Hi, my problem is, I have restore the Contacts with ownbackup and now i have a load loop on contacts. I can’t see the Contacts Adressbook and the contacs.
The Restore Tables:
- oc_addressbookchanges
- oc_addressbooks
- oc_cards
- oc_cards_properties
When restoring I get the following error:
[details=Summary] Table(s) could not be restored: Inserting data row failed: An exception occurred while executing ‘INSERT INTO oc_cards
(id
,addressbookid
,carddata
,uri
,lastmodified
,etag
,size
) SELECT ?,?,?,?,?,?,? FROM oc_cards
WHERE id
= ? AND addressbookid
= ? AND carddata
= ? AND uri
= ? AND lastmodified
= ? AND etag
= ? AND size
= ? HAVING COUNT(*) = 0’ with params [“1”, “4”, “BEGIN:VCARD\r\nVERSION:4.0\r\nPRODID:+//IDN bitfire.at//DAVdroid/1.4.0.3-gplay vcard4android ez-vcard/0.1\r\n 0.1\r\nUID:7cac7d59-3edd-4158-b181-58af232c97cb\r\nCATEGORIES:
=\r\nREV:20170225T124301Z\r\nEND:VCARD\r\n”, “7cac7d59-3edd-4158-b181-58af232c97cb.vcf”, “1488026583”, “f794851d27e30afddc9581925e48382d”, “140558”]: SQLSTATE[42S22]: Column not found: 1054 Unknown column ‘carddata’ in ‘where clause’
[/details]
If I want to access the contacts I get the following entry in the log:
Summary
Doctrine\DBAL\Exception\InvalidFieldNameException: An exception occurred while executing 'SELECT `id`, `uri`, `lastmodified`, `etag`, `size`, `carddata` FROM `oc_cards` WHERE `addressbookid` = ?' with params ["3"]: SQLSTATE[42S22]: Column not found: 1054 Unknown column 'carddata' in 'field list'
/var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/DBALException.php - line 128: Doctrine\DBAL\Driver\AbstractMySQLDriver->convertException('An exception oc...', Object(Doctrine\DBAL\Driver\PDOException))
/var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php - line 836: Doctrine\DBAL\DBALException driverExceptionDuringQuery(Object(Doctrine\DBAL\Driver\PDOMySql\Driver), Object(Doctrine\DBAL\Driver\PDOException), 'SELECT `id`, `u...', Array)
/var/www/nextcloud/lib/private/DB/Connection.php - line 194: Doctrine\DBAL\Connection->executeQuery('SELECT `id`, `u...', Array, Array, NULL)
/var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Query/QueryBuilder.php - line 206: OC\DB\Connection->executeQuery('SELECT `id`, `u...', Array, Array)
/var/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php - line 177: Doctrine\DBAL\Query\QueryBuilder->execute()
/var/www/nextcloud/apps/dav/lib/CardDAV/CardDavBackend.php - line 460: OC\DB\QueryBuilder\QueryBuilder->execute()
/var/www/nextcloud/3rdparty/sabre/dav/lib/CardDAV/AddressBook.php - line 80: OCA\DAV\CardDAV\CardDavBackend->getCards('3')
/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Tree.php - line 195: Sabre\CardDAV\AddressBook->getChildren()
/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php - line 893: Sabre\DAV\Tree->getChildren('addressbooks/us...')
/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php - line 947: Sabre\DAV\Server->addPathNodesRecursively(Array, Object(Sabre\DAV\PropFind))
/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php - line 336: Sabre\DAV\Server->getPropertiesForPath('addressbooks/us...', Array, 1)
[internal function] Sabre\DAV\CorePlugin->httpPropFind(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))
/var/www/nextcloud/3rdparty/sabre/event/lib/EventEmitterTrait.php - line 105: call_user_func_array(Array, Array)
/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php - line 479: Sabre\Event\EventEmitter->emit('method PROPFIND', Array)
/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php - line 254: Sabre\DAV\Server->invokeMethod(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))
/var/www/nextcloud/apps/dav/lib/Server.php - line 227: Sabre\DAV\Server->exec()
/var/www/nextcloud/apps/dav/appinfo/v2/remote.php - line 30: OCA\DAV\Server->exec()
/var/www/nextcloud/remote.php - line 165: require_once('/var/www/nextcl...')
{main}
Can someone help me there?
