Hi everyone,
we just packaged the RC versions of the upcoming maintenance releases.
You can find them at
- https://download.nextcloud.com/server/prereleases/nextcloud-12.0.10RC1.zip
- https://download.nextcloud.com/server/prereleases/nextcloud-13.0.5RC2.zip
They will also soon show up in the beta channel of the updater.
The changelog for those releases looks like this:
13.0.5 RC 2
13.0.5 RC 1
- Fix highlighting of the upload drop zone (server#9837)
- Apply ldapUserFilter on members of group (server#9839)
- Make the DELETION of groups match greedy on the groupID (server#9841)
- Add parent index to share table (server#9843)
- Remove unused config option (server#9844)
- Log full exception in cron instead of only the message (server#9958)
- Properly lock the target file on dav upload when not using part files (server#9986)
- LDAP backup server should not be queried when auth fails (server#10032)
- Fix filenames in sharing integration tests (server#10044)
- Lower log level for quota manipulation cases (server#10076)
- Let user set avatar in nextcloud if LDAP provides invalid image data (server#10089)
- Improved logging of smb connection errors (server#10093)
- Allow admin to disable fetching of avatars as well as a specific attribute (server#10115)
- Allow to disable encryption (server#10121)
- Update message shown when unsharing a file (server#10164)
- Fixed English grammatical error on Settings page. (server#10165)
- Request a valid property for DAV opendir (server#10169)
- Allow updating the token on session regeneration (server#10170)
- Prevent lock values from going negative with memcache backend (server#10180)
- Correctly handle users with numeric user ids (server#10185)
- Correctly parse the subject parameters for link (un)shares of calendars (server#10188)
- Fix “parsing” of email-addresses in comments and chat messages (server#10189)
- Sanitize parameters in createSessionToken() while logging (server#10195)
- Also retry rename operation on InvalidArgumentException (server#10201)
- Improve url detection in comments (server#10202)
- Use download manager from PDF.js to download the file (files_pdfviewer#84)
- Fix trying to load removed scripts (files_pdfviewer#87)
- Only pull for new messages if the session is allowed to be kept alive (notifications#138)
- Always push object data (notifications#139)
- Add prioritization for Talk (notifications#140)
12.0.10 RC 1
- Make the DELETION of groups match greedy on the groupID (server#9842)
- Sanitize parameters in createSessionToken() while logging (server#10196)
- Fix trying to load removed scripts (files_pdfviewer#88)
Happy testing!
