Hi eyeryone,
today i am here in need of some help while performing my first nextcloud installation. My setup
- Ubuntu Server 20.04 LTS
- MariaDB 10.4
- php7.4
- Apache2
Webserver and DB all on one system.
I followed the offical guide example for ubuntu installations
https://docs.nextcloud.com/server/stable/admin_manual/installation/example_ubuntu.html
I am currently at the âlastâ step performing installation via the installation wizzard or via occ.
i wanted to install nextcloud via occ, as i plan to use a headless approach for this build.
however:
my tries with occ (later on also via the wizzard) are not successfull, giving me the error:
"Error while trying to create admin user: Failed to connect to the database: An exception occurred in the driver: SQLSTATE[HY000][1045] Access denied for user ânextcloudâ@âlocalhostâ (using password: YES)
So what works:
- DB is up and running, listening on the default port.
- I can connect as user ânextcloudâ via cli.
- Even in the usercontext of the www-data âbuild-inâ www-data user i can manually connect to db via cli.
- mysql/error.log - shows the access attempts of the user which are then denied
So far it looks like something is happening with the provided credentials during the setup - thatâs why i tried simple passwords with no specidal characters - no success
i tried several combinations of values for the cli method - hostname / hostname wit port âŚ
afterwards iâve installed a GUI and browser to access the GUI wizzard. Able to access everything and all worked but i got the same error (which of cause was to be expected)
No i am a bit⌠idealess what to try next. i would setup the whole server again, but i canât see any major flaws iâve been makeing or what could be so wrong that a basic connection to an local DB isnât workingâŚ
What seems to be normal:
Takeing a look into the table mysql.user shows, that the user hast no auth_plugin listed - meaning as far as i was able to read that the user is using the mysql_native plugin.
however - as i am able to connect via cli that seems to be fine.
Anyone hast som ideas how to get this serivce up running?
Thanks in advance!
