I am working on getting Nextcloud to run in the Tomcat web server.
At the moment I am stuck on adding a new contact (the first entry, there are no contacts yet).
In the firefox console I see:
REPORT
XHR
https://192.168....:8443/nextcloud/remote.php/dav/addressbooks/users/admin/contacts/ [HTTP/1.1 415 1158ms]
Kopfzeilen
Antwortkopfzeilen
Cache-Control private
Content-Language en
Content-Length 1098
Content-Type text/html;charset=UTF-8
Date Tue, 26 Sep 2017 10:37:36 GMT
Expires Thu, 01 Jan 1970 01:00:00 CET
Anfragekopfzeilen
Accept */*
Accept-Encoding gzip, deflate, br
Accept-Language de-DE,en-US;q=0.7,en;q=0.3
Authorization Basic ...=
Connection keep-alive
Content-Length 477
Content-Type application/xml;charset=utf-8
Cookie nc_sameSiteCookielax=true; nc_sameSiteCookiestrict=true; oc...=...; oc_sessionPassphrase=...
Depth 1
Host 192.168....:8443
User-Agent Mozilla/5.0 (X11; Linux x86_64; rv:52.0) Gecko/20100101 Firefox/52.0
requesttoken ...
POST
<card:addressbook-query xmlns:card="urn:ietf:params:xml:ns:carddav"\n xmlns:d="DAV:">\n <d:prop>\n <d:getetag />,<card:address-data />\n </d:prop>\n <!-- According to http://stackoverflow.com/questions/23742568/google-carddav-api-addressbook-multiget-returns-400-bad-request,\n Google's CardDAV server requires a filter element. I don't think all addressbook-query calls need a filter in the spec though? -->\n </card:addressbook-query>
Antwort
<!doctype html><html lang="en"><head><title>HTTP Status [415] β [Unsupported Media Type]</title><style type="text/css">h1 {font-family:Tahoma,Arial,sans-serif;color:white;background-color:#525D76;font-size:22px;} h2 {font-family:Tahoma,Arial,sans-serif;color:white;background-color:#525D76;font-size:16px;} h3 {font-family:Tahoma,Arial,sans-serif;color:white;background-color:#525D76;font-size:14px;} body {font-family:Tahoma,Arial,sans-serif;color:black;background-color:white;} b {font-family:Tahoma,Arial,sans-serif;color:white;background-color:#525D76;} p {font-family:Tahoma,Arial,sans-serif;background:white;color:black;font-size:12px;} a {color:black;} a.name {color:black;} .line {height:1px;background-color:#525D76;border:none;}</style></head><body><h1>HTTP Status [415] β [Unsupported Media Type]</h1><hr class="line" /><p><b>Type</b> Status Report</p><p><b>Description</b> The origin server is refusing to service the request because the payload is in a format not supported by this method on the target resource.</p><hr class="line" /><h3>Apache Tomcat/9.0.0.M21</h3></body></html>
Cookies
nc_sameSiteCookielax true
nc_sameSiteCookiestrict true
oc_sessionPassphrase ...
oc... ...
Aufrufliste
send https://192.168....:8443/nextcloud/apps/contacts/js/dav/dav.js:3641:7
callee$2$0$ https://192.168....:8443/nextcloud/apps/contacts/js/dav/dav.js:3156:22
tryCatch https://192.168....:8443/nextcloud/apps/contacts/js/dav/dav.js:121:37
invoke https://192.168....:8443/nextcloud/apps/contacts/js/dav/dav.js:294:22
defineGeneratorMethod/Gp[method] https://192.168....:8443/nextcloud/apps/contacts/js/dav/dav.js:330:14
onFulfilled https://192.168....:8443/nextcloud/apps/contacts/js/dav/dav.js:3737:15
co/< https://192.168....:8443/nextcloud/apps/contacts/js/dav/dav.js:3726:5
co https://192.168....:8443/nextcloud/apps/contacts/js/dav/dav.js:3722:10
send https://192.168....:8443/nextcloud/apps/contacts/js/dav/dav.js:3134:15
callee$0$0$ https://192.168....:8443/nextcloud/apps/contacts/js/dav/dav.js:1763:16
createPromise https://192.168....:8443/nextcloud/apps/contacts/js/dav/dav.js:3702:12
callee$0$0$ https://192.168....:8443/nextcloud/apps/contacts/js/dav/dav.js:1929:16
syncCollection https://192.168....:8443/nextcloud/apps/contacts/js/dav/dav.js:3438:12
syncAddressBook https://192.168....:8443/nextcloud/apps/contacts/js/dav/dav.js:1832:10
syncAddressBook https://192.168....:8443/nextcloud/apps/contacts/js/dav/dav.js:1540:14
.sync https://192.168....:8443/nextcloud/apps/contacts/js/public/script.js:1513:11
this.fillCache/loadPromise</< https://192.168....:8443/nextcloud/apps/contacts/js/public/script.js:1655:7
this.fillCache/loadPromise< https://192.168....:8443/nextcloud/apps/contacts/js/public/script.js:1653:5
In nextcloud.log I see:
{"reqId":"...","level":4,"time":"2017-09-26T10:37:35+00:00","remoteAddr":"127.0.0.1","user":"admin","app":"webdav","method":"REPORT","url":"\/nextcloud\/remote.php\/dav\/addressbooks\/users\/admin\/contacts\/","message":"Exception: {\"Exception\":\"Sabre\\\\DAV\\\\Exception\\\\ReportNotSupported\",\"Message\":\"The addressbook-query report is not supported on this url with Depth: 0\",\"Code\":0,\"Trace\":\"#0 \\\/var\\\/www\\\/default\\\/nextcloud##120002\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/CardDAV\\\/Plugin.php(203): Sabre\\\\CardDAV\\\\Plugin->addressbookQueryReport(Object(Sabre\\\\CardDAV\\\\Xml\\\\Request\\\\AddressBookQueryReport))\\n#1 [internal function]: Sabre\\\\CardDAV\\\\Plugin->report('{urn:ietf:param...', Object(Sabre\\\\CardDAV\\\\Xml\\\\Request\\\\AddressBookQueryReport), 'addressbooks\\\/us...')\\n#2 \\\/var\\\/www\\\/default\\\/nextcloud##120002\\\/3rdparty\\\/sabre\\\/event\\\/lib\\\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\\n#3 \\\/var\\\/www\\\/default\\\/nextcloud##120002\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/CorePlugin.php(718): Sabre\\\\Event\\\\EventEmitter->emit('report', Array)\\n#4 [internal function]: Sabre\\\\DAV\\\\CorePlugin->httpReport(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#5 \\\/var\\\/www\\\/default\\\/nextcloud##120002\\\/3rdparty\\\/sabre\\\/event\\\/lib\\\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\\n#6 \\\/var\\\/www\\\/default\\\/nextcloud##120002\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(479): Sabre\\\\Event\\\\EventEmitter->emit('method:REPORT', Array)\\n#7 \\\/var\\\/www\\\/default\\\/nextcloud##120002\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(254): Sabre\\\\DAV\\\\Server->invokeMethod(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#8 \\\/var\\\/www\\\/default\\\/nextcloud##120002\\\/apps\\\/dav\\\/lib\\\/Server.php(253): Sabre\\\\DAV\\\\Server->exec()\\n#9 \\\/var\\\/www\\\/default\\\/nextcloud##120002\\\/apps\\\/dav\\\/appinfo\\\/v2\\\/remote.php(33): OCA\\\\DAV\\\\Server->exec()\\n#10 \\\/var\\\/www\\\/default\\\/nextcloud##120002\\\/remote.php(162): require_once('\\\/var\\\/www\\\/defaul...')\\n#11 {main}\",\"File\":\"\\\/var\\\/www\\\/default\\\/nextcloud##120002\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/CardDAV\\\/Plugin.php\",\"Line\":439}","userAgent":"Mozilla\/5.0 (X11; Linux x86_64; rv:52.0) Gecko\/20100101 Firefox\/52.0","version":"12.0.2.0"}
