I’m trying to use Talked and I’m having similar problems. I’m running the talked repository on a separate server, but within the same local network. My ubuntu version is 22.04. I installed nginx but I don’t know if I managed to make the proxy correctly. I followed the github installation process.
When trying to run the command inside the chat /recording start I get the following output: “An error occurred while running the command. Please try again or contact an administrator.”
the Talked app version is 0.5 and I’m using Nextcloud version 25.0.5
