I have installed nextant, configured it, installed solr and nextanr has also indexed all my files fine. I can search in solr my index and it shows back hits,
But when I try to enter a word into the search in nextcloud, it seems to search just in the Filenames. What am I missing?
The search functios is like it isn#t installed, but I can see it in the admin panel.Or am I entering the search in the wrong field?
Any hint is appreciated.
There is nothing in teh logs of nextcloud or solr, which gave me a hint , what is going wrong.
It shows 744 extracted documents in the admin interface!
I can searcg in solr with querys in the documents.
But nextant is ignored, when I search in the cloud
in the Admin Interface, please change the option Display Result to Nextant Style
This option will be removed next major release (0.10.0), as nextant will be fully integrated to the Files App (using its extension FileList). Meaning that all options from the Files App will be available in the search result - select multiple files, download as zip, moving files around, favorites, âŠ
The file link mentioned here is a valid search result and is visible in the cloud
In Firefox it looks like this
Strict-Transport-Security: Die Website gab eine Kopfzeile an, die nicht erfolgreich verarbeitet werden konnte.[Weitere Informationen]search
TypeError: $e.data(âŠ) is undefined
filterRows()
filelist.js:2396
_.forEach()
underscore.js:153
FileList.prototype.setFilter()
filelist.js:2406
Files.prototype.attach/<()
search.js:170
Search.prototype.initialize/<()
search.js:331
n.event.dispatch()
jquery.min.js:3
n.event.add/r.handle()
jquery.min.js:3
I really appreciate your help and I am looking forward to get your wonderfull app running, which will really enhance the experience of my users. I have no doubt!
Another issue with your app at my side is -this might be related- is, that I do not get a filelist anymore, when I open a second nextcloud tab while the first one is still open.
Afterwards, even after logout, I see no filelist in the file app.
The only way then to get the file list back is by cleaning the browser cache, or disable the nextant app
Tested on Chrome and Firefox
No Javascript errors any more, but still no search results.
I put a breakpoint in the code area in the javascript debugger, which I believe where the searching starts, but its code seems not to be calledâŠ
I send you via private mail a link to my nextcloud
