So, here’s my goal. I already have flows in place which tag specific files by filename when they are uploaded. Now, building on that, I would like to convert images which have a set of those tags to PDF. So I created a rule with three conditions:
- is tagged with X
- is tagged with Y
- mime type matches Images
But unfortunately, nothing happens when I upload stuff matching those criteria, so I created another flow to post to a chat channel, to debug. As expected, nothing shows up.
The weird thing is that if I manually remove the tags from the file, and then re-add them one by one, then when both X and Y are added, I get a message in my channel.
So, how am I supposed to
- create a flow which triggers when a specific set of tags are added to a new file by another flow
- debug the flow engine
Ah, I couldn’t debug the engine despite all my efforts, nothing in the system log, neither the flow.log. I posted an issue about that on the NC server github.
Any help/suggestions appreciated.
