Help Local storage!
#1
I am running NC 13 on Ubuntu LTS 18.04 as a VM on Hyper-V. I have a drive on the physical box running windows 2016 that has the files I want to make available to the users I give access to NC.
I know there are many posts and articles but I have information overload and cannot get the drive to be seen by NC or seem to get it to set-up in Ubuntu.
I can easily share the folders to other clients on my network but struggling with Ubuntu.
#2
Did you try and ask the hyper-v community how to link a folder from Win 2016 in a Linux machine? Once you managed to do that, you have to set the permissions that the webserver user (in Ubuntu: www-data) can read or read and write this folder.
#3
As tflidd stated, you need to mount the share into your VM first. After that, you need to set the ownership to the www-data user. If I recall correctly you can simply attach the physical disk to your Hyper-V VM. Or you could create a Virtual Disk on that external drive and link it to the VM. It’s your choice.
If you wondered how to set the ownership to www-data, it’s the following command:
sudo chown www-data:www-data -R /path/to/datafolder
This will recursively set the ownership of /path/to/datafolder.
#4
Why not just share the drive from windows and mount it as external storage in Nextcloud?
#5
Simply attached the physical disk to the Hyper-V and now the VM will not start. “An error occurred wile attmepting to start the selected virtualmachine(s).” Server failed to change state
#6
@sunshinetech
“Why not just share the drive from windows and mount it as external storage in Nextcloud?” That is what I wan t to do but it appears it is not that simple.
#7
OK the VM is back up an running. I have a NFS share but still cannot add the folders to Nextcloud
