RC2 of our desktop client has the following changes compared to the first RC:
- desktop#2505 Status
feature - desktop#2967 Add
missing error handling for downloads of client side encryption - desktop#2976 Split
content of User::isValueableActivity() - desktop#2981 Refresh
Windows download dialog progress when hydrating a placeholder - desktop#2989 Display
the content of the login dialog correct - desktop#2990 Fix
crash when trying to open the folder creation dialog - desktop#2995 Repair
basic auth support - desktop#2998 Fix
incorrect type when reading the ālogExpireā property from config. - desktop#2999 Donāt
customize settings dialog palette - desktop#3009 Donāt
check against product name if checking server version - desktop#3010 CFAPI:
Handle cancelation of hydration requests - desktop#3016 Fix for
Windows CreateFile long path - desktop#3020
Increase logging around file removal events - desktop#3025 Enable
high dpi scaling on all platforms - desktop#3028 Check
reading from journal was successful before remove placeholder - desktop#3029 L10n:
Change sync message
Yes, that means a minor feature was added - showing the status of the user in the UI. Give this a test, how does it look with your favorite status?
There is also a known issue with the virtual drive/replacement files:
on Windows, on a newly created syncing folder with VFS enabled, you might see the error āError writing the metadata do the databaseā.
We donāt know yet what causes it and weāre debugging it. If you experience any other errors, please, let us know, that is the only way we can be sure everything works not only on our internal testing but also in real life, on your servers!
Get it here:
