I am not sure if this is a duplicate with one of the other proplems mentioned before but I need some assistance.
NC: 13.0 (Docker)
Contacts : 2.1.0
Using Firefox 58.0.2 clicking on contacts shows no content and the groups are not shown in the left column.
In the Web console I see the following issues:
Content Security Policy: Die Einstellungen der Seite haben das Laden einer Ressource auf self blockiert ("script-src 'nonce-M1NMMmN2Zzk1VEJMMlU0aEhhV1pDZVA4LzZNYVQ3Nno5M0JveUdjWWdwYz06c1hxTUg2eEtobms5Z0NCWWFlejFZSnVHa2VkV2Q4bUF1QlFtdUNJcSsvQT0=' 'unsafe-eval'"). Source: ondrop attribute on INPUT element.
contacts
Source-Map-Fehler: SyntaxError: JSON.parse: unexpected character at line 1 column 1 of the JSON data
Ressourcen-Adresse: https://<MYURL>/core/vendor/core.js?v=5ac8fb93-0
Source-Map-Adresse: purify.min.js.map
When I load the page directly (not going via reverse proxy) it loads perfectly.
When I use the Edge Browser it loads even via the proxy.
Is this a proxy configuration problem or a problem of NC/Contacts?
Any help is appreciated!
Thanks.
