Dear NextCloud Experts,
I installed the NEXTCLOUD 12.0.3 version on a shared hosting space.
Then I downloaded the client for Windows 7 (Nextcloud-2.3.2.1-setup.exe) and I installed it.
Synchronization between folders worked.
Then I decided to enable the Encryption Module.
I also changed the user login password.
When I was logged in again, I tried to download some uloaded files from my NextCloud repository, but I received this error message:
Sabre\DAV\Exception\ServiceUnavailable Encryption not ready: multikeydecrypt with share key failed:error:0407109F:rsa routines:RSA_padding_check_PKCS1_type_2:pkcs decoding error
This XML file does not appear to have any style information associated with it. The document tree is shown below.
<d:error xmlns:d=“DAV:” xmlns:s=“http://sabredav.org/ns”>
<s:exception>Sabre\DAV\Exception\ServiceUnavailable</s:exception>
<s:message>
</s:message>
<s:message>…</s:message>
</d:error>
<d:error xmlns:d=“DAV:” xmlns:s=“http://sabredav.org/ns”>…</d:error>
Who knows how to retrieve uploaded files?
Have I upload them again ?
Have I reset some keys ? How ?
Your kind help is absolutely welcomed !
Thank You in advance.
Alex
