Help Setting up AIO Backups
    • Nextcloud AIO v10.7.0
    • Docker Container on MacOS 14.6.1
I’m trying to set up a backup to my NAS which is where the ncdata folder also is.
I can see the process creates a lock.roster file and a lock.exclusive file.
The log is below- I’m sure it’s a simple configuration issue, I’m just not sure what.
The ncdata folder is mapped to /Volumes/Backup/Nextcloud/nextcloud_data
I’m entering this in the AIO Local Backup Location /Volumes/Backup/Nextcloud
Which should put the backups in
/Volumes/Backup/Nextcloud/borg
2025-03-09T17:36:29.952314995Z Local Exception
2025-03-09T17:36:29.952353014Z Traceback (most recent call last):
2025-03-09T17:36:29.952356047Z   File "/usr/lib/python3.12/site-packages/borg/archiver.py", line 5391, in main
2025-03-09T17:36:29.952357824Z     exit_code = archiver.run(args)
2025-03-09T17:36:29.952359228Z                 ^^^^^^^^^^^^^^^^^^
2025-03-09T17:36:29.952360580Z   File "/usr/lib/python3.12/site-packages/borg/archiver.py", line 5309, in run
2025-03-09T17:36:29.952362131Z     rc = func(args)
2025-03-09T17:36:29.952363458Z          ^^^^^^^^^^
2025-03-09T17:36:29.952364979Z   File "/usr/lib/python3.12/site-packages/borg/archiver.py", line 176, in wrapper
2025-03-09T17:36:29.952366367Z     with repository:
2025-03-09T17:36:29.952367611Z          ^^^^^^^^^^
2025-03-09T17:36:29.952368873Z   File "/usr/lib/python3.12/site-packages/borg/repository.py", line 217, in __enter__
2025-03-09T17:36:29.952370263Z     self.open(self.path, bool(self.exclusive), lock_wait=self.lock_wait, lock=self.do_lock)
2025-03-09T17:36:29.952371728Z   File "/usr/lib/python3.12/site-packages/borg/repository.py", line 465, in open
2025-03-09T17:36:29.952373066Z     self.lock = Lock(os.path.join(path, 'lock'), exclusive, timeout=lock_wait).acquire()
2025-03-09T17:36:29.952374471Z                 ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
2025-03-09T17:36:29.952375889Z   File "/usr/lib/python3.12/site-packages/borg/locking.py", line 398, in acquire
2025-03-09T17:36:29.952377264Z     with self._lock:
2025-03-09T17:36:29.952378501Z          ^^^^^^^^^^
2025-03-09T17:36:29.952379752Z   File "/usr/lib/python3.12/site-packages/borg/locking.py", line 124, in __exit__
2025-03-09T17:36:29.952381142Z     self.release()
2025-03-09T17:36:29.952382382Z   File "/usr/lib/python3.12/site-packages/borg/locking.py", line 176, in release
2025-03-09T17:36:29.952383755Z     os.unlink(self.unique_name)
2025-03-09T17:36:29.952385055Z OSError: [Errno 16] Resource busy: '/mnt/borgbackup/borg/lock.exclusive/nextcloud-aio-borgbackup.34-0'
2025-03-09T17:36:29.952386481Z
2025-03-09T17:36:29.952387714Z Platform: Linux 9ac31546df62 6.12.5-linuxkit #1 SMP PREEMPT_DYNAMIC Tue Jan 21 10:25:35 UTC 2025 x86_64
2025-03-09T17:36:29.952389187Z Linux: Unknown Linux
2025-03-09T17:36:29.952390428Z Borg: 1.4.0  Python: CPython 3.12.9 msgpack: 1.0.8 fuse: llfuse 1.5.1 [pyfuse3,llfuse]
2025-03-09T17:36:29.952391869Z PID: 34  CWD: /
2025-03-09T17:36:29.952393145Z sys.argv: ['/usr/bin/borg', 'info']
2025-03-09T17:36:29.952394471Z SSH_ORIGINAL_COMMAND: None
2025-03-09T17:36:29.952395771Z
2025-03-09T17:36:29.974879482Z Initializing repository...
2025-03-09T17:36:30.392586680Z using builtin fallback logging configuration
2025-03-09T17:36:30.542362929Z 33 self tests completed in 0.15 seconds
2025-03-09T17:36:30.550750901Z There is already something at /mnt/borgbackup/borg.
2025-03-09T17:36:30.550769043Z Traceback (most recent call last):
2025-03-09T17:36:30.550772144Z   File "/usr/lib/python3.12/site-packages/borg/archiver.py", line 5391, in main
2025-03-09T17:36:30.550774039Z     exit_code = archiver.run(args)
2025-03-09T17:36:30.550775425Z                 ^^^^^^^^^^^^^^^^^^
2025-03-09T17:36:30.550776762Z   File "/usr/lib/python3.12/site-packages/borg/archiver.py", line 5309, in run
2025-03-09T17:36:30.550778186Z     rc = func(args)
2025-03-09T17:36:30.550779444Z          ^^^^^^^^^^
2025-03-09T17:36:30.550780717Z   File "/usr/lib/python3.12/site-packages/borg/archiver.py", line 176, in wrapper
2025-03-09T17:36:30.550782100Z     with repository:
2025-03-09T17:36:30.550783406Z          ^^^^^^^^^^
2025-03-09T17:36:30.550784717Z   File "/usr/lib/python3.12/site-packages/borg/repository.py", line 215, in __enter__
2025-03-09T17:36:30.550786089Z     self.create(self.path)
2025-03-09T17:36:30.550787377Z   File "/usr/lib/python3.12/site-packages/borg/repository.py", line 300, in create
2025-03-09T17:36:30.550788794Z     self.check_can_create_repository(path)
2025-03-09T17:36:30.550790143Z   File "/usr/lib/python3.12/site-packages/borg/repository.py", line 282, in check_can_create_repository
2025-03-09T17:36:30.550791577Z     raise self.PathAlreadyExists(path)
2025-03-09T17:36:30.550792896Z borg.repository.Repository.PathAlreadyExists: There is already something at /mnt/borgbackup/borg.
2025-03-09T17:36:30.550794300Z
2025-03-09T17:36:30.550810186Z Platform: Linux 9ac31546df62 6.12.5-linuxkit #1 SMP PREEMPT_DYNAMIC Tue Jan 21 10:25:35 UTC 2025 x86_64
2025-03-09T17:36:30.550811578Z Linux: Unknown Linux
2025-03-09T17:36:30.550812857Z Borg: 1.4.0  Python: CPython 3.12.9 msgpack: 1.0.8 fuse: llfuse 1.5.1 [pyfuse3,llfuse]
2025-03-09T17:36:30.550814304Z PID: 35  CWD: /
2025-03-09T17:36:30.550815573Z sys.argv: ['/usr/bin/borg', 'init', '--debug', '--encryption=repokey-blake2']
2025-03-09T17:36:30.550817026Z SSH_ORIGINAL_COMMAND: None
2025-03-09T17:36:30.550821347Z
2025-03-09T17:36:30.575025457Z Could not initialize borg repository.
