I can’t access https://help.nextcloud.com/ using ipv6:
Firefox: Une erreur est survenue pendant une connexion Ă help.nextcloud.com. PR_END_OF_FILE_ERROR
$ curl https://help.nextcloud.com/
curl: (35) OpenSSL SSL_connect: SSL_ERROR_SYSCALL in connection to help.nextcloud.com:443
$ wget https://help.nextcloud.com/
--2021-01-02 23:41:57-- https://help.nextcloud.com/
Résolution de help.nextcloud.com (help.nextcloud.com)… 2a01:4f9:2b:29dc::146, 95.217.53.146
Connexion à help.nextcloud.com (help.nextcloud.com)|2a01:4f9:2b:29dc::146|:443… connecté.
GnuTLS: Error in the pull function.
Incapable d’établir une connexion SSL.
It’s ok with ipv4:
$ curl -4 https://help.nextcloud.com/ >/dev/null
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 18587 0 18587 0 0 41862 0 --:--:-- --:--:-- --:--:-- 41862
External check: https://tls.imirhil.fr/https/help.nextcloud.com
Can you fix it please?
