Help with "Let's Encrypt" renewal failure on 30.0.2 snap
    • 30.0.2snap2
    • Ubuntu 24.04
    • Yes
    • When Let's Encrypt certificates tried to renew within the last few weeks
    • snap
Let’s Encrypt fails to renew. It has been working fine for the last year. I’m not sure how to proceed here. Try to renew manually? Since Nextcloud itself is working fine, I’d like to make sure I do this correctly. Here is some of the log:
2024-12-15T22:17:07-05:00 nextcloud.renew-certs[1699955]: Cleaning up challenges
2024-12-15T22:17:07-05:00 nextcloud.renew-certs[1699955]: Attempting to renew cert (yumhouse.ddns.net-0001) from /var/snap/nextcloud/current/certs/certbot/config/renewal/yumhouse.ddns.net-0001.conf produced an unexpected error: Missing command line flag or config entry for this setting:
2024-12-15T22:17:07-05:00 nextcloud.renew-certs[1699955]: Input the webroot for yumhouse.ddns.net:. Skipping.
2024-12-15T22:17:07-05:00 nextcloud.renew-certs[1699955]: - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -
2024-12-15T22:17:07-05:00 nextcloud.renew-certs[1699955]: Processing
2024-12-15T22:17:07-05:00 nextcloud.renew-certs[1699955]: /var/snap/nextcloud/current/certs/certbot/config/renewal/yumhouse.ddns.net.conf
2024-12-15T22:17:08-05:00 nextcloud.renew-certs[1699955]: Cert is due for renewal, auto-renewing...
2024-12-15T22:17:08-05:00 nextcloud.renew-certs[1699955]: Plugins selected: Authenticator webroot, Installer None
2024-12-15T22:17:08-05:00 nextcloud.renew-certs[1699955]: Renewing an existing certificate
2024-12-15T22:17:09-05:00 nextcloud.renew-certs[1699955]: Performing the following challenges:
2024-12-15T22:17:09-05:00 nextcloud.renew-certs[1699955]: http-01 challenge for yumhouse.ddns.net
2024-12-15T22:17:09-05:00 nextcloud.renew-certs[1699955]: http-01 challenge for yumhouse.no-ip.org
2024-12-15T22:17:09-05:00 nextcloud.renew-certs[1699955]: Cleaning up challenges
2024-12-15T22:17:09-05:00 nextcloud.renew-certs[1699955]: Attempting to renew cert (yumhouse.ddns.net) from /var/snap/nextcloud/current/certs/certbot/config/renewal/yumhouse.ddns.net.conf produced an unexpected error: Missing command line flag or config entry for this setting:
2024-12-15T22:17:09-05:00 nextcloud.renew-certs[1699955]: Input the webroot for yumhouse.ddns.net:. Skipping.
2024-12-15T22:17:09-05:00 nextcloud.renew-certs[1699955]: - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -
2024-12-15T22:17:09-05:00 nextcloud.renew-certs[1699955]: Processing
2024-12-15T22:17:09-05:00 nextcloud.renew-certs[1699955]: /var/snap/nextcloud/current/certs/certbot/config/renewal/yumhouse.no-ip.org.conf
2024-12-15T22:17:09-05:00 nextcloud.renew-certs[1699955]: Cert is due for renewal, auto-renewing...
2024-12-15T22:17:09-05:00 nextcloud.renew-certs[1699955]: Plugins selected: Authenticator webroot, Installer None
2024-12-15T22:17:10-05:00 nextcloud.renew-certs[1699955]: Renewing an existing certificate
2024-12-15T22:17:10-05:00 nextcloud.renew-certs[1699955]: Performing the following challenges:
2024-12-15T22:17:10-05:00 nextcloud.renew-certs[1699955]: http-01 challenge for yumhouse.no-ip.org
2024-12-15T22:17:10-05:00 nextcloud.renew-certs[1699955]: Cleaning up challenges
2024-12-15T22:17:10-05:00 nextcloud.renew-certs[1699955]: Attempting to renew cert (yumhouse.no-ip.org) from /var/snap/nextcloud/current/certs/certbot/config/renewal/yumhouse.no-ip.org.conf produced an unexpected error: Missing command line flag or config entry for this setting:
2024-12-15T22:17:10-05:00 nextcloud.renew-certs[1699955]: Input the webroot for yumhouse.no-ip.org:. Skipping.
2024-12-15T22:17:10-05:00 nextcloud.renew-certs[1699955]: All renewal attempts failed. The following certs could not be renewed:
2024-12-15T22:17:10-05:00 nextcloud.renew-certs[1699955]:   /var/snap/nextcloud/current/certs/certbot/config/live/yumhouse.ddns.net-0001/fullchain.pem (failure)
2024-12-15T22:17:10-05:00 nextcloud.renew-certs[1699955]:   /var/snap/nextcloud/current/certs/certbot/config/live/yumhouse.ddns.net/fullchain.pem (failure)
2024-12-15T22:17:10-05:00 nextcloud.renew-certs[1699955]:   /var/snap/nextcloud/current/certs/certbot/config/live/yumhouse.no-ip.org/fullchain.pem (failure)
2024-12-15T22:17:10-05:00 nextcloud.renew-certs[1699955]: - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -
2024-12-15T22:17:10-05:00 nextcloud.renew-certs[1699955]: Running post-hook command: restart-apache
2024-12-15T22:17:11-05:00 nextcloud.renew-certs[1699955]: Output from post-hook command restart-apache:
2024-12-15T22:17:11-05:00 nextcloud.renew-certs[1699955]: Restarting apache... done
2024-12-15T22:17:11-05:00 nextcloud.renew-certs[1699955]: 3 renew failure(s), 0 parse failure(s)
2024-12-16T14:12:08-05:00 systemd[1]: Stopping snap.nextcloud.renew-certs.service - Service for snap application nextcloud.renew-certs...
2024-12-16T14:12:08-05:00 systemd[1]: snap.nextcloud.renew-certs.service: Deactivated successfully.
2024-12-16T14:12:08-05:00 systemd[1]: Stopped snap.nextcloud.renew-certs.service - Service for snap application nextcloud.renew-certs.
2024-12-16T14:12:08-05:00 systemd[1]: snap.nextcloud.renew-certs.service: Consumed 35.515s CPU time, 69.5M memory peak, 172.0K memory swap peak.
2024-12-16T14:13:50-05:00 systemd[1]: Started snap.nextcloud.renew-certs.service - Service for snap application nextcloud.renew-certs.
2024-12-16T14:13:55-05:00 nextcloud.renew-certs[2500]: Saving debug log to /var/snap/nextcloud/current/certs/certbot/logs/letsencrypt.log
2024-12-16T14:13:55-05:00 nextcloud.renew-certs[2500]: - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -
2024-12-16T14:13:55-05:00 nextcloud.renew-certs[2500]: Processing
2024-12-16T14:13:55-05:00 nextcloud.renew-certs[2500]: /var/snap/nextcloud/current/certs/certbot/config/renewal/yumhouse.ddns.net-0001.conf
2024-12-16T14:13:55-05:00 nextcloud.renew-certs[2500]: Cert is due for renewal, auto-renewing...
2024-12-16T14:13:55-05:00 nextcloud.renew-certs[2500]: Non-interactive renewal: random delay of 281 seconds
2024-12-16T14:18:36-05:00 nextcloud.renew-certs[2500]: Plugins selected: Authenticator webroot, Installer None
2024-12-16T14:18:36-05:00 nextcloud.renew-certs[2500]: Renewing an existing certificate
2024-12-16T14:18:38-05:00 nextcloud.renew-certs[2500]: Performing the following challenges:
2024-12-16T14:18:38-05:00 nextcloud.renew-certs[2500]: http-01 challenge for yumhouse.ddns.net
2024-12-16T14:18:38-05:00 nextcloud.renew-certs[2500]: Cleaning up challenges
2024-12-16T14:18:38-05:00 nextcloud.renew-certs[2500]: Attempting to renew cert (yumhouse.ddns.net-0001) from /var/snap/nextcloud/current/certs/certbot/config/renewal/yumhouse.ddns.net-0001.conf produced an unexpected error: Missing command line flag or config entry for this setting:
2024-12-16T14:18:38-05:00 nextcloud.renew-certs[2500]: Input the webroot for yumhouse.ddns.net:. Skipping.
2024-12-16T14:18:38-05:00 nextcloud.renew-certs[2500]: - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -
2024-12-16T14:18:38-05:00 nextcloud.renew-certs[2500]: Processing
2024-12-16T14:18:38-05:00 nextcloud.renew-certs[2500]: /var/snap/nextcloud/current/certs/certbot/config/renewal/yumhouse.ddns.net.conf
2024-12-16T14:18:38-05:00 nextcloud.renew-certs[2500]: Cert is due for renewal, auto-renewing...
2024-12-16T14:18:38-05:00 nextcloud.renew-certs[2500]: Plugins selected: Authenticator webroot, Installer None
2024-12-16T14:18:38-05:00 nextcloud.renew-certs[2500]: Renewing an existing certificate
2024-12-16T14:18:39-05:00 nextcloud.renew-certs[2500]: Performing the following challenges:
2024-12-16T14:18:39-05:00 nextcloud.renew-certs[2500]: http-01 challenge for yumhouse.ddns.net
2024-12-16T14:18:39-05:00 nextcloud.renew-certs[2500]: http-01 challenge for yumhouse.no-ip.org
2024-12-16T14:18:39-05:00 nextcloud.renew-certs[2500]: Cleaning up challenges
2024-12-16T14:18:39-05:00 nextcloud.renew-certs[2500]: Attempting to renew cert (yumhouse.ddns.net) from /var/snap/nextcloud/current/certs/certbot/config/renewal/yumhouse.ddns.net.conf produced an unexpected error: Missing command line flag or config entry for this setting:
2024-12-16T14:18:39-05:00 nextcloud.renew-certs[2500]: Input the webroot for yumhouse.ddns.net:. Skipping.
2024-12-16T14:18:39-05:00 nextcloud.renew-certs[2500]: - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -
2024-12-16T14:18:39-05:00 nextcloud.renew-certs[2500]: Processing
2024-12-16T14:18:39-05:00 nextcloud.renew-certs[2500]: /var/snap/nextcloud/current/certs/certbot/config/renewal/yumhouse.no-ip.org.conf
2024-12-16T14:18:39-05:00 nextcloud.renew-certs[2500]: Cert is due for renewal, auto-renewing...
2024-12-16T14:18:39-05:00 nextcloud.renew-certs[2500]: Plugins selected: Authenticator webroot, Installer None
2024-12-16T14:18:39-05:00 nextcloud.renew-certs[2500]: Renewing an existing certificate
2024-12-16T14:18:40-05:00 nextcloud.renew-certs[2500]: Performing the following challenges:
2024-12-16T14:18:40-05:00 nextcloud.renew-certs[2500]: http-01 challenge for yumhouse.no-ip.org
2024-12-16T14:18:40-05:00 nextcloud.renew-certs[2500]: Cleaning up challenges
2024-12-16T14:18:40-05:00 nextcloud.renew-certs[2500]: Attempting to renew cert (yumhouse.no-ip.org) from /var/snap/nextcloud/current/certs/certbot/config/renewal/yumhouse.no-ip.org.conf produced an unexpected error: Missing command line flag or config entry for this setting:
2024-12-16T14:18:40-05:00 nextcloud.renew-certs[2500]: Input the webroot for yumhouse.no-ip.org:. Skipping.
2024-12-16T14:18:40-05:00 nextcloud.renew-certs[2500]: All renewal attempts failed. The following certs could not be renewed:
2024-12-16T14:18:40-05:00 nextcloud.renew-certs[2500]:   /var/snap/nextcloud/current/certs/certbot/config/live/yumhouse.ddns.net-0001/fullchain.pem (failure)
2024-12-16T14:18:40-05:00 nextcloud.renew-certs[2500]:   /var/snap/nextcloud/current/certs/certbot/config/live/yumhouse.ddns.net/fullchain.pem (failure)
2024-12-16T14:18:40-05:00 nextcloud.renew-certs[2500]:   /var/snap/nextcloud/current/certs/certbot/config/live/yumhouse.no-ip.org/fullchain.pem (failure)
2024-12-16T14:18:40-05:00 nextcloud.renew-certs[2500]: - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -
2024-12-16T14:18:40-05:00 nextcloud.renew-certs[2500]: Running post-hook command: restart-apache
2024-12-16T14:18:41-05:00 nextcloud.renew-certs[2500]: Output from post-hook command restart-apache:
2024-12-16T14:18:41-05:00 nextcloud.renew-certs[2500]: Restarting apache... done
2024-12-16T14:18:41-05:00 nextcloud.renew-certs[2500]: 3 renew failure(s), 0 parse failure(s)
Nothing recent in the log
        "apps_paths": [
                "path": "\/snap\/nextcloud\/current\/htdocs\/apps",
                "url": "\/apps",
                "writable": false
                "path": "\/var\/snap\/nextcloud\/current\/nextcloud\/extra-apps",
                "url": "\/extra-apps",
                "writable": true
        "supportedDatabases": [
            "mysql"
        "redis": {
            "port": 0
        "log_type": "file",
        "logfile": "\/var\/snap\/nextcloud\/current\/logs\/nextcloud.log",
        "logfilemode": 416,
            "localhost",
            "192.168.0.143",
            "yumhouse.ddns.net",
            "yumhouse.no-ip.org"
        "dbtype": "mysql",
        "version": "30.0.2.2",
        "overwrite.cli.url": "http:\/\/localhost",
        "dbport": "",
        "mysql.utf8mb4": true,
        "mail_smtpmode": "smtp",
        "mail_sendmailmode": "smtp",
        "mail_smtpport": "587",
        "mail_smtpauth": 1,
        "default_phone_region": "US",
        "twofactor_enforced": "true",
        "twofactor_enforced_groups": [],
        "loglevel": 2,
        "maintenance_window_start": 1
@The9Cat welcome back
see Nextcloud snap wiki
have a look at Managing encryption especially this topic Managing HTTP encryption (HTTPS) · nextcloud-snap/nextcloud-snap Wiki · GitHub
I had been wondering whether there was another solution besides wiping out the Let's Encrypt certificates and starting again.
Anyway, I did follow the recipe in the snap wiki, which is equivalent to starting again, and it’s working. So maybe that is the best. So thanks for that info!
yeah Lets Encrypt from scratch is a good choice…
glad to hear its working again
I might also add: the Nextcloud snap is generally awesome despite the occasional Let's Encrypt issues.
