Steps to reproduce.
- Delete user
- Gone
How do you recover this? The entire company data is gone because the main folder is owned by me.
Steps to reproduce.
Looks like the files will have been deleted as expected. But double check your data folder (i.e. /var/www/nextcloud/data)
Assuming you don’t have backups and if all else fails look into the Photorec tool and try to recover from there.
