apps/richdocumentscode/proxy.php?req=/hosting/capabilitiesresulted in a
404 Not Found` response: 404 Not Found
You’ll need to provide more context about your setup and what steps you’ve taken for each your current point
It appears you don’t have the richdocumentscode
app installed, but it could also be numerous other things - like a way outside web server config.
The nextcloud installed during my ubuntu 22.04 installation, I think its under snap
Okay, but are you trying to do something when this error occurs?
What are the steps to reproduce?
I have no idea, still try to search for the solution.
Thanks
