Having all sorts of problems talking to My Nextcloud 11.0.3 contacts.
In OSX 10.12.4 Settings I add a new CardDav Account with the following entries
Account Type: Advanced
User Name: MYUSERNAME
Password: MYPASSWORD
Server Address: https://MYDOMAIN.COM
Server Path: /nextcloud/remote.php/dav/addressbooks/users/MYUSERNAME/contacts/
Port: ‘Auto’ Use SSL box is ticked
and press sign in. After a few seconds I get the error "Unable to verify account name or password.
I’ve checked my .htaccess file and here are following entries within it
SetEnvIfNoCase ^Authorization$ "(.+)" XAUTHORIZATION=$1 RequestHeader set XAuthorization %{XAUTHORIZATION}e env=XAUTHORIZATION SetEnvIfNoCase Authorization "(.+)" HTTP_AUTHORIZATION=$1 # Add security and privacy related headers Header set X-Content-Type-Options "nosniff" Header set X-XSS-Protection "1; mode=block" Header set X-Robots-Tag "none" Header set X-Frame-Options "SAMEORIGIN" Header set X-Download-Options "noopen" Header set X-Permitted-Cross-Domain-Policies "none" SetEnv modHeadersAvailable trueAdd cache control for static resources
<FilesMatch “.(css|js|svg|gif)$”>
Header set Cache-Control “max-age=15778463”
Let browsers cache WOFF files for a week
<FilesMatch “.woff$”>
Header set Cache-Control "max-age=604800"
php_value upload_max_filesize 511M
php_value post_max_size 511M
php_value memory_limit 512M
php_value mbstring.func_overload 0
php_value always_populate_raw_post_data -1
php_value default_charset 'UTF-8’
php_value output_buffering 0
SetEnv htaccessWorking true
RewriteEngine on
RewriteRule .* - [env=HTTP_AUTHORIZATION:%{HTTP:Authorization}]
RewriteRule ^.well-known/host-meta /public.php?service=host-meta [QSA,L]
RewriteRule ^.well-known/host-meta.json /public.php?service=host-meta-json [QSA,L]
RewriteRule ^.well-known/carddav /remote.php/dav/ [R=301,L]
RewriteRule ^.well-known/caldav /remote.php/dav/ [R=301,L]
RewriteRule ^remote/(.) remote.php [QSA,L]
RewriteRule ^(?:build|tests|config|lib|3rdparty|templates)/. - [R=404,L]
RewriteCond %{REQUEST_URI} !^/.well-known/acme-challenge/.*
RewriteRule ^(?:.|autotest|occ|issue|indie|db_|console).* - [R=404,L]
AddType image/svg+xml svg svgz
AddEncoding gzip svgz
DirectoryIndex index.php index.html
AddDefaultCharset utf-8
Options -Indexes
ModPagespeed Off
DO NOT CHANGE ANYTHING ABOVE THIS LINE
Header set Strict-Transport-Security "max-age=15552000; includeSubDomains; preload"
Redirect 301 /.well-known/carddav /nextcloud/remote.php/dav
Redirect 301 /.well-known/caldav /nextcloud/remote.php/dav
My nextcloud instance is installed on a bog standard Apache2 server in /var/www/html/nextcloud
the .htaccess file is in the nextcloud directory.
I cannot get the contacts working in my iPhone with the same settings and the calendar in OS X and iPhone don’t connect either.
Presumably something really basic is wrong, but I’ll be dammed if I can see what. I have gone through most of the entries on the same topic within the Nextcloud Community as well as
https://192.168.0.21/nextcloud/index.php/settings/help?mode=admin
most of the solutions offered are contradictory and refer to older versions of Nextcloud
UFW firewall is turned on and only allows tcp access to ports 22, 443
Any ideas?
