I am tring to install and run Nextcloud.
I downloaded the VM from the official website et managed to install it (on a proliant gen8 server running on ESXi 6)
No problem regarding the access of the webmin interface (mylocalIP:10000) but I get trouble when trying to access the actual interface.
I get an error message telling me that I am trying to access my server from an unapproved domain. I am still on my local network… I tried to access the config.php file to add my local IP in the trusted list but cannot access the nextcloud folder (permission denied) (no problem to access /var/www).
Could you please help me ?
Another question : Is the domain name mandatory to access Nextcloud from the outside ? (or my Internet IP with redirected ports is enough ?)
How are you trying to edit the file? Through Webmin or SSH? If you’re using SSH, try typing ‘sudo’ before the command and entering your password.
A domain name is not required to access Nextcloud from the Internet, but you will need to put your IP address in the trusted_domains field in config.php.
I managed to modify it this morning using putty, thanks.
For an unknown reason the SSH client I was using before didn’t work…
Another noob question : I’m using raid5 on my OMV VM and would like to create a folder on this filesystem to store my Nextcloud data.
So I would like to make it available from my OMV VM to my Nextcloud VM.
