I have my nextcloud server running to save some photos on it.
So far its a simple setup with docker-compose.
I have all my containers running behing Traefik2 reverse proxy and the Nextcloud image with apache2 and I have the following code for that container:
Nextcloud:
container_name: Nextcloud
image: nextcloud
restart: unless-stopped
network_mode: bridge
environment:
- PUID=99
- PGID=100
ports:
- 9001:80
volumes:
- "${SETTINGS}/Nextcloud/config:/var/www/html/config"
- "${SETTINGS}/Nextcloud/www:/var/www/html/"
- "/mnt/user/Nextcloud:/var/www/html/data"
labels:
- "traefik.enable=true"
- "traefik.http.routers.nextcloud-http.entrypoints=http"
- "traefik.http.routers.nextcloud-http.rule=Host(`cloud.${DOMAIN}`)"
- "traefik.http.routers.nextcloud-http.middlewares=https-redirect@file"
- "traefik.http.routers.nextcloud-https.entrypoints=https"
- "traefik.http.routers.nextcloud-https.tls=true"
- "traefik.http.routers.nextcloud-https.rule=Host(`cloud.${DOMAIN}`)"
- "traefik.http.routers.nextcloud-https=nextcloud"
- "traefik.http.routers.nextcloud-https.service=nextcloud"
- "traefik.http.services.nextcloud.loadbalancer.server.port=80"
It is working and I can save things on it, but I ended up having some problems while using the online client.
For example, when I uploaded multiple files at once (for example 200), since there were multiple concurrent requests, some would fail.
But the worst is when I enter in a folder and it tries to generate all the thumbnails. When that happens, depending on the folder, the apache2 service ramps up to 100% CPU and 100% memory and all containers fail, getting with all my resources at 100%.
The server has unraid with a Ryzen 3700x (8 cores) and 32GB RAM, so I don’t think this is normal.
Can anyone lead me on what I’m doing wrong on the setup?
Thank you in advance!
