i want to now the way to make me and my team can edit our files ( excel sheet or documents) form the web
at least onlyoffice and/or collabora must be installed additional to nextcloud.
at which point of that journey are you?
i have already installed collabora but when i open an excel sheet file it doesn’t open
i hope you installed the container not only activate the app in nextcloud.
did you reboot your server. collabora needs a reboot.
did you install certifcates correct? collabora is rather sensitiv here.
what error do you get? which howto do you follow?
i thought that when i install collabora from the app and make it enable every thing is going to work:rofl:
but i found that i have to integrate it on my server with Nextcloud
so i need steps one by one
i have installed nextcloud on Ubuntu server
pls check the forum for suggestions as there are some…
