Guests application: prevent guests from accessing and changing their personal information
Context
  • Nextcloud Server version:
    • Nextcloud Hub 10 (31.0.8) (31.0.8)
    • Ubuntu 24.04 LTS
  • Web server and version:
    • Apache/2.4.58 (Ubuntu)
  • Reverse proxy and version:
    • nginx/1.29.1
  • PHP version:
    • Selected in HestiaCP: 8.3, reported by Nextcloud: 8.2.29
  • Installation method:
    • manual on a VPS on top of the **Hestia Control Panel**
    • Cloudflare yes, but proxy is off for the A record
      mod_security is not loaded in Apache
Apache with Nginx
Nextcloud configuration
Contents of config.php:
  'instanceid' => 'oc4plhmtku49',
  'instanceid' => '***********9',
  'passwordsalt' => 'Y***************************OE',
  'secret' => 'T**********************************************I',
    0 => 'server.subdomain.tld',
  'datadirectory' => '/home/hestia_user/web/server.subdomain.tld/public_html/data',
  'version' => '31.0.8.1',
  'overwrite.cli.url' => 'https://server.subdomain.tld',
  'dbname' => 'nc_db',
  'dbhost' => 'localhost',
  'dbuser' => 'db_usr',
  'dbpassword' => 'jlsdflsdhfsl',
  'app_install_overwrite' =>
The output of occ app:list:
  • activity: 4.0.0
  • app_api: 5.0.2
  • bruteforcesettings: 4.0.0
  • circles: 31.0.0
  • comments: 1.21.0
  • contactsinteraction: 1.12.0
  • dashboard: 7.11.0
  • dav: 1.33.0
  • federation: 1.21.0
  • files: 2.3.1
  • files_downloadlimit: 4.0.0
  • files_pdfviewer: 4.0.0
  • files_reminders: 1.4.0
  • files_sharing: 1.23.1
  • files_trashbin: 1.21.0
  • files_versions: 1.24.0
  • firstrunwizard: 4.0.0
  • guests: 4.5.1
  • logreader: 4.0.0
  • notifications: 4.0.0
  • oauth2: 1.19.1
  • password_policy: 3.0.0
  • privacy: 3.0.0
  • profile: 1.0.0
  • provisioning_api: 1.21.0
  • recommendations: 4.0.0
  • related_resources: 2.0.0
  • serverinfo: 3.0.0
  • settings: 1.14.0
  • sharebymail: 1.21.0
  • support: 3.0.0
  • survey_client: 3.0.0
  • systemtags: 1.21.1
  • text: 5.0.0
  • theming: 2.6.1
  • updatenotification: 1.21.0
  • user_status: 1.11.0
  • viewer: 4.0.0
  • webhook_listeners: 1.2.0
  • workflowengine: 2.13.0
  • admin_audit: 1.21.0
  • cfg_share_links: 7.0.1
  • encryption: 2.19.0
  • files_external: 1.23.0
  • photos: 4.0.0 (installed 4.0.0)
  • suspicious_login: 9.0.1
  • user_ldap: 1.22.0
  • weather_status: 1.11.0 (installed 1.11.0)
Summary
I would like to publish a large directory with multimedia (1TB) and make it available to the public, while allowing the following functions:
  • search
  • bulk download
This would be something like Proton Drive or Google Drive.
For the moment I am considering Nextcloud, but I am quite aware that this might not be the best platform for this.
Unfortunately, unauthenticated Nextcloud users cannot search shared public directories.
The only alternative on Nextcloud I could think of was the Guests application.
So far I created a single guest user called Guest, with the help fo the php occ guests:add command. My idea is to share its credentials with the public. Another user, a normal one, already shared a certain Public directory with the Guest user and that works.
Now I need to prevent anybody logging in with the Guest user from:
  • locking other users out by changing the password or e-mail address etc. of the Guest user
  • abusing the server, by initiating the download of very large amounts of data via the web interface
So I’ve been trying to prevent the Guest user from accessing its Profile > Settings page, in particular its Personal Info and Security pages. Is this even possible?
Any other ideas are welcome.
Thank you.
