Help testing 12.0.7 RC1 & 13.0.2 RC1
we just packaged the RCs for our next maintenance releases. They will be available via the “beta” updater channel soon.
The planned release for those versions is next Thursday.
As always - have an backup available and happy testing :rocket:
Download it from the prerelease folder: https://download.nextcloud.com/server/prereleases/
Changelogs
12.0.7 RC1
13.0.2 RC1
The update went smoothly without errors. Anything special to look at?
Just check if the use cases you use work fine. :slight_smile:
Hi
Sorry gave limited info;
The install went well, I am using a reverse proxy setup under IIS7 due to using port 443 for another test currently and nextcloud is run from a pre-installed VM all of which resolve externally without a problem. All other links on each page work without error except when logging out…
The use case was fine nothing out of the ordinary.
Is a strange one for sure…, will try out the RC when it’s released to see if this addresses the problem
Thanks
Marco
And obviously I forgot to write where it could be downloaded - from our prerelease folder: https://download.nextcloud.com/server/prereleases/
The automatic web updater worked just fine, never needed the download location.
the web update worked great here :wink:
Debian stretch
Installation nextcloud 13.0.2 RC1
restore config.php
  'instanceid' => '',
  'passwordsalt' => '',
  'secret' => '',
    0 => 'wolke.systron.de',
    1 => '10.0.0.10',
  'datadirectory' => '/data',
  'dbtype' => 'pgsql',
  'version' => '',
  'dbname' => 'nextcloud',
  'dbhost' => 'db.systron.de',
  'dbport' => '5432',
  'dbuser' => 'nextcloud',
  'dbpassword' => 'passwort',
  'installed' => false,
  'default_language' => 'de',
  'force_language' => 'de',
  'memcache.local' => '\OC\Memcache\Redis',
  'redis' => array(
       'host' => '/var/run/redis/redis.sock',
       'port' => 0,
  'memcache.locking' => '\OC\Memcache\Redis',
  'mail_from_address' => 'root',
  'mail_smtpmode' => 'php',
  'mail_smtpauthtype' => 'PLAIN',
  'theme' => '',
  'loglevel' => 0,
restart apache
Technische Details
    Entfernte Adresse: 10.0.0.251
    Anfragekennung: FpwJymP8CLRDK6h790d0
/data/nextcloud.log:
    "reqId": "FpwJymP8CLRDK6h790d0",
    "level": 3,
    "time": "2018-04-24T10:04:24+00:00",
    "remoteAddr": "10.0.0.251",
    "user": "--",
    "app": "base",
    "method": "GET",
    "url": "/index.php",
    "message": {
        "Exception": "ErrorException",
        "Message": "session_name(): session.name cannot be a numeric or empty ''",
        "Code": 0,
        "Trace": "
	        #0 [internal function]: OC\\\\Session\\\\Internal->trapError(2, 'session_name():...', '/var/www/html/n...', 175, Array)
	        #1 [internal function]: session_name('')
	        #2 lib/private/Session/Internal.php(175): call_user_func_array('session_name', Array)
	        #3 lib/private/Session/Internal.php(48): OC\\\\Session\\\\Internal->invoke('session_name', Array)
	        #4 lib/base.php(436): OC\\\\Session\\\\Internal->__construct('')
	        #5 lib/base.php(664): OC::initSession()
	        #6 lib/base.php(1081): OC::init()
	        #7 index.php(35): require_once('/var/www/html/n...')
	        #8 {main}",
        "File": "lib/private/Session/Internal.php",
        "Line": 151
    "userAgent": "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:60.0) Gecko/20100101 Firefox/60.0",
    "version": ""
For some weird reasons those values are empty in your instance. This is the cause for the failure. Those are set on installation and should not be removed.
I took the old config.php and removed the entries. It should be a
complete fresh installation.
When will this values filled?
I took values from an old config.php an now postgresql is filled.
But firefox show me a blanc side with URL:
https://nextcloud.systron.de/index.php/apps/files/
Last entry in /data/nextcloud.log:
{“reqId”:“zrkXs1ysVil4dvIE9SJU”,“level”:0,“time”:“2018-04-24T12:17:15+00:00”,“remoteAddr”:“10.0.0.251”,“user”:“rag”,“app”:“files_skeleton”,“method”:“POST”,“url”:"/index.php",“message”:“copying
skeleton for rag from /var/www/html/nextcloud/core/skeleton to
/rag/files/”,“userAgent”:“Mozilla/5.0 (X11; Ubuntu; Linux x86_64;
rv:60.0) Gecko/20100101 Firefox/60.0”,“version”:“13.0.2.0”}
And now?
If you want to reinstall, then remove those lines completely and also remove the version. Keep in mind that this is not 100% supported, but should work.
web update did not started.
You have an extra directory in there. Move it out and then it should work fine. We are on it to fix this: https://github.com/nextcloud/updater/issues/68
oh yes all went smooth after removing it was opennms files in folder for data collection.
the redis configuration part stops installation with empty firefox-window:
‘memcache.local’ => ‘\OC\Memcache\Redis’,
‘redis’ =>
‘host’ => ‘/var/run/redis/redis.sock’,
‘port’ => 0,
‘memcache.locking’ => ‘\OC\Memcache\Redis’,
Is this wrong?
Didn’t had any issu with redis only OpenNMS still can not make that work on Debian stable.
Manual upgrade from 13.0.1 to 13.0.2RC1 went fine. No errors, basic tests revealed no issues.
Debian 9.4 in LXC, Apache, PHP 7.0.27, Redis, PostgreSQL 9.6.
I was hoping that https://github.com/nextcloud/server/issues/6343 would be fixed, my db log files get a bit clogged. Fortunately I’ve just a few users, so I can manage in terms of disk space.
Nice work :+1:
Apr 25 14:33:45 wolke apache2[1131]: [:error] [pid 1131] [client 10.0.0.238:58075] PHP Fatal error: Uncaught Error: Class ‘OC_User’ not found in /var/www/html/nextcloud/lib/private/Log/File.php:104\nStack trace:\n#0 [internal function]: OC\Log\File::write(‘PHP’, ‘Redis::get(): s…’, 3)\n#1 /var/www/html/nextcloud/lib/private/Log.php(321): call_user_func(Array, ‘PHP’, ‘Redis::get(): s…’, 3)\n#2 /var/www/html/nextcloud/lib/private/Log.php(191): OC\Log->log(3, ‘Redis::get(): s…’, Array)\n#3 /var/www/html/nextcloud/lib/private/Log/ErrorHandler.php(90): OC\Log->error(‘Redis::get(): s…’, Array)\n#4 [internal function]: OC\Log\ErrorHandler::onError(8, ‘Redis::get(): s…’, ‘/var/www/html/n…’, 54, Array)\n#5 /var/www/html/nextcloud/lib/private/Memcache/Redis.php(54): Redis->get(‘af0d535e66ac22c…’)\n#6 /var/www/html/nextcloud/lib/autoloader.php(146): OC\Memcache\Redis->get(‘OC_User’)\n#7 [internal function]: OC\Autoloader->load(‘OC_User’)\n#8 /var/www/html/nextcloud/lib/private/Log/File.php(104): spl_autoload_call(‘OC_User’)\n#9 [internal function]: OC\Log\File::write(‘PHP’, ‘Uncaught Error:…’, 3)\n#10 /var/www/htm in /var/www/html/nextcloud/lib/private/Log/File.php on line 104
