I reinstalled Nextcloud via snap, changed my instance ID to the old installs ID, but only by admin user’s data was restored. I think the MySQL database isn’t being accessed, as when adding a user that existed, I get a bad request.
I read that updates make a database dump, is there any way I can use that?
[/details]
Nextcloud version: 18.0.4.2
Operating system and version: 18.04
Apache or nginx version: Apache2, 2.4.29
PHP version: 7.2.24
Error ocs_api InvalidArgumentException: Username is invalid because files already exist for this user 2020-05-28T11:32:56-0700
Error ocs_api InvalidArgumentException: Username is invalid because files already exist for this user 2020-05-28T11:11:56-0700
'apps_paths' =>
0 =>
'path' => '/snap/nextcloud/current/htdocs/apps',
'url' => '/apps',
'writable' => false,
1 =>
'path' => '/var/snap/nextcloud/current/nextcloud/extra-apps',
'url' => '/extra-apps',
'writable' => true,
'supportedDatabases' =>
0 => 'mysql',
'redis' =>
'host' => '/tmp/sockets/redis.sock',
'port' => 0,
'instanceid' => 'ockwop45dy6v',
'passwordsalt' => '***',
'secret' => '***',
0 => '192.168.1.112',
1 => '***',
'datadirectory' => '/mnt/pool/data',
'version' => '18.0.4.2',
'overwrite.cli.url' => 'http://192.168.1.112',
'dbname' => 'nextcloud',
'dbhost' => 'localhost:/tmp/sockets/mysql.sock',
'dbuser' => 'nextcloud',
'dbpassword' => '***',
