example
longer
example
here
Nextcloud version 25.0.2:
Operating system and version Ubuntu 22.04.1 LTS:
Apache or nginx version Apache 2.4.25:
PHP version 8.1:
GUI view of logging in Administrative Setting is not visible
Is this the first time you’ve seen this error? YES:
- Enabled SSO & SAML Authentication. Then selected logging in Administrative settings and log view does not appear.
- Disabled SSO & SAML Authentication. I again select logging within Administrative settings and now logs are now visible
- Enabled SSO & SAML Authentication again. Select Logging again and logs do not appear in GUI.
The output of your Nextcloud log in Admin > Logging: Logs after disabling SSO & SAML Authentication
Error PHP Error: foreach() argument must be of type array|object, null given at /var/www/html/nextcloud/apps/user_saml/lib/SAMLSettings.php#118 2022-12-13T13:14:12-0500
Error PHP Error: foreach() argument must be of type array|object, null given at /var/www/html/nextcloud/apps/user_saml/lib/SAMLSettings.php#118 2022-12-13T13:13:52-0500
Error PHP Error: foreach() argument must be of type array|object, null given at /var/www/html/nextcloud/apps/user_saml/lib/SAMLSettings.php#118 2022-12-13T13:13:51-0500
Error PHP Error: foreach() argument must be of type array|object, null given at /var/www/html/nextcloud/apps/user_saml/lib/SAMLSettings.php#118 2022-12-13T13:13:44-0500
'instanceid' => 'oc4******3i',
'passwordsalt' => '5Hmt8cX8*******xqA888888',
'secret' => 'ofxh9p8FuG***************U/Wl/t5AkPomdV',
0 => 'x.x.x.x',
'datadirectory' => '/var/www/html/nextcloud/data',
'version' => '25.0.2.3',
'overwrite.cli.url' => 'http://x.x.x.x',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => 'mysqladmin',
'dbpassword' => 'password',
PASTE HERE
PASTE HERE
PASTE HERE
