Inside a groupfolder, I have 15 subfolders. For these folders one single user should have access.
Visibility should also be limited, each user must only see his folder.
Can this be done ?
cheers … juerg
Can this be done ?
cheers … juerg
See the response from user Daksol (me) in this Issue on Github. The approach described there should work for you.
