example
longer
example
here
Nextcloud version: 19.0.5
Operating system and version: Centos 7.8
Apache or nginx version: Apache/2.4
PHP version: 7.4
MariaDB: 10.3
The issue I am facing:
In time I’m accessing as user admin the APP Flow in Settings under the Administration I get following Errors. …under Personal it seems to work.
Error jsresourceloader Could not find resource core/js/systemtags/systemtagscollection.js to load
2021-01-05T12:47:56+0100
Error jsresourceloader Could not find resource core/js/systemtags/systemtagmodel.js to load
Error jsresourceloader Could not find resource core/js/systemtags/systemtags.js to load
Error jsresourceloader Could not find resource core/js/oc-backbone-webdav.js to load
But after upgrade to NC 20 it’s still there
- NC Logon as admin
- open Settings
- goto Administration
- start the app Flow
- check the Logging
{"reqId":"SEEMS-TO-BE-A-SECRET","level":3,"time":"2021-01-05T11:40:33+00:00","remoteAddr":"1111:222:333:4444:5555:6666:7777:8888","user":"user","app":"jsresourceloader","method":"GET","url":"/nextcloud/index.php/settings/admin/workflow","message":"Could not find resource core/js/oc-backbone-webdav.js to load","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:84.0) Gecko/20100101 Firefox/84.0","version":"20.0.4.0"}
{"reqId":"SEEMS-TO-BE-A-SECRET","level":3,"time":"2021-01-05T11:40:33+00:00","remoteAddr":"1111:222:333:4444:5555:6666:7777:8888","user":"user","app":"jsresourceloader","method":"GET","url":"/nextcloud/index.php/settings/admin/workflow","message":"Could not find resource core/js/systemtags/systemtags.js to load","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:84.0) Gecko/20100101 Firefox/84.0","version":"20.0.4.0"}
{"reqId":"SEEMS-TO-BE-A-SECRET","level":3,"time":"2021-01-05T11:40:33+00:00","remoteAddr":"1111:222:333:4444:5555:6666:7777:8888","user":"user","app":"jsresourceloader","method":"GET","url":"/nextcloud/index.php/settings/admin/workflow","message":"Could not find resource core/js/systemtags/systemtagmodel.js to load","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:84.0) Gecko/20100101 Firefox/84.0","version":"20.0.4.0"}
{"reqId":"SEEMS-TO-BE-A-SECRET","level":3,"time":"2021-01-05T11:40:33+00:00","remoteAddr":"1111:222:333:4444:5555:6666:7777:8888","user":"user","app":"jsresourceloader","method":"GET","url":"/nextcloud/index.php/settings/admin/workflow","message":"Could not find resource core/js/systemtags/systemtagscollection.js to load","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:84.0) Gecko/20100101 Firefox/84.0","version":"20.0.4.0"}
'instanceid' => 'abcdefghij',
'passwordsalt' => 'ITSSOSECRET',
'secret' => 'ITSANOTHERSECRET',
0 => 'domain.org',
'datadirectory' => '/var/www/virtual/user/nextcloud_data',
'version' => '20.0.4.0',
'overwrite.cli.url' => 'https://domain.org/nextcloud',
'dbname' => 'DB_user_nextcloud',
'dbhost' => 'localhost',
'dbuser' => 'DB_user',
'dbpassword' => 'SECRET',
'theme' => '',
'loglevel' => 2,
'mail_from_address' => 'mailuser',
'mail_smtpmode' => 'smtp',
'mail_domain' => 'domain.org',
'mail_smtpauth' => 1,
'mail_smtphost' => 'mail.domain.org',
'mail_smtpport' => '587',
'mail_smtpname' => 'smtp_name',
'mail_smtppassword' => 'mail_secret',
'app_install_overwrite' =>
0 => 'files_external',
'data-fingerprint' => 'a2a2a2a2a2a2a2a2a2a2a2a2a2a2a2a',
'updater.secret' => '!w34!"WD4!ED&%5665trzdftre4w43"§$"54e%RE$%',
'encryption.legacy_format_support' => false,
'encryption.key_storage_migrated' => false,
Is there any I can do?
In other words, what does it mean and have I to do anything here.
What is not working?
May it relay on statement in config.php
I do not understand what fore it is?
