Can anyone please offer any help on how to install a third party SSL Cert
I have Nextcloud 16 snap installed on Ubuntu server
The company that I got the SSL cert from have given me 3 files
1 x .cer file
1 x .pfx file
1 x .key file
I’ve been looking at google and this support forum and what I can work out is that I need to copy the files to /var/snap/nextcloud/current/certs/custom/ but what I’ve read is that I should copy .pem files to that location but I don’t have .pem files.
Do I have to SSH into my server using the root account? if I do what is the username and password for the root account, as I used the account I setup to install nextcloud snap and it doesn’t give me permissions to copy to the above directory.
What is the result of the following command: grep "BEGIN CERTIFICATE" <path-to-cer-file> ?
What is the result of the following command: grep "PRIVATE KEY" <path-to-key-file> ?
The first issue I have is that I don’t have permission to copy the files to the server…Do I have to use the root account…if so what would the username and password be?
Ups, you should never ever post the whole content of these files in a forum, because it could be misused by others otherwise. Please instantly remove it!!
So, after you’ve answered my question I can confirm that the *.cer file can be used as cert.pem and that the *key file can be used as privkey.pem file. For the chain.pem you will most likely need to download the following intermediate certificate, which is in der-format and needs to be converted into the pem-format be used:
