When trying to restore nc after Sharing Symbol Missing problem we have got new trouble: No data is showing up AND no sharing symbols!
After the above mentioned upgrade to NCP 1.24 and NC 18.0.3 I restored to NC 17.0.2.1 with nc-restore. Automatic nc-scan has been activated after nc-restore. Data is at the right place on the server. User can login, BUT no data is showing up
Yesterday ~ 11:30h
1.1 Backup with ncp-export-ncp, nc-backup (without data) and nc-snapshot
1.2 Update from ncp 1.20 to 1.24 via nc-update
1.3 Update from 17.x to 18.0.3 via nc-update-nextcloud
Result
2.1 System running / Datasync possible but
2.2 Sharing (Freigaben) is gone: see Keine Freigaben
Today
3.1 Try to fix problem by restoring via nc-restore (using existing data)
3.2 Result: after nc-scan user can see last activities but no files AND
3.3 Sharing still isn’t available
I did some more investigations: Can it be that nc-backup backups the database but nc-restore doesn’t restore it to the previous location?
The configuration file /etc/mysql/mariadb.conf.d/50-server.cnf says
datadir = /var/lib/mysql
and when I use nc-database the default value of /var/lib/mysql is shown, whereas nc-datadir shows the right vaule of /media/cloud-data/ncdata … and as far as I can see the backup doesn’t include any settings outside the nextcloud directory.
Seams to be a bug?
Idea the following steps:
nc-init to cleanup nextcloud configuration
nc-database to default location, such that ncp “knows” where it is"
nc-restore will give me a running system, where database is restored to the default location
