Hey,
um sicher zu gehen mach ich nach jeder Änderung einen Reboot.
Hier die phpinfo:
root@raspberrypinext:~# php -i
phpinfo()
PHP Version => 7.3.19-1~deb10u1
System => Linux raspberrypinext 5.4.51-v7l+ #1333 SMP Mon Aug 10 16:51:40 BST 20 20 armv7l
Build Date => Jul 5 2020 06:46:45
Server API => Command Line Interface
Virtual Directory Support => disabled
Configuration File (php.ini) Path => /etc/php/7.3/cli
Loaded Configuration File => /etc/php/7.3/cli/php.ini
Scan this dir for additional .ini files => /etc/php/7.3/cli/conf.d
Additional .ini files parsed => /etc/php/7.3/cli/conf.d/10-mysqlnd.ini,
/etc/php/7.3/cli/conf.d/10-opcache.ini,
/etc/php/7.3/cli/conf.d/10-pdo.ini,
/etc/php/7.3/cli/conf.d/15-xml.ini,
/etc/php/7.3/cli/conf.d/20-apcu.ini,
/etc/php/7.3/cli/conf.d/20-bcmath.ini,
/etc/php/7.3/cli/conf.d/20-calendar.ini,
/etc/php/7.3/cli/conf.d/20-ctype.ini,
/etc/php/7.3/cli/conf.d/20-curl.ini,
/etc/php/7.3/cli/conf.d/20-dom.ini,
/etc/php/7.3/cli/conf.d/20-exif.ini,
/etc/php/7.3/cli/conf.d/20-fileinfo.ini,
/etc/php/7.3/cli/conf.d/20-ftp.ini,
/etc/php/7.3/cli/conf.d/20-gd.ini,
/etc/php/7.3/cli/conf.d/20-gettext.ini,
/etc/php/7.3/cli/conf.d/20-gmp.ini,
/etc/php/7.3/cli/conf.d/20-iconv.ini,
/etc/php/7.3/cli/conf.d/20-imagick.ini,
/etc/php/7.3/cli/conf.d/20-intl.ini,
/etc/php/7.3/cli/conf.d/20-json.ini,
/etc/php/7.3/cli/conf.d/20-mbstring.ini,
/etc/php/7.3/cli/conf.d/20-mysqli.ini,
/etc/php/7.3/cli/conf.d/20-pdo_mysql.ini,
/etc/php/7.3/cli/conf.d/20-pdo_pgsql.ini,
/etc/php/7.3/cli/conf.d/20-pdo_sqlite.ini,
/etc/php/7.3/cli/conf.d/20-pgsql.ini,
/etc/php/7.3/cli/conf.d/20-phar.ini,
/etc/php/7.3/cli/conf.d/20-posix.ini,
/etc/php/7.3/cli/conf.d/20-readline.ini,
/etc/php/7.3/cli/conf.d/20-shmop.ini,
/etc/php/7.3/cli/conf.d/20-simplexml.ini,
/etc/php/7.3/cli/conf.d/20-sockets.ini,
/etc/php/7.3/cli/conf.d/20-sqlite3.ini,
/etc/php/7.3/cli/conf.d/20-sysvmsg.ini,
/etc/php/7.3/cli/conf.d/20-sysvsem.ini,
/etc/php/7.3/cli/conf.d/20-sysvshm.ini,
/etc/php/7.3/cli/conf.d/20-tokenizer.ini,
/etc/php/7.3/cli/conf.d/20-wddx.ini,
/etc/php/7.3/cli/conf.d/20-xmlreader.ini,
/etc/php/7.3/cli/conf.d/20-xmlwriter.ini,
/etc/php/7.3/cli/conf.d/20-xsl.ini,
/etc/php/7.3/cli/conf.d/20-zip.ini,
/etc/php/7.3/cli/conf.d/25-apcu_bc.ini
PHP API => 20180731
PHP Extension => 20180731
Zend Extension => 320180731
Zend Extension Build => API320180731,NTS
PHP Extension Build => API20180731,NTS
Debug Build => no
Thread Safety => disabled
Zend Signal Handling => enabled
Zend Memory Manager => enabled
Zend Multibyte Support => provided by mbstring
IPv6 Support => enabled
DTrace Support => available, disabled
Registered PHP Streams => https, ftps, compress.zlib, php, file, glob, data, htt p, ftp, zip, phar
Registered Stream Socket Transports => tcp, udp, unix, udg, ssl, tls, tlsv1.0, t lsv1.1, tlsv1.2
Registered Stream Filters => zlib.*, string.rot13, string.toupper, string.tolowe r, string.strip_tags, convert.*, consumed, dechunk, convert.iconv.*
This program makes use of the Zend Scripting Language Engine:
Zend Engine v3.3.19, Copyright (c) 1998-2018 Zend Technologies
with Zend OPcache v7.3.19-1~deb10u1, Copyright (c) 1999-2018, by Zend Techno logies
_______________________________________________________________________
apc
APC Compatibility => 1.0.4
APCu Version => 5.1.17
Build Date => Nov 4 2018 04:16:28
apcu
APCu Support => Disabled
Version => 5.1.17
APCu Debugging => Disabled
MMAP Support => Enabled
MMAP File Mask =>
Serialization Support => Disabled
Build Date => Feb 8 2019 16:18:59
Directive => Local Value => Master Value
apc.coredump_unmap => Off => Off
apc.enable_cli => Off => Off
apc.enabled => On => On
apc.entries_hint => 4096 => 4096
apc.gc_ttl => 3600 => 3600
apc.mmap_file_mask => no value => no value
apc.preload_path => no value => no value
apc.serializer => php => php
apc.shm_segments => 1 => 1
apc.shm_size => 32M => 32M
apc.slam_defense => Off => Off
apc.smart => 0 => 0
apc.ttl => 0 => 0
apc.use_request_time => On => On
bcmath
BCMath support => enabled
bcmath.scale => 0 => 0
calendar
Calendar support => enabled
Core
allow_url_fopen => On => On
allow_url_include => Off => Off
arg_separator.input => & => &
arg_separator.output => & => &
auto_append_file => no value => no value
auto_globals_jit => On => On
auto_prepend_file => no value => no value
browscap => no value => no value
default_charset => UTF-8 => UTF-8
default_mimetype => text/html => text/html
disable_classes => no value => no value
disable_functions => no value => no value
display_errors => STDOUT => STDOUT
display_startup_errors => Off => Off
doc_root => no value => no value
docref_ext => no value => no value
docref_root => no value => no value
enable_dl => On => On
enable_post_data_reading => On => On
error_append_string => no value => no value
error_log => no value => no value
error_prepend_string => no value => no value
error_reporting => no value => no value
expose_php => On => On
extension_dir => /usr/lib/php/20180731 => /usr/lib/php/20180731
file_uploads => On => On
hard_timeout => 2 => 2
highlight.comment => <font style="color: #FF8000">#FF8000</font> => <font style= "color: #FF8000">#FF8000</font>
highlight.default => <font style="color: #0000BB">#0000BB</font> => <font style= "color: #0000BB">#0000BB</font>
highlight.html => <font style="color: #000000">#000000</font> => <font style="co lor: #000000">#000000</font>
highlight.keyword => <font style="color: #007700">#007700</font> => <font style= "color: #007700">#007700</font>
highlight.string => <font style="color: #DD0000">#DD0000</font> => <font style=" color: #DD0000">#DD0000</font>
html_errors => Off => Off
ignore_repeated_errors => Off => Off
ignore_repeated_source => Off => Off
ignore_user_abort => Off => Off
implicit_flush => On => On
include_path => .:/usr/share/php => .:/usr/share/php
input_encoding => no value => no value
internal_encoding => no value => no value
log_errors => Off => Off
log_errors_max_len => 1024 => 1024
mail.add_x_header => Off => Off
mail.force_extra_parameters => no value => no value
mail.log => no value => no value
max_execution_time => 0 => 0
max_file_uploads => 20 => 20
max_input_nesting_level => 64 => 64
max_input_time => -1 => -1
max_input_vars => 1000 => 1000
memory_limit => 128M => 128M
open_basedir => no value => no value
output_buffering => 0 => 0
output_encoding => no value => no value
output_handler => no value => no value
post_max_size => 8M => 8M
precision => 14 => 14
realpath_cache_size => 4096K => 4096K
realpath_cache_ttl => 120 => 120
register_argc_argv => On => On
report_memleaks => On => On
report_zend_debug => Off => Off
request_order => no value => no value
sendmail_from => no value => no value
sendmail_path => /usr/sbin/sendmail -t -i => /usr/sbin/sendmail -t -i
serialize_precision => -1 => -1
short_open_tag => On => On
SMTP => localhost => localhost
smtp_port => 25 => 25
sys_temp_dir => no value => no value
syslog.facility => LOG_USER => LOG_USER
syslog.filter => no-ctrl => no-ctrl
syslog.ident => php => php
track_errors => Off => Off
unserialize_callback_func => no value => no value
upload_max_filesize => 2M => 2M
upload_tmp_dir => no value => no value
user_dir => no value => no value
user_ini.cache_ttl => 300 => 300
user_ini.filename => .user.ini => .user.ini
variables_order => EGPCS => EGPCS
xmlrpc_error_number => 0 => 0
xmlrpc_errors => Off => Off
zend.assertions => 1 => 1
zend.detect_unicode => On => On
zend.enable_gc => On => On
zend.multibyte => Off => Off
zend.script_encoding => no value => no value
zend.signal_check => Off => Off
ctype
ctype functions => enabled
curl
cURL support => enabled
cURL Information => 7.64.0
Age => 4
Features
AsynchDNS => Yes
CharConv => No
Debug => No
GSS-Negotiate => No
IDN => Yes
IPv6 => Yes
krb4 => No
Largefile => Yes
libz => Yes
NTLM => Yes
NTLMWB => Yes
SPNEGO => Yes
SSL => Yes
SSPI => No
TLS-SRP => Yes
HTTP2 => Yes
GSSAPI => Yes
KERBEROS5 => Yes
UNIX_SOCKETS => Yes
PSL => Yes
HTTPS_PROXY => Yes
MULTI_SSL => No
BROTLI => No
Protocols => dict, file, ftp, ftps, gopher, http, https, imap, imaps, ldap, ldap s, pop3, pop3s, rtmp, rtsp, scp, sftp, smb, smbs, smtp, smtps, telnet, tftp
Host => arm-unknown-linux-gnueabihf
SSL Version => OpenSSL/1.1.1d
ZLib Version => 1.2.11
libSSH Version => libssh2/1.8.0
curl.cainfo => no value => no value
date
date/time support => enabled
timelib version => 2018.03
"Olson" Timezone Database Version => 0.system
Timezone Database => internal
Default timezone => Europe/Berlin
date.default_latitude => 31.7667 => 31.7667
date.default_longitude => 35.2333 => 35.2333
date.sunrise_zenith => 90.583333 => 90.583333
date.sunset_zenith => 90.583333 => 90.583333
date.timezone => no value => no value
dom
DOM/XML => enabled
DOM/XML API Version => 20031129
libxml Version => 2.9.4
HTML Support => enabled
XPath Support => enabled
XPointer Support => enabled
Schema Support => enabled
RelaxNG Support => enabled
exif
EXIF Support => enabled
Supported EXIF Version => 0220
Supported filetypes => JPEG, TIFF
Multibyte decoding support using mbstring => enabled
Extended EXIF tag formats => Canon, Casio, Fujifilm, Nikon, Olympus, Samsung, Pa nasonic, DJI, Sony, Pentax, Minolta, Sigma, Foveon, Kyocera, Ricoh, AGFA, Epson
exif.decode_jis_intel => JIS => JIS
exif.decode_jis_motorola => JIS => JIS
exif.decode_unicode_intel => UCS-2LE => UCS-2LE
exif.decode_unicode_motorola => UCS-2BE => UCS-2BE
exif.encode_jis => no value => no value
exif.encode_unicode => ISO-8859-15 => ISO-8859-15
fileinfo
fileinfo support => enabled
libmagic => 533
filter
Input Validation and Filtering => enabled
filter.default => unsafe_raw => unsafe_raw
filter.default_flags => no value => no value
ftp
FTP support => enabled
FTPS support => enabled
gd
GD Support => enabled
GD headers Version => 2.2.5
GD library Version => 2.2.5
FreeType Support => enabled
FreeType Linkage => with freetype
FreeType Version => 2.9.1
GIF Read Support => enabled
GIF Create Support => enabled
JPEG Support => enabled
libJPEG Version => 6b
PNG Support => enabled
libPNG Version => 1.6.36
WBMP Support => enabled
XPM Support => enabled
libXpm Version => 30411
XBM Support => enabled
WebP Support => enabled
gd.jpeg_ignore_warning => 1 => 1
gettext
GetText Support => enabled
gmp
gmp support => enabled
GMP version => 6.1.2
hash
hash support => enabled
Hashing Engines => md2 md4 md5 sha1 sha224 sha256 sha384 sha512/224 sha512/256 s ha512 sha3-224 sha3-256 sha3-384 sha3-512 ripemd128 ripemd160 ripemd256 ripemd32 0 whirlpool tiger128,3 tiger160,3 tiger192,3 tiger128,4 tiger160,4 tiger192,4 sn efru snefru256 gost gost-crypto adler32 crc32 crc32b fnv132 fnv1a32 fnv164 fnv1a 64 joaat haval128,3 haval160,3 haval192,3 haval224,3 haval256,3 haval128,4 haval 160,4 haval192,4 haval224,4 haval256,4 haval128,5 haval160,5 haval192,5 haval224 ,5 haval256,5
MHASH support => Enabled
MHASH API Version => Emulated Support
iconv
iconv support => enabled
iconv implementation => glibc
iconv library version => 2.28
iconv.input_encoding => no value => no value
iconv.internal_encoding => no value => no value
iconv.output_encoding => no value => no value
imagick
imagick module => enabled
imagick module version => 3.4.3
imagick classes => Imagick, ImagickDraw, ImagickPixel, ImagickPixelIterator, Ima gickKernel
Imagick compiled with ImageMagick version => ImageMagick 6.9.10-23 Q16 x86_64 20 190101 https://imagemagick.org
Imagick using ImageMagick library version => ImageMagick 6.9.10-23 Q16 arm 20190 101 https://imagemagick.org
ImageMagick copyright => © 1999-2019 ImageMagick Studio LLC
ImageMagick release date => 20190101
ImageMagick number of supported formats: => 242
ImageMagick supported formats => 3FR, 3G2, 3GP, AAI, AI, ART, ARW, AVI, AVS, BGR , BGRA, BGRO, BIE, BMP, BMP2, BMP3, BRF, CAL, CALS, CANVAS, CAPTION, CIN, CIP, C LIP, CMYK, CMYKA, CR2, CRW, CUR, CUT, DATA, DCM, DCR, DCX, DDS, DFONT, DJVU, DNG , DOT, DPX, DXT1, DXT5, EPDF, EPI, EPS, EPS2, EPS3, EPSF, EPSI, EPT, EPT2, EPT3, ERF, EXR, FAX, FILE, FITS, FRACTAL, FTP, FTS, G3, G4, GIF, GIF87, GRADIENT, GRA Y, GRAYA, GROUP4, GV, H, HALD, HDR, HEIC, HISTOGRAM, HRZ, HTM, HTML, HTTP, HTTPS , ICB, ICO, ICON, IIQ, INFO, INLINE, IPL, ISOBRL, ISOBRL6, J2C, J2K, JBG, JBIG, JNG, JNX, JP2, JPC, JPE, JPEG, JPG, JPM, JPS, JPT, JSON, K25, KDC, LABEL, M2V, M 4V, MAC, MAGICK, MAP, MASK, MAT, MATTE, MEF, MIFF, MKV, MNG, MONO, MOV, MP4, MPC , MPEG, MPG, MRW, MSL, MSVG, MTV, MVG, NEF, NRW, NULL, ORF, OTB, OTF, PAL, PALM, PAM, PANGO, PATTERN, PBM, PCD, PCDS, PCL, PCT, PCX, PDB, PDF, PDFA, PEF, PES, P FA, PFB, PFM, PGM, PGX, PICON, PICT, PIX, PJPEG, PLASMA, PNG, PNG00, PNG24, PNG3 2, PNG48, PNG64, PNG8, PNM, PPM, PREVIEW, PS, PS2, PS3, PSB, PSD, PTIF, PWP, RAD IAL-GRADIENT, RAF, RAS, RAW, RGB, RGBA, RGBO, RGF, RLA, RLE, RMF, RW2, SCR, SCT, SFW, SGI, SHTML, SIX, SIXEL, SPARSE-COLOR, SR2, SRF, STEGANO, SUN, SVG, SVGZ, T EXT, TGA, THUMBNAIL, TIFF, TIFF64, TILE, TIM, TTC, TTF, TXT, UBRL, UBRL6, UIL, U YVY, VDA, VICAR, VID, VIFF, VIPS, VST, WBMP, WEBP, WMF, WMV, WMZ, WPG, X, X3F, X BM, XC, XCF, XPM, XPS, XV, XWD, YCbCr, YCbCrA, YUV
imagick.locale_fix => 0 => 0
imagick.progress_monitor => 0 => 0
imagick.skip_version_check => 1 => 1
intl
Internationalization support => enabled
ICU version => 63.1
ICU Data version => 63.1
ICU TZData version => 2018e
ICU Unicode version => 11.0
intl.default_locale => no value => no value
intl.error_level => 0 => 0
intl.use_exceptions => 0 => 0
json
json support => enabled
json version => 1.7.0
libxml
libXML support => active
libXML Compiled Version => 2.9.4
libXML Loaded Version => 20904
libXML streams => enabled
mbstring
Multibyte Support => enabled
Multibyte string engine => libmbfl
HTTP input encoding translation => disabled
libmbfl version => 1.3.2
oniguruma version => 6.9.4
mbstring extension makes use of "streamable kanji code filter and converter", wh ich is distributed under the GNU Lesser General Public License version 2.1.
Multibyte (japanese) regex support => enabled
Multibyte regex (oniguruma) backtrack check => On
Multibyte regex (oniguruma) version => 6.9.4
mbstring.detect_order => no value => no value
mbstring.encoding_translation => Off => Off
mbstring.func_overload => 0 => 0
mbstring.http_input => no value => no value
mbstring.http_output => no value => no value
mbstring.http_output_conv_mimetypes => ^(text/|application/xhtml\+xml) => ^(text /|application/xhtml\+xml)
mbstring.internal_encoding => no value => no value
mbstring.language => neutral => neutral
mbstring.regex_stack_limit => 100000 => 100000
mbstring.strict_detection => Off => Off
mbstring.substitute_character => no value => no value
mysqli
MysqlI Support => enabled
Client API library version => mysqlnd 5.0.12-dev - 20150407 - $Id: 7cc7cc96e675f 6d72e5cf0f267f48e167c2abb23 $
Active Persistent Links => 0
Inactive Persistent Links => 0
Active Links => 0
mysqli.allow_local_infile => Off => Off
mysqli.allow_persistent => On => On
mysqli.default_host => no value => no value
mysqli.default_port => 3306 => 3306
mysqli.default_pw => no value => no value
mysqli.default_socket => no value => no value
mysqli.default_user => no value => no value
mysqli.max_links => Unlimited => Unlimited
mysqli.max_persistent => Unlimited => Unlimited
mysqli.reconnect => Off => Off
mysqli.rollback_on_cached_plink => Off => Off
mysqlnd
mysqlnd => enabled
Version => mysqlnd 5.0.12-dev - 20150407 - $Id: 7cc7cc96e675f6d72e5cf0f267f48e16 7c2abb23 $
Compression => supported
core SSL => supported
extended SSL => supported
Command buffer size => 4096
Read buffer size => 32768
Read timeout => 86400
Collecting statistics => Yes
Collecting memory statistics => No
Tracing => n/a
Loaded plugins => mysqlnd,debug_trace,auth_plugin_mysql_native_password,auth_plu gin_mysql_clear_password,auth_plugin_sha256_password
API Extensions => mysqli,pdo_mysql
ich hab die php.ini im CLI Ordner mit den gleichen Werten wie unetr apache2 verändert.
Wenn ich eine größer Datei (ca. 8 GB) hochlade dann bekomm ich im Browser UI unter Benachrichungen die Mitteilung das die “chunks nicht zusammengesetzt werden konnten. Fehlermeldung:0”
Die Datei erscheint dann einfach nicht im Ordner.
Im Protokoll erscheint aber kein Fehler mehr. Die heruntergeladenen Ordner (6 GB) die als ZIP archive bei mir landen sind immernoch defekt.
