Nextcloud version (eg, 20.0.5): 25.0.2
Operating System: Linux 5.15.69-grsec-kapsi x86_64
CPU: Intel Xeon E312xx (Sandy Bridge) (12 cores)
Memory: 31.32 GB
Webserver: Apache 2.4
PHP
Version: 8.0.26
Memory limit: 512 MB
Max execution time: 3600
Upload max size: 256 MB
Extensions: Core, date, libxml, openssl, pcre, zlib, filter, hash, json, Reflection, SPL, session, standard, sodium, cgi-fcgi, mysqlnd, PDO, xml, bcmath, calendar, ctype, curl, dom, enchant, mbstring, FFI, fileinfo, ftp, gd, gettext, gmp, iconv, igbinary, imagick, imap, intl, ldap, exif, mysqli, pdo_mysql, pdo_pgsql, pdo_sqlite, pgsql, Phar, posix, readline, redis, shmop, SimpleXML, soap, sockets, sqlite3, sysvmsg, sysvsem, sysvshm, tidy, tokenizer, xmlreader, xmlwriter, xsl, zip, Zend OPcache
Shared server environment. I’ve used Nextcloud there since 1x versions, but recently (in some 2-3 months) the web interface has gotten really slow. Can’t tell exactly when as I mostly just sync my pictures there with mobile app. Support didn’t really have any ideas on what to check (“oh, php”).
So I’m turning towards the community incase you could come up with ideas for me or to persons running the servers.
There is no redis, nor will one become available.
So the issue: slowness.
From the same server environment where my nextcloud is, fetchin login page with wget: 3-5 seconds. Example:
[-bash]:~$>time wget -o /dev/null https://mycloud.patanen.com/index.php/login
real 0m5.705s
user 0m0.008s
sys 0m0.008s
With a browser, if I create a simple “hello world” page within the nextcloud page, fetching that page takes few milliseconds, but on the other hand the fetch of /index.php/apps/dashboard/ takes 1+ second as shown on the browser console/developer tools.
for the heck of it, I also installed profiler (btw above figures are without profiler) to see if I get anythiong out of it. Well, I got nothing, but perhaps you can tell somehing based on this:
Fetching /index.php/apps/files/ - 3458ms
Db query 115
Events (just listing the slow ones)
Time | Description | |
boot | 1191.9 ms (Start: 83.2068920135498, End: 1275.0771045684814) | Initialize |
init | 1275.1 ms (Start: 0, End: 1275.0840187072754) | OC::init |
runtime | 2183.7 ms (Start: 1275.0890254974365, End: 3458.806037902832) | Runtime |
request | 2191.4 ms (Start: 1275.089979171753, End: 3458.806037902832) | Full request after boot |
handle_request | 2191.2 ms (Start: 1275.2079963684082, End: 3458.806037902832) | Handle request |
loadroutesfiles | 16.5 ms (Start: 1664.6339893341064, End: 1681.0970306396484) | Loading Routes |
run_route | 1773.9 ms (Start: 1692.573070526123, End: 3458.806037902832) | Run route |
setup_root_fs | 6.8 ms (Start: 1854.9480438232422, End: 1861.7680072784424) | Setup root filesystem |
setup_fs | 346.1 ms (Start: 2025.6259441375732, End: 2371.7329502105713) | Setup filesystem |
Any pointers and ideas are welcome. Currently my site is almost unbrowseable.
