","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/apps/dav/lib/Connector/Sabre/Directory.php","line":110,"function":"put","class":"OCA\\DAV\\Connector\\Sabre\\File","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php","line":1098,"function":"createFile","class":"OCA\\DAV\\Connector\\Sabre\\Directory","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":504,"function":"createFile","class":"Sabre\\DAV\\Server","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpPut","class":"Sabre\\DAV\\CorePlugin","type":"->","args":[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->","args":["method:PUT",[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]]},{"file":"/var/www/html/apps/dav/lib/Connector/Sabre/Server.php","line":43,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->","args":[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/html/apps/dav/lib/Server.php","line":371,"function":"start","class":"OCA\\DAV\\Connector\\Sabre\\Server","type":"->","args":[]},{"file":"/var/www/html/apps/dav/appinfo/v2/remote.php","line":19,"function":"exec","class":"OCA\\DAV\\Server","type":"->","args":[]},{"file":"/var/www/html/remote.php","line":146,"args":["/var/www/html/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/var/www/html/3rdparty/doctrine/dbal/src/Driver/PDO/Exception.php","Line":28,"Previous":{"Exception":"PDOException","Message":"SQLSTATE[HY000]: General error: 1205 Lock wait timeout exceeded; try restarting transaction","Code":"HY000","Trace":[{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Driver/PDO/Statement.php","line":130,"function":"execute","class":"PDOStatement","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Connection.php","line":1207,"function":"execute","class":"Doctrine\\DBAL\\Driver\\PDO\\Statement","type":"->","args":[]},{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Connections/PrimaryReadReplicaConnection.php","line":292,"function":"executeStatement","class":"Doctrine\\DBAL\\Connection","type":"->","args":["UPDATE `filecache` SET `mtime` = ?, `storage_mtime` = ? WHERE (`fileid` = ?) AND (`storage` = ?) AND (((`mtime` <> ?) OR (`mtime` IS NULL)) OR ((`storage_mtime` <> ?) OR (`storage_mtime` IS NULL)))",[1738216091,1738216091,"*** sensitive parameters replaced ***",2,1738216091,"And 1 more entries, set log level to debug to see all entries"],[2,2,1,1,2,"And 1 more entries, set log level to debug to see all entries"]]},{"file":"/var/www/html/lib/private/DB/Connection.php","line":462,"function":"executeStatement","class":"Doctrine\\DBAL\\Connections\\PrimaryReadReplicaConnection","type":"->","args":["UPDATE `filecache` SET `mtime` = :dcValue5, `storage_mtime` = :dcValue6 WHERE (`fileid` = :dcValue1) AND (`storage` = :dcValue2) AND (((`mtime` <> :dcValue3) OR (`mtime` IS NULL)) OR ((`storage_mtime` <> :dcValue4) OR (`storage_mtime` IS NULL)))",{"dcValue1":"*** sensitive parameters replaced ***","dcValue2":2,"dcValue3":1738216091,"dcValue4":1738216091,"dcValue5":1738216091,"0":"And 1 more entries, set log level to debug to see all entries"},{"dcValue1":1,"dcValue2":1,"dcValue3":2,"dcValue4":2,"dcValue5":2,"0":"And 1 more entries, set log level to debug to see all entries"}]},{"file":"/var/www/html/lib/private/DB/ConnectionAdapter.php","line":67,"function":"executeStatement","class":"OC\\DB\\Connection","type":"->","args":["UPDATE `filecache` SET `mtime` = :dcValue5, `storage_mtime` = :dcValue6 WHERE (`fileid` = :dcValue1) AND (`storage` = :dcValue2) AND (((`mtime` <> :dcValue3) OR (`mtime` IS NULL)) OR ((`storage_mtime` <> :dcValue4) OR (`storage_mtime` IS NULL)))",{"dcValue1":"*** sensitive parameters replaced ***","dcValue2":2,"dcValue3":1738216091,"dcValue4":1738216091,"dcValue5":1738216091,"0":"And 1 more entries, set log level to debug to see all entries"},{"dcValue1":1,"dcValue2":1,"dcValue3":2,"dcValue4":2,"dcValue5":2,"0":"And 1 more entries, set log level to debug to see all entries"}]},{"file":"/var/www/html/lib/private/DB/QueryBuilder/QueryBuilder.php","line":306,"function":"executeStatement","class":"OC\\DB\\ConnectionAdapter","type":"->","args":["UPDATE `*PREFIX*filecache` SET `mtime` = :dcValue5, `storage_mtime` = :dcValue6 WHERE (`fileid` = :dcValue1) AND (`storage` = :dcValue2) AND (((`mtime` <> :dcValue3) OR (`mtime` IS NULL)) OR ((`storage_mtime` <> :dcValue4) OR (`storage_mtime` IS NULL)))",{"dcValue1":"*** sensitive parameters replaced ***","dcValue2":2,"dcValue3":1738216091,"dcValue4":1738216091,"dcValue5":1738216091,"0":"And 1 more entries, set log level to debug to see all entries"},{"dcValue1":1,"dcValue2":1,"dcValue3":2,"dcValue4":2,"dcValue5":2,"0":"And 1 more entries, set log level to debug to see all entries"}]},{"file":"/var/www/html/lib/private/DB/QueryBuilder/ExtendedQueryBuilder.php","line":289,"function":"executeStatement","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->","args":[{"__class__":"OC\\DB\\ConnectionAdapter"}]},{"file":"/var/www/html/lib/private/DB/QueryBuilder/ExtendedQueryBuilder.php","line":55,"function":"executeStatement","class":"OC\\DB\\QueryBuilder\\ExtendedQueryBuilder","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/lib/private/Files/Cache/Cache.php","line":358,"function":"execute","class":"OC\\DB\\QueryBuilder\\ExtendedQueryBuilder","type":"->","args":[]},{"file":"/var/www/html/lib/private/Files/Cache/Updater.php","line":248,"function":"update","class":"OC\\Files\\Cache\\Cache","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/lib/private/Files/Cache/Updater.php","line":125,"function":"correctParentStorageMtime","class":"OC\\Files\\Cache\\Updater","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/apps/dav/lib/Connector/Sabre/File.php","line":330,"function":"update","class":"OC\\Files\\Cache\\Updater","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/apps/dav/lib/Connector/Sabre/Directory.php","line":110,"function":"put","class":"OCA\\DAV\\Connector\\Sabre\\File","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php","line":1098,"function":"createFile","class":"OCA\\DAV\\Connector\\Sabre\\Directory","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":504,"function":"createFile","class":"Sabre\\DAV\\Server","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpPut","class":"Sabre\\DAV\\CorePlugin","type":"->","args":[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->","args":["method:PUT",[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]]},{"file":"/var/www/html/apps/dav/lib/Connector/Sabre/Server.php","line":43,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->","args":[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/html/apps/dav/lib/Server.php","line":371,"function":"start","class":"OCA\\DAV\\Connector\\Sabre\\Server","type":"->","args":[]},{"file":"/var/www/html/apps/dav/appinfo/v2/remote.php","line":19,"function":"exec","class":"OCA\\DAV\\Server","type":"->","args":[]},{"file":"/var/www/html/remote.php","line":146,"args":["/var/www/html/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/var/www/html/3rdparty/doctrine/dbal/src/Driver/PDO/Statement.php","Line":130}},"message":"An exception occurred while executing a query: SQLSTATE[HY000]: General error: 1205 Lock wait timeout exceeded; try restarting transaction","exception":{},"CustomMessage":"An exception occurred while executing a query: SQLSTATE[HY000]: General error: 1205 Lock wait timeout exceeded; try restarting transaction"}}
{"reqId":"exAsYFqDwzyKtQFuN26B","level":3,"time":"2025-01-30T05:51:24+00:00","remoteAddr":"172.22.0.1","user":"julien","app":"webdav","method":"PUT","url":"/remote.php/dav/files/julien/InstantUpload/Camera/IMG_20250129_224719%20(2).jpg","message":"An exception occurred while executing a query: SQLSTATE[HY000]: General error: 1205 Lock wait timeout exceeded; try restarting transaction","userAgent":"Mozilla/5.0 (Android) Nextcloud-android/3.30.8","version":"30.0.5.1","exception":{"Exception":"Doctrine\\DBAL\\Exception\\LockWaitTimeoutException","Message":"An exception occurred while executing a query: SQLSTATE[HY000]: General error: 1205 Lock wait timeout exceeded; try restarting transaction","Code":1205,"Trace":[{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Connection.php","line":1939,"function":"convert","class":"Doctrine\\DBAL\\Driver\\API\\MySQL\\ExceptionConverter","type":"->","args":[{"__class__":"Doctrine\\DBAL\\Driver\\PDO\\Exception"},{"__class__":"Doctrine\\DBAL\\Query"}]},{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Connection.php","line":1881,"function":"handleDriverException","class":"Doctrine\\DBAL\\Connection","type":"->","args":[{"__class__":"Doctrine\\DBAL\\Driver\\PDO\\Exception"},{"__class__":"Doctrine\\DBAL\\Query"}]},{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Connection.php","line":1213,"function":"convertExceptionDuringQuery","class":"Doctrine\\DBAL\\Connection","type":"->","args":[{"__class__":"Doctrine\\DBAL\\Driver\\PDO\\Exception"},"UPDATE `filecache` SET `mtime` = ?, `storage_mtime` = ? WHERE (`fileid` = ?) AND (`storage` = ?) AND (((`mtime` <> ?) OR (`mtime` IS NULL)) OR ((`storage_mtime` <> ?) OR (`storage_mtime` IS NULL)))",[1738216223,1738216223,"*** sensitive parameters replaced ***",2,1738216223,"And 1 more entries, set log level to debug to see all entries"],[2,2,1,1,2,"And 1 more entries, set log level to debug to see all entries"]]},{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Connections/PrimaryReadReplicaConnection.php","line":292,"function":"executeStatement","class":"Doctrine\\DBAL\\Connection","type":"->","args":["UPDATE `filecache` SET `mtime` = ?, `storage_mtime` = ? WHERE (`fileid` = ?) AND (`storage` = ?) AND (((`mtime` <> ?) OR (`mtime` IS NULL)) OR ((`storage_mtime` <> ?) OR (`storage_mtime` IS NULL)))",[1738216223,1738216223,"*** sensitive parameters replaced ***",2,1738216223,"And 1 more entries, set log level to debug to see all entries"],[2,2,1,1,2,"And 1 more entries, set log level to debug to see all entries"]]},{"file":"/var/www/html/lib/private/DB/Connection.php","line":462,"function":"executeStatement","class":"Doctrine\\DBAL\\Connections\\PrimaryReadReplicaConnection","type":"->","args":["UPDATE `filecache` SET `mtime` = :dcValue5, `storage_mtime` = :dcValue6 WHERE (`fileid` = :dcValue1) AND (`storage` = :dcValue2) AND (((`mtime` <> :dcValue3) OR (`mtime` IS NULL)) OR ((`storage_mtime` <> :dcValue4) OR (`storage_mtime` IS NULL)))",{"dcValue1":"*** sensitive parameters replaced ***","dcValue2":2,"dcValue3":1738216223,"dcValue4":1738216223,"dcValue5":1738216223,"0":"And 1 more entries, set log level to debug to see all entries"},{"dcValue1":1,"dcValue2":1,"dcValue3":2,"dcValue4":2,"dcValue5":2,"0":"And 1 more entries, set log level to debug to see all entries"}]},{"file":"/var/www/html/lib/private/DB/ConnectionAdapter.php","line":67,"function":"executeStatement","class":"OC\\DB\\Connection","type":"->","args":["UPDATE `filecache` SET `mtime` = :dcValue5, `storage_mtime` = :dcValue6 WHERE (`fileid` = :dcValue1) AND (`storage` = :dcValue2) AND (((`mtime` <> :dcValue3) OR (`mtime` IS NULL)) OR ((`storage_mtime` <> :dcValue4) OR (`storage_mtime` IS NULL)))",{"dcValue1":"*** sensitive parameters replaced ***","dcValue2":2,"dcValue3":1738216223,"dcValue4":1738216223,"dcValue5":1738216223,"0":"And 1 more entries, set log level to debug to see all entries"},{"dcValue1":1,"dcValue2":1,"dcValue3":2,"dcValue4":2,"dcValue5":2,"0":"And 1 more entries, set log level to debug to see all entries"}]},{"file":"/var/www/html/lib/private/DB/QueryBuilder/QueryBuilder.php","line":306,"function":"executeStatement","class":"OC\\DB\\ConnectionAdapter","type":"->","args":["UPDATE `*PREFIX*filecache` SET `mtime` = :dcValue5, `storage_mtime` = :dcValue6 WHERE (`fileid` = :dcValue1) AND (`storage` = :dcValue2) AND (((`mtime` <> :dcValue3) OR (`mtime` IS NULL)) OR ((`storage_mtime` <> :dcValue4) OR (`storage_mtime` IS NULL)))",{"dcValue1":"*** sensitive parameters replaced ***","dcValue2":2,"dcValue3":1738216223,"dcValue4":1738216223,"dcValue5":1738216223,"0":"And 1 more entries, set log level to debug to see all entries"},{"dcValue1":1,"dcValue2":1,"dcValue3":2,"dcValue4":2,"dcValue5":2,"0":"And 1 more entries, set log level to debug to see all entries"}]},{"file":"/var/www/html/lib/private/DB/QueryBuilder/ExtendedQueryBuilder.php","line":289,"function":"executeStatement","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->","args":[{"__class__":"OC\\DB\\ConnectionAdapter"}]},{"file":"/var/www/html/lib/private/DB/QueryBuilder/ExtendedQueryBuilder.php","line":55,"function":"executeStatement","class":"OC\\DB\\QueryBuilder\\ExtendedQueryBuilder","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/lib/private/Files/Cache/Cache.php","line":358,"function":"execute","class":"OC\\DB\\QueryBuilder\\ExtendedQueryBuilder","type":"->","args":[]},{"file":"/var/www/html/lib/private/Files/Cache/Updater.php","line":248,"function":"update","class":"OC\\Files\\Cache\\Cache","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/lib/private/Files/Cache/Updater.php","line":125,"function":"correctParentStorageMtime","class":"OC\\Files\\Cache\\Updater","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/apps/dav/lib/Connector/Sabre/File.php","line":330,"function":"update","class":"OC\\Files\\Cache\\Updater","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/apps/dav/lib/Connector/Sabre/Directory.php","line":110,"function":"put","class":"OCA\\DAV\\Connector\\Sabre\\File","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php","line":1098,"function":"createFile","class":"OCA\\DAV\\Connector\\Sabre\\Directory","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":504,"function":"createFile","class":"Sabre\\DAV\\Server","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpPut","class":"Sabre\\DAV\\CorePlugin","type":"->","args":[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->","args":["method:PUT",[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]]},{"file":"/var/www/html/apps/dav/lib/Connector/Sabre/Server.php","line":43,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->","args":[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/html/apps/dav/lib/Server.php","line":371,"function":"start","class":"OCA\\DAV\\Connector\\Sabre\\Server","type":"->","args":[]},{"file":"/var/www/html/apps/dav/appinfo/v2/remote.php","line":19,"function":"exec","class":"OCA\\DAV\\Server","type":"->","args":[]},{"file":"/var/www/html/remote.php","line":146,"args":["/var/www/html/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/var/www/html/3rdparty/doctrine/dbal/src/Driver/API/MySQL/ExceptionConverter.php","Line":42,"Previous":{"Exception":"Doctrine\\DBAL\\Driver\\PDO\\Exception","Message":"SQLSTATE[HY000]: General error: 1205 Lock wait timeout exceeded; try restarting transaction","Code":1205,"Trace":[{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Driver/PDO/Statement.php","line":132,"function":"new","class":"Doctrine\\DBAL\\Driver\\PDO\\Exception","type":"::","args":[{"__class__":"PDOException","errorInfo":["HY000",1205,"Lock wait timeout exceeded; try restarting transaction"]}]},{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Connection.php","line":1207,"function":"execute","class":"Doctrine\\DBAL\\Driver\\PDO\\Statement","type":"->","args":[]},{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Connections/PrimaryReadReplicaConnection.php","line":292,"function":"executeStatement","class":"Doctrine\\DBAL\\Connection","type":"->","args":["UPDATE `filecache` SET `mtime` = ?, `storage_mtime` = ? WHERE (`fileid` = ?) AND (`storage` = ?) AND (((`mtime` <> ?) OR (`mtime` IS NULL)) OR ((`storage_mtime` <> ?) OR (`storage_mtime` IS NULL)))",[1738216223,1738216223,"*** sensitive parameters replaced ***",2,1738216223,"And 1 more entries, set log level to debug to see all entries"],[2,2,1,1,2,"And 1 more entries, set log level to debug to see all entries"]]},{"file":"/var/www/html/lib/private/DB/Connection.php","line":462,"function":"executeStatement","class":"Doctrine\\DBAL\\Connections\\PrimaryReadReplicaConnection","type":"->","args":["UPDATE `filecache` SET `mtime` = :dcValue5, `storage_mtime` = :dcValue6 WHERE (`fileid` = :dcValue1) AND (`storage` = :dcValue2) AND (((`mtime` <> :dcValue3) OR (`mtime` IS NULL)) OR ((`storage_mtime` <> :dcValue4) OR (`storage_mtime` IS NULL)))",{"dcValue1":"*** sensitive parameters replaced ***","dcValue2":2,"dcValue3":1738216223,"dcValue4":1738216223,"dcValue5":1738216223,"0":"And 1 more entries, set log level to debug to see all entries"},{"dcValue1":1,"dcValue2":1,"dcValue3":2,"dcValue4":2,"dcValue5":2,"0":"And 1 more entries, set log level to debug to see all entries"}]},{"file":"/var/www/html/lib/private/DB/ConnectionAdapter.php","line":67,"function":"executeStatement","class":"OC\\DB\\Connection","type":"->","args":["UPDATE `filecache` SET `mtime` = :dcValue5, `storage_mtime` = :dcValue6 WHERE (`fileid` = :dcValue1) AND (`storage` = :dcValue2) AND (((`mtime` <> :dcValue3) OR (`mtime` IS NULL)) OR ((`storage_mtime` <> :dcValue4) OR (`storage_mtime` IS NULL)))",{"dcValue1":"*** sensitive parameters replaced ***","dcValue2":2,"dcValue3":1738216223,"dcValue4":1738216223,"dcValue5":1738216223,"0":"And 1 more entries, set log level to debug to see all entries"},{"dcValue1":1,"dcValue2":1,"dcValue3":2,"dcValue4":2,"dcValue5":2,"0":"And 1 more entries, set log level to debug to see all entries"}]},{"file":"/var/www/html/lib/private/DB/QueryBuilder/QueryBuilder.php","line":306,"function":"executeStatement","class":"OC\\DB\\ConnectionAdapter","type":"->","args":["UPDATE `*PREFIX*filecache` SET `mtime` = :dcValue5, `storage_mtime` = :dcValue6 WHERE (`fileid` = :dcValue1) AND (`storage` = :dcValue2) AND (((`mtime` <> :dcValue3) OR (`mtime` IS NULL)) OR ((`storage_mtime` <> :dcValue4) OR (`storage_mtime` IS NULL)))",{"dcValue1":"*** sensitive parameters replaced ***","dcValue2":2,"dcValue3":1738216223,"dcValue4":1738216223,"dcValue5":1738216223,"0":"And 1 more entries, set log level to debug to see all entries"},{"dcValue1":1,"dcValue2":1,"dcValue3":2,"dcValue4":2,"dcValue5":2,"0":"And 1 more entries, set log level to debug to see all entries"}]},{"file":"/var/www/html/lib/private/DB/QueryBuilder/ExtendedQueryBuilder.php","line":289,"function":"executeStatement","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->","args":[{"__class__":"OC\\DB\\ConnectionAdapter"}]},{"file":"/var/www/html/lib/private/DB/QueryBuilder/ExtendedQueryBuilder.php","line":55,"function":"executeStatement","class":"OC\\DB\\QueryBuilder\\ExtendedQueryBuilder","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/lib/private/Files/Cache/Cache.php","line":358,"function":"execute","class":"OC\\DB\\QueryBuilder\\ExtendedQueryBuilder","type":"->","args":[]},{"file":"/var/www/html/lib/private/Files/Cache/Updater.php","line":248,"function":"update","class":"OC\\Files\\Cache\\Cache","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/lib/private/Files/Cache/Updater.php","line":125,"function":"correctParentStorageMtime","class":"OC\\Files\\Cache\\Updater","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/apps/dav/lib/Connector/Sabre/File.php","line":330,"function":"update","class":"OC\\Files\\Cache\\Updater","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/apps/dav/lib/Connector/Sabre/Directory.php","line":110,"function":"put","class":"OCA\\DAV\\Connector\\Sabre\\File","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php","line":1098,"function":"createFile","class":"OCA\\DAV\\Connector\\Sabre\\Directory","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":504,"function":"createFile","class":"Sabre\\DAV\\Server","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpPut","class":"Sabre\\DAV\\CorePlugin","type":"->","args":[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->","args":["method:PUT",[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]]},{"file":"/var/www/html/apps/dav/lib/Connector/Sabre/Server.php","line":43,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->","args":[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/html/apps/dav/lib/Server.php","line":371,"function":"start","class":"OCA\\DAV\\Connector\\Sabre\\Server","type":"->","args":[]},{"file":"/var/www/html/apps/dav/appinfo/v2/remote.php","line":19,"function":"exec","class":"OCA\\DAV\\Server","type":"->","args":[]},{"file":"/var/www/html/remote.php","line":146,"args":["/var/www/html/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/var/www/html/3rdparty/doctrine/dbal/src/Driver/PDO/Exception.php","Line":28,"Previous":{"Exception":"PDOException","Message":"SQLSTATE[HY000]: General error: 1205 Lock wait timeout exceeded; try restarting transaction","Code":"HY000","Trace":[{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Driver/PDO/Statement.php","line":130,"function":"execute","class":"PDOStatement","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Connection.php","line":1207,"function":"execute","class":"Doctrine\\DBAL\\Driver\\PDO\\Statement","type":"->","args":[]},{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Connections/PrimaryReadReplicaConnection.php","line":292,"function":"executeStatement","class":"Doctrine\\DBAL\\Connection","type":"->","args":["UPDATE `filecache` SET `mtime` = ?, `storage_mtime` = ? WHERE (`fileid` = ?) AND (`storage` = ?) AND (((`mtime` <> ?) OR (`mtime` IS NULL)) OR ((`storage_mtime` <> ?) OR (`storage_mtime` IS NULL)))",[1738216223,1738216223,"*** sensitive parameters replaced ***",2,1738216223,"And 1 more entries, set log level to debug to see all entries"],[2,2,1,1,2,"And 1 more entries, set log level to debug to see all entries"]]},{"file":"/var/www/html/lib/private/DB/Connection.php","line":462,"function":"executeStatement","class":"Doctrine\\DBAL\\Connections\\PrimaryReadReplicaConnection","type":"->","args":["UPDATE `filecache` SET `mtime` = :dcValue5, `storage_mtime` = :dcValue6 WHERE (`fileid` = :dcValue1) AND (`storage` = :dcValue2) AND (((`mtime` <> :dcValue3) OR (`mtime` IS NULL)) OR ((`storage_mtime` <> :dcValue4) OR (`storage_mtime` IS NULL)))",{"dcValue1":"*** sensitive parameters replaced ***","dcValue2":2,"dcValue3":1738216223,"dcValue4":1738216223,"dcValue5":1738216223,"0":"And 1 more entries, set log level to debug to see all entries"},{"dcValue1":1,"dcValue2":1,"dcValue3":2,"dcValue4":2,"dcValue5":2,"0":"And 1 more entries, set log level to debug to see all entries"}]},{"file":"/var/www/html/lib/private/DB/ConnectionAdapter.php","line":67,"function":"executeStatement","class":"OC\\DB\\Connection","type":"->","args":["UPDATE `filecache` SET `mtime` = :dcValue5, `storage_mtime` = :dcValue6 WHERE (`fileid` = :dcValue1) AND (`storage` = :dcValue2) AND (((`mtime` <> :dcValue3) OR (`mtime` IS NULL)) OR ((`storage_mtime` <> :dcValue4) OR (`storage_mtime` IS NULL)))",{"dcValue1":"*** sensitive parameters replaced ***","dcValue2":2,"dcValue3":1738216223,"dcValue4":1738216223,"dcValue5":1738216223,"0":"And 1 more entries, set log level to debug to see all entries"},{"dcValue1":1,"dcValue2":1,"dcValue3":2,"dcValue4":2,"dcValue5":2,"0":"And 1 more entries, set log level to debug to see all entries"}]},{"file":"/var/www/html/lib/private/DB/QueryBuilder/QueryBuilder.php","line":306,"function":"executeStatement","class":"OC\\DB\\ConnectionAdapter","type":"->","args":["UPDATE `*PREFIX*filecache` SET `mtime` = :dcValue5, `storage_mtime` = :dcValue6 WHERE (`fileid` = :dcValue1) AND (`storage` = :dcValue2) AND (((`mtime` <> :dcValue3) OR (`mtime` IS NULL)) OR ((`storage_mtime` <> :dcValue4) OR (`storage_mtime` IS NULL)))",{"dcValue1":"*** sensitive parameters replaced ***","dcValue2":2,"dcValue3":1738216223,"dcValue4":1738216223,"dcValue5":1738216223,"0":"And 1 more entries, set log level to debug to see all entries"},{"dcValue1":1,"dcValue2":1,"dcValue3":2,"dcValue4":2,"dcValue5":2,"0":"And 1 more entries, set log level to debug to see all entries"}]},{"file":"/var/www/html/lib/private/DB/QueryBuilder/ExtendedQueryBuilder.php","line":289,"function":"executeStatement","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->","args":[{"__class__":"OC\\DB\\ConnectionAdapter"}]},{"file":"/var/www/html/lib/private/DB/QueryBuilder/ExtendedQueryBuilder.php","line":55,"function":"executeStatement","class":"OC\\DB\\QueryBuilder\\ExtendedQueryBuilder","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/lib/private/Files/Cache/Cache.php","line":358,"function":"execute","class":"OC\\DB\\QueryBuilder\\ExtendedQueryBuilder","type":"->","args":[]},{"file":"/var/www/html/lib/private/Files/Cache/Updater.php","line":248,"function":"update","class":"OC\\Files\\Cache\\Cache","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/lib/private/Files/Cache/Updater.php","line":125,"function":"correctParentStorageMtime","class":"OC\\Files\\Cache\\Updater","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/apps/dav/lib/Connector/Sabre/File.php","line":330,"function":"update","class":"OC\\Files\\Cache\\Updater","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/apps/dav/lib/Connector/Sabre/Directory.php","line":110,"function":"put","class":"OCA\\DAV\\Connector\\Sabre\\File","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php","line":1098,"function":"createFile","class":"OCA\\DAV\\Connector\\Sabre\\Directory","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":504,"function":"createFile","class":"Sabre\\DAV\\Server","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpPut","class":"Sabre\\DAV\\CorePlugin","type":"->","args":[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->","args":["method:PUT",[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]]},{"file":"/var/www/html/apps/dav/lib/Connector/Sabre/Server.php","line":43,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->","args":[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/html/apps/dav/lib/Server.php","line":371,"function":"start","class":"OCA\\DAV\\Connector\\Sabre\\Server","type":"->","args":[]},{"file":"/var/www/html/apps/dav/appinfo/v2/remote.php","line":19,"function":"exec","class":"OCA\\DAV\\Server","type":"->","args":[]},{"file":"/var/www/html/remote.php","line":146,"args":["/var/www/html/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/var/www/html/3rdparty/doctrine/dbal/src/Driver/PDO/Statement.php","Line":130}},"message":"An exception occurred while executing a query: SQLSTATE[HY000]: General error: 1205 Lock wait timeout exceeded; try restarting transaction","exception":{},"CustomMessage":"An exception occurred while executing a query: SQLSTATE[HY000]: General error: 1205 Lock wait timeout exceeded; try restarting transaction"}}
{"reqId":"yuc0RemlZBMS1cIcfFJe","level":3,"time":"2025-01-30T06:53:43+00:00","remoteAddr":"","user":"--","app":"no app in context","method":"","url":"--","message":"Transaction took 5024.1708259583s","userAgent":"--","version":"30.0.5.1","exception":{"Exception":"Exception","Message":"Transaction took 5024.1708259583s","Code":0,"Trace":[{"file":"/var/www/html/lib/private/DB/ConnectionAdapter.php","line":135,"function":"commit","class":"OC\\DB\\Connection","type":"->","args":[]},{"file":"/var/www/html/lib/private/Files/Utils/Scanner.php","line":267,"function":"commit","class":"OC\\DB\\ConnectionAdapter","type":"->","args":[]},{"file":"/var/www/html/apps/files/lib/Command/Scan.php","line":153,"function":"scan","class":"OC\\Files\\Utils\\Scanner","type":"->","args":["/julien",true,null]},{"file":"/var/www/html/apps/files/lib/Command/Scan.php","line":214,"function":"scanFiles","class":"OCA\\Files\\Command\\Scan","type":"->","args":["julien","/julien",null,{"__class__":"Symfony\\Component\\Console\\Output\\ConsoleOutput"},false,true,false]},{"file":"/var/www/html/3rdparty/symfony/console/Command/Command.php","line":326,"function":"execute","class":"OCA\\Files\\Command\\Scan","type":"->","args":[{"__class__":"Symfony\\Component\\Console\\Input\\ArgvInput"},{"__class__":"Symfony\\Component\\Console\\Output\\ConsoleOutput"}]},{"file":"/var/www/html/core/Command/Base.php","line":161,"function":"run","class":"Symfony\\Component\\Console\\Command\\Command","type":"->","args":[{"__class__":"Symfony\\Component\\Console\\Input\\ArgvInput"},{"__class__":"Symfony\\Component\\Console\\Output\\ConsoleOutput"}]},{"file":"/var/www/html/3rdparty/symfony/console/Application.php","line":1078,"function":"run","class":"OC\\Core\\Command\\Base","type":"->","args":[{"__class__":"Symfony\\Component\\Console\\Input\\ArgvInput"},{"__class__":"Symfony\\Component\\Console\\Output\\ConsoleOutput"}]},{"file":"/var/www/html/3rdparty/symfony/console/Application.php","line":324,"function":"doRunCommand","class":"Symfony\\Component\\Console\\Application","type":"->","args":[{"__class__":"OCA\\Files\\Command\\Scan"},{"__class__":"Symfony\\Component\\Console\\Input\\ArgvInput"},{"__class__":"Symfony\\Component\\Console\\Output\\ConsoleOutput"}]},{"file":"/var/www/html/3rdparty/symfony/console/Application.php","line":175,"function":"doRun","class":"Symfony\\Component\\Console\\Application","type":"->","args":[{"__class__":"Symfony\\Component\\Console\\Input\\ArgvInput"},{"__class__":"Symfony\\Component\\Console\\Output\\ConsoleOutput"}]},{"file":"/var/www/html/lib/private/Console/Application.php","line":183,"function":"run","class":"Symfony\\Component\\Console\\Application","type":"->","args":[{"__class__":"Symfony\\Component\\Console\\Input\\ArgvInput"},{"__class__":"Symfony\\Component\\Console\\Output\\ConsoleOutput"}]},{"file":"/var/www/html/console.php","line":87,"function":"run","class":"OC\\Console\\Application","type":"->","args":[{"__class__":"Symfony\\Component\\Console\\Input\\ArgvInput"}]},{"file":"/var/www/html/occ","line":11,"args":["/var/www/html/console.php"],"function":"require_once"}],"File":"/var/www/html/lib/private/DB/Connection.php","Line":838,"message":"Transaction took 5024.1708259583s","exception":{},"timeSpent":5024.170825958252,"CustomMessage":"Transaction took 5024.1708259583s"}}
Cleaned up my Reverse proxy config
# /etc/apache2/sites-enabled/cloud.example.com-le-ssl.conf
<IfModule mod_ssl.c>
<VirtualHost *:443>
    ServerAdmin email@example.com
    ServerName cloud.example.com
    SSLEngine On
    SSLCertificateFile /etc/letsencrypt/live/cloud.example.com/fullchain.pem
    SSLCertificateKeyFile /etc/letsencrypt/live/cloud.example.com/privkey.pem
    ProxyPass / http://127.0.0.1:8083/
    ProxyPassReverse / http://127.0.0.1:8083/
    ProxyPreserveHost On
    ProxyPassReverseCookieDomain 127.0.0.1 cloud.example.com
    RequestHeader set X-Forwarded-Proto "https"
    RequestHeader set X-Forwarded-Ssl on
    ErrorLog /srv/logs/error/cloud.example.com.log
    CustomLog /srv/logs/access/cloud.example.com.log combined
    RewriteEngine On
    RewriteRule ^/\.well-known/carddav https://%{SERVER_NAME}/remote.php/dav/ [R=301,L]
    RewriteRule ^/\.well-known/caldav https://%{SERVER_NAME}/remote.php/dav/ [R=301,L]
    <IfModule mod_headers.c>
    Header always set Strict-Transport-Security "max-age=15552000; includeSubDomains; preload"
    </IfModule>
</VirtualHost>
</IfModule>
<VirtualHost *:80>
    ServerAdmin julien.gasbayet@gmail.com
    Redirect permanent / https://cloud.example.com/
</VirtualHost>
</IfModule>
and the subsequent NC config
        "htaccess.RewriteBase": "\/",
        "apps_paths": [
                "url": "\/apps",
                "writable": false
                "url": "\/custom_apps",
                "writable": true
        "upgrade.disable-web": false,
        "overwrite.cli.url": "https:\/\/cloud.example.com",
        "overwriteprotocol": "https",
        "forwarded_for_headers": [
            "X-Forwarded-For",
            "HTTP_X_FORWARDED_FOR"
            "cloud.example.com"
        "trusted_proxies": [
            "127.0.0.1",
            "172.22.0.1"
        "dbtype": "mysql",
        "version": "30.0.5.1",
        "dbtableprefix": "",
        "dbport": "",
        "mysql.utf8mb4": true,
        "updater.secret": "***REMOVED SENSITIVE VALUE***",
        "loglevel": 0,
        "mail_smtpmode": "smtp",
        "mail_smtpport": "465",
        "mail_smtpsecure": "ssl",
        "mail_smtpauthtype": "LOGIN",
        "mail_smtpauth": 1,
        "theme": "",
        "default_phone_region": "ISO 3166-2:FR",
        "filelocking.enabled": true,
        "redis": {
            "port": 0
        "log_rotate_size": 10000000,
        "app_install_overwrite": [
            "maps"
        "data-fingerprint": "5b0aa8fd17e9acc9cf681077be6da67a"
But I’ve still a super slow instance. :sob:
I’ve run several NC occ commands:
docker exec -u www-data nextcloud-app php occ files:repair-tree
# and also:
files:cleanup
maintenance:repair
files:scan-app-data
db:add-missing-indices
db:add-missing-columns
db:add-missing-primary-keys
maintenance:mimetype:update-db --repair-filecache
But nothing solves the main issue that is that the instance is engulfing all my CPU and when trying to sync my files and does it unusably slowly.
I dont understand what you mean by “terminating TLS on your app container too and have overridden the distributed Apache config”. Can you clarify?
In your cloud-app container (running the nextcloud image) you have your SSL and LE config injected into the container. Aren’t those configs purely for your reverse proxy (which is not hosted in the cloud-app container)?
It almost looks like you’re trying to use the Apache that is embedded in the nextcloud image as your reverse proxy for itself. That’s the part that isn’t adding up. (Though given the rest of the Compose config that part can’t really be functioning fully).
The above from your posted logs suggest you have a manually ran occ files:scan. That may just be a red herring since I guess you may have just ran that while trying to figure out what’s going on. But if you do have a schedule job running that command regularly, that will likely exasperate whatever is going on at the moment.
Based on the fact you still have this line, I suspect your NC container is generating some warnings when it starts (see here) because the above value should not exist in an up-to-date installation (the built-in Updater can’t be used with the image since the image handles updates on its own).
Can you check the underlying host for other problems? i.e. check kernel messages via journalctl -a and dmesg and poking around in /var/log?
Also, any chance you can you shut off your sync clients (i.e. desktop client) and similar to try to eliminate some variables?
I indeed had a warning in the admin overview panel about the mariaDB version. I fell back to the 11.4 version. No warning anymore.
Did you do a dump and restore or just change the version tag?
Let’s also back up a moment and go back over what you did / what has changed since this all started (since it may turn up something we’re overlooking here):
I upgraded from v27 to v30 with Docker, upgrading one version after the other. Now the server is super slow. Unusably slow.
Presumably things were fine at v27. Okay, so you just upgraded to v28 by doing what? (bumping the image version tag then doing a docker compose pull and docker compose up -d? Or something else) And then same for v29 and v30 I presume?
About Reverse proxy
You were right those volumes connections were odd. I removed them, they appeared to be useless and probably a linger from the past.
About the scan output
I figured. Indeed I ran a scan trying to figure things out. Restarting things and clearing cache put it back in tracks but the server was still eating up CPU trying to sync.
underlyin host logs?
Nothing stands out honestly. Syslog is essentially warning me about the nextcloud cron task executing every 5 minutes and that’s pretty much it.
sync clients
I actually did not think of that. I disconnected the app and other things on the phone and local desktop client. Some minor debug alerts where clearly coming from them.
how I updated
I indeed upgraded to the +1 version and running docker compose again. Checking if it worked, then doing it again. Until I reached v30.
I had some indices to fix and ran some database commands to fix it.
next up
I did a test by backing up the files and running a fresh “empty” instance with all the same config and setup. It worked like a charm. It’s definetly the database of the current install that’s flipped up.
But I must have broken something or I don’t know. I’ve been on this thing for 3 days straight. I can’t spend more time on it. I’m a bit sad that NC broke on me like that :frowning:
I’ve pulled my files, my important data like contacts, agenda and I’m rebuilding an instance. My files are syncing now to reupload them. Lightning fast as normally expected and upload is fast. Writing is averaging 16mo/s when it struggled to register a single file before.
I’m sad I did not get to understand the issue though.
Thanks a bunch for you guidance :raised_hands::heart_hands:
At least it was an opportunity to clarify my reverse proxy setup thanks to your remarks.
