Help testing 13.0.1 RC 1, 12.0.6 RC 1, 11.0.8 RC 1
We just packaged the RC 1 version of all maintenance releases that are planned for the next week. As always you can either download them directly from prerelease folder on the download server: https://download.nextcloud.com/server/prereleases/ or you use the beta channel of the built-in updater and use that.
As always: have an backup available and keep rocking :rocket:
The changelog of those releases can be found here:
13.0.1: https://github.com/nextcloud/server/pull/8748
12.0.6: https://github.com/nextcloud/server/pull/8750
11.0.8: https://github.com/nextcloud/server/pull/8751
If you find bugs report them in our bug tracker: https://github.com/nextcloud/server/issues and if it is a bug that is related to the update itself you can get at least a Nextcloud t-shirt. :wink: (@jospoortvliet knows more on this one)
Thanks for this. But hmm, I don’t see an update with beta channel active. Is it rolled out in waves as well? Daily channel just offers an outdated February build.
Same problem here. No 13.0.1 offered.
I installed it via the “daily” option. You will get some scary characters, but it should install 13.0.1
I just changed to the ‘daily’ update channel and was offered only this
update:
Nextcloud 13.0.0 Build:2018-02-06T00:39:26+00:00
No sign of 13.0.1 being available anywhere for me :frowning:
you will get 13.0.1 anyway even that text states different
We just noticed that it wasn’t deployed to the updater server yet. It should be available now. To enforce a refresh of the latest state just change from the current channel to a different one and back to beta. Then you should get the update notification for the RC1.
Successfully updated now to Nextcloud 13.0.1 RC 1
Thanks guys!
Jep, everything went fine now, many thanks :+1:!
