I have Nextcloud 21.0.3 running on a Synology DS218+ using Web Station, PHP 7.4.9-0006 and MariaDB 10.3.24-0069. I have a folder setup on the External Storage app and I gave access to my user and the admin user. The folder shows up on the Files app but when I try to access it I get the error “This operation is forbidden” and in the logs I get this:
[webdav] Fatal: OCA\DAV\Connector\Sabre\Exception\Forbidden: No read permissions at <<closure>>
0. /volume1/web/nextcloud/apps/dav/lib/Connector/Sabre/CommentPropertiesPlugin.php line 72
OCA\DAV\Connector\Sabre\Directory->getChildren()
1. /volume1/web/nextcloud/apps/dav/lib/Connector/Sabre/CommentPropertiesPlugin.php line 117
OCA\DAV\Connector\Sabre\CommentPropertiesPlugin->cacheDirectory(OCA\DAV\Connector\Sabre\Directory {})
2. /volume1/web/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php line 89
OCA\DAV\Connector\Sabre\CommentPropertiesPlugin->handleGetProperties(Sabre\DAV\PropFind {}, OCA\DAV\Connector\Sabre\Directory {})
3. /volume1/web/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php line 1052
Sabre\DAV\Server->emit("propFind", [Sabre\DAV\PropF ... }])
4. /volume1/web/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php line 984
Sabre\DAV\Server->getPropertiesByNode(Sabre\DAV\PropFind {}, OCA\DAV\Connector\Sabre\Directory {})
5. /volume1/web/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php line 1661
Sabre\DAV\Server->getPropertiesIteratorForPath("files/6r6w6/Documents", ["{DAV:}getlastm ... "], 1)
6. /volume1/web/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php line 1646
Sabre\DAV\Server->writeMultiStatus(Sabre\Xml\Writer ... ]}, Generator {}, false)
7. /volume1/web/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php line 346
Sabre\DAV\Server->generateMultiStatus(Generator {}, false)
8. /volume1/web/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php line 89
Sabre\DAV\CorePlugin->httpPropFind(Sabre\HTTP\Request {}, Sabre\HTTP\Response {})
9. /volume1/web/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php line 472
Sabre\DAV\Server->emit("method:PROPFIND", [Sabre\HTTP\Requ ... }])
10. /volume1/web/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php line 253
Sabre\DAV\Server->invokeMethod(Sabre\HTTP\Request {}, Sabre\HTTP\Response {})
11. /volume1/web/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php line 321
Sabre\DAV\Server->start()
12. /volume1/web/nextcloud/apps/dav/lib/Server.php line 332
Sabre\DAV\Server->exec()
13. /volume1/web/nextcloud/apps/dav/appinfo/v2/remote.php line 35
OCA\DAV\Server->exec()
14. /volume1/web/nextcloud/remote.php line 167
require_once("/volume1/web/ne ... p")
PROPFIND /nextcloud/remote.php/dav/files/6r6w6/Documents
