Since the GDPE is now an issue ( and it is good that it exists ) there is one issue i would like to have addressed, or solved, the latter would be definitely a boon:
right now, when i prepare to share a file, and i enter the name into the search box, i see something like the following:
entering a piece of the name, like “muster” i get a result like:
Max Mustermann (mustermann@tugraz.at)
now i can change the 2nd part ( the email in this case to something else ),
which is exactly the way it is meant to be. however, additionally, if i move the mouse over the entry in the list, i also get the internal username hovering above ( like m.muster ). is there a way to stop showing the internal username which is pulled from our ldap-server.
an option to switch the hover/mouseover off, or to be able to show some other attribute would be very good.
the issue is less for our own service, but for the federated searches.
