Help needed: Problems installing software at Nextcloud box and raspberry pi 3
Hi guys,
this weekend I got my nextcloud box and was really happy to start and create my own cload. But somehow I am able to get it too work and at this moment I really dont know what to do anymore, hopefully someone is able to point me in the right direction.
I followed this tutorial:
  1. I started with this image: ubuntu-core-16-armhf-rpi3-installer-20170329.img
  2. Created an account at ubuntu.com
  3. Created a public key with puttygen and saved it in my ubuntu account
  4. Boot the nextcloud box with an ethernet connection
  5. During the first boot I got to the profile page and entered my emailaddress (SSO)
In the end I got to a page saying that I could login through SSH with my username (from ubuntu.com) @ the IP adress of the box. I can ping the machine, and can see it has a connection through my router.
But whatever I try, I can not login with SSH or get passed this message. I have tried multiple SSO accounts, reformatted the SD card, different keys, formatted the harddisk on my ubuntu machine etc.
Also I can not see anything on this URL: ​http://nextcloud.local​.
Have you also tried: ssh [default_user]@nextcloud.local?
Hi Hollerauer, thanks for your reply. Yes I have tried that, but I got the same result, Access Denied.
If you’re starting from scratch and willing to try a slightly different approach, I’d suggest the same route that I recently suggested in this post:
(in that posting I overlooked the fact that the OP was looking for a client recommendation, not a server, but it sounds like you want to set up a server).
Also, this thread covers similar ground, and received similar responses:
@donutlover
finally had some time to continue, but your advice worked as a charm, just as I expected from the ā€œofficialā€ image. Thanks a lot!!
Glad this worked out for you. This is great…@nachoparker does all the work, and I get all the credit! Can’t beat that. :slight_smile:
