I have a server with both nextcloud and Kodi running.
I was thinking about giving read-access rights to kodi to certain unencrypted folders of the nextcloud data.
But I first wanted to be sure it wont break my server/database.
Anyone has already tried it?
I know it works with WebDAV, Except it takes much more time to load files to play.
That is the main reason I am looking for a solution.
To my knowledge there is no direct problem of giving only read access to the folder I want Kodi to be able to read.
But as I’m not sure of this I want to know if anyone has already tried it out.
If it’s read only then it shouldn’t hurt anything, but Kodi may see some of Nextcloud’s data files if there are any there.
Just to throw out another option, you can set up a local folder as external storage in Nextcloud and have Kodi also access that folder. Then it could safely have write access if needed.
So I tried this one, and it works, Kind of, but not exactly.
I made a groupfolder structure in but if I mount the __groupfolder to the /media/kodi/folder there is nothing in there.
