I’ve raised two reproducible issues on GitHub 2 months ago. Both went stale for the second time now, without anyone at least acknowledging them. Can someone please ping somebody from the team to look into it?
You can reply to the issues if you want to keep them open. Just reply “open please” to the email notification, or on github. Nothing else we can do, because the team makes no guarantees on addressing our issues.
I replied to the issues both times I got the notification. The first time it worked, and the bot removed the stable label. This time it didn’t care and closed both issues anyway 30 minutes ago. “open please” does not work.
Both issues should receive the teams’ attention since #4304 makes your PC unresponsive and #4306 prevents issues from being reported on GitHub.
So this issue still persists. The GitHub bot is being relatively useless, since it closes issues even if you reply.
Should I write my own bot that just comments the date daily into my issues, or just not report issues at all? To make it clear: I’m not asking anyone to work on them right away. Just some acknowledgement so these valid issues are not lost. And the bot stops closing them.
A bot doing wild things and no way to contact anyone responsible.
Valid issues “vanishing” due to a wild bot. And apparently nobody from the internal team is at least skimming through issues on a regular basis to assign or sort them. Seems to me like a process that should see some improvement on the Devs side.
Out of curiosity, I just checked on GitHub again: 595 closed tickets with the stale label. And many of them seems similar to what I’ve described.
