Hey there!
We just packaged the RC 1 of the maintenance releases of 12.0.11 and 13.0.6
You can download them from the prerelease folder at:
- https://download.nextcloud.com/server/prereleases/nextcloud-13.0.6RC1.zip
- https://download.nextcloud.com/server/prereleases/nextcloud-12.0.11RC1.zip
Also it will show shortly up in the updater beta channel.
Happy testing
The changelog of those versions can be found here:
13.0.6 RC 1
- Add sabre plugin to allow anonymous options requests to the dav root (server#10285)
- Do scan the root storage in background scan (server#10376)
- Adding test for table schedulingobjects and fixing postgres LOB (server#10552)
- Fix transfering ownership of a share to user with same id as receiver (server#10565)
- Make file cache updates more robust (server#10581)
- Retry smb stat on timeout (server#10591)
- Use insertIfNotExists to store new mimetypes. (server#10620)
- Only warn about data lose on password reset if per-user keys are used (server#10646)
- Update the scope of the lockdownmanager (server#10682)
- Log entries that are hidden during file listing (server#10698)
- Forgotten pass fix link (server#10735)
- Fix comment style in config sample (server#10759)
- Make sure error_log() always receives a string (server#10760)
- Fix call to OC.generateUrl for caldav birthday calendar on/off (server#10761)
- Use the path_hash instead of the path to query the filecache (server#10762)
- Don’t blame random people for background email updates (server#10763)
- Resolve all group memberships properly (server#10783)
- Remove unexecutable code (server#10816)
- Improve URL detection (server#10821)
- MySQL 8.0+ and MariaDB 10.3+ are large prefix and barracuda by default (server#10823)
