Help with basic Calendar settings
Probably a noob question, but here goes:
I can’t even get past this in the documentation:
iOS - Synchronize iPhone/iPad Calendar
  1. Open the settings application.
  2. Select Mail, Contacts, Calendars.
First off, there are many places where there are “settings.” I’ve clicked all of them. And I don’t see any setting entitled “Mail, Contacts, Calendars”
I DO have calendars installed - in fact, I have some read-only calendar subscriptions working. But I’d like full functionality!
Steve
So choose Settings->Accounts&Passwords->Add Account->other
There is CardDAV and CaldDAV
:slight_smile:
I don’t see that either.
Under Settings, there are Personal and Administration.
Under Settings->Personal there are Personal info, Security, Sync clients, Sharing, and Additional Settings
Under Settings->Administration there are Basic settings, Monitoring, Sharing, Security, Theming, Encryption, Activity, Workflow, Usage survey, Logging, Additional settings, Tips & tricks.
:frowning:
Here is an example.
https://userforum-en.mailbox.org/knowledge-base/article/caldav-carddav-ios
Ah, those are settings for the iOS app, not for Nextcloud!
Next issue: getting the CalDAV to be recognized.
I have Nextcloud on a Raspberry Pi, and I’m using port 8443 for SSL with a locally signed certificate only. I connect to Nextcloud using SSL without a problem, but iOS CalDAV can’t seem to make it happen.
I’m using: example.com:8443/remote.php/dav/principals/users/MYUSERNAMEINCAPS/
First error is “can’t use SSL.” I’ve tried Advanced Settings, and tried both enabling SSL, as well as disabling and changing the port to 8080 (though per Nextcloud security I have a force on the server side to use SSL).
Any hints?
i heard that iOS-client(s) could turn out to be very picky about ssl-certificates.
