Hi there! Let me start by saying - I donât speak computer. I bought a new Raspberry Pi 4 4GB, with the main goal of setting up a personal cloud and experimenting with hosting my own website. So, while I was installing Nextcloud (following these instructions to the letter https://www.youtube.com/watch?v=kb0L3cvcFGQ), at the moment where I shouldâve entered a login screen on my browser when entering [ip address]/nextcloud, I got an error saying my version wasnât compatible. I looked up the latest version on here https://download.nextcloud.com/server/releases/ and âinstalledâ that (if thatâs the right word) through puTTY instead.
Then, I entered:
sudo mkdir -p /var/www/html/nextcloud/data
sudo chown -R www-data:www-data /var/www/html/nextcloud
sudo chmod 750 /var/www/html/nextcloud/data
And
sudo systemctl restart apache2
When trying to access the [ip address]/nextcloud website again - it gave me an updating screen saying it would update to 18.0.3. I clicked on âupdateâ - but then it gave me the following error and I am so stuck at the moment
Doctrine\DBAL\Exception\DriverException: An exception occurred while executing âSELECT âcâ.âidâ FROM âoc_calendarobjectsâ âcâ LEFT JOIN âoc_calendarsâ âpâ ON âcâ.âcalendaridâ = âpâ.âidâ WHERE (âpâ.âidâ IS NULL) AND (âcâ.âcalendartypeâ = ?)â with params [0]: SQLSTATE[HY000]: General error: 1 no such column: c.calendartype
Iâd be very very thankful for your help! Iâve looked through the forum many times, but I canât seem to find an answer (that I understand - that is).
Are you running Nextcloud or NextCloudPi?
Thank you for trying to help Karl! Ehm I think itâs Nextcloud. Because these are the exact steps I followed - and they donât seem to mention NextcloudPi.
Hi there! Iâm still very stuck - and I would like to start my Nextcloud - Pi journey very much. If thereâs anyone who can guide me towards a solution Iâd appreciate that a lot!
@hakimaknouz
this is a very valid questionâŚ
but you canât know so far that nextcloudpi
is just a great tool that would help noobs like me and you setting up their own nextcloud pretty fast with sane settings.
apart from that nextcloudpi
(short: ncp
) is part of the official nextcloudversum. so you donât need to be afraid about anythingâŚ
youâll find more infos about ncp
at their website www.nextcloudpi.com - they even would help you with the installation (more or less: grab their image-file, write it to your sd-card and then start it up)
good luck.
Iâm just asking because I havenât used NextCloudPi and I understand the setup is very different. I canât offer much guidance with the initial setup. Maybe someone familiar with it can chime in.
Aah thanks a lot Jimmy and Karl! I think I will then try to figure out how to remove everything that has to do with my nextcloud from my raspberry pi (I hope I didnât break anything lol) - and then start over again following the instructions on https://docs.nextcloudpi.com/en/how-to-install-nextcloudpi/.
a last suggestion allowed @hakimaknouz?
if youâd just write the new image onto your sd-card it would automatically wipe everything that was on it before. and set up a fresh instance⌠so you wouldnât really break anything since it comes together with a fully installed raspbian, already
which means: just write image onto sd-card, insert sd-card to pi, power on and shoot. (more or less), for details pls refer to the wiki of ncp
good luck!
Thanks again @JimmyKater! Will try out asap and let you know whether it worked
