I’m having difficulties using Nextcloud AIO docker, using MacOS Catalina and Docker Desktop. First time I’m trying to use it.
According to the project page (GitHub - nextcloud/all-in-one: Nextcloud AIO stands for Nextcloud All In One and provides easy deployment and maintenance with most features included in this one Nextcloud instance.), I am to pull the AIO docker, and use the following script to load it:
sudo docker run -it \
--name nextcloud-aio-mastercontainer \
--restart always \
-p 80:80 \
-p 8080:8080 \
-p 8443:8443 \
--volume nextcloud_aio_mastercontainer:/mnt/docker-aio-config \
--volume /var/run/docker.sock:/var/run/docker.sock:ro \
nextcloud/all-in-one:latest
Problem seems to be that Docker reports back: “Docker socket is not avilable. Cannot continue”.
Looking at Docker, the AIO docker is loaded but not started. Unable to start. If I start, it stops/exists immediatly and I get the same error message from Docker.
Searching for solutions on DuckDuckGo yields about 5 hits, none of the applicable to this problem. I am not sure where to turn for help or suggestions, other than perhaps if Docker has a forum - which I will check next.
If anyone have any ideas of what causes this problem and how it can be resolved, I’d be grateful. Any suggestions welcome.
Thank you in advance
/A
