Sorry for the original empty post. This is my first use of this forum.
I am trying to migrate from owncloud to nextcloud and have set up a test system to experiment with. My environment is OpenBSD 6.1 using httpd, with php 5.6 and maria db. I have been able to install nextcloud 11.0.2 and upgrade to 11.0.3. I have also installed owncloud 9.1.4 and upgraded to 9.1.5. My production system is at 9.1.5.
I try to upgrade from owncloud 9.1.5 to nextcloud 10.0.5 using the web and I get an error saying “An error occured”. When I click to see the detailed log, I get a repeat of “an error occured” The log file does show the following error, but that is all.
{“reqId”:“McyEM+hz0iIBTTFSuPQg”,“remoteAddr”:“50.92.162.251”,“app”:“index”,“message”:“Exception: {“Exception”:“OC\\NeedsUpdateException”,“Message”:”",“Code”:0,“Trace”:"#0 \/nextcloud\/lib\/private\/legacy\/app.php(123): OC_App::loadApp(‘federation’)\n#1 \/nextcloud\/lib\/base.php(975): OC_App::loadApps(Array)\n#2 \/nextcloud\/index.php(48): OC::handleRequest()\n#3 {main}",“File”:"\/nextcloud\/lib\/private\/legacy\/app.php",“Line”:151}",“level”:3,“time”:“2017-05-26T05:48:35+00:00”,“method”:“GET”,“url”:"/index.php/core/js/oc.js?v=290b6049713cbb89c91a325039a7ee5c",“user”:"–",“version”:“9.1.5.2”}
The systems of owncloud and nextcloud that I testing with are the basic installs. No apps are enabled other than what the installations provide.
The config file is:
'instanceid' => 'ocovb9lmn6w4',
'passwordsalt' => 'x5ZBSsmI988mpHpX9djfc9ILA0RIZO',
'secret' => '4zkAQ3e01mGBntcn2Da1NgnNAQr3pBkAsnQrGyRQoupDqW3J',
0 => 'xxxxxxxxxxx',
'datadirectory' => '/owncloud/data',
'overwrite.cli.url' => 'https://xxxxxxxx',
'version' => '9.1.5.2',
'dbname' => 'owncloud',
'dbhost' => 'localhost',
'dbuser' => 'owndba',
'dbpassword' => 'dba-pswd',
'logtimezone' => 'UTC',
'theme' => '',
'loglevel' => 2,
The httpd access log shows:
xxxxxxxxxxx - - [25/May/2017:23:15:56 -0700] "GET /index.php HTTP/1.1" 200 0
xxxxxxxxxxx- - [25/May/2017:23:15:56 -0700] "GET /index.php/core/js/oc.js?v=290b6049713cbb89c91a325039a7ee5c HTTP/1.1" 503 0
There is nothing generated in the httpd error log.
Can anyone provide a hint as to what to look at next?
