Fulltextsearch container won't start
I am installing the all in one docker image and everything worked fine until I decided to enable the Fulltextsearch addons (which I activated via the AIO web interface by checking the corresponding box). When I open the logs of the corresponding container, the following error won’t stop printing again and again :
{"type": "server", "timestamp": "2023-02-19T19:30:12,885+01:00", "level": "INFO", "component": "o.e.n.Node", "cluster.name": "docker-cluster", "node.name": "eb31b1b69b22", "message": "version[7.17.9], pid[10], build[default/docker/ef48222227ee6b9e70e502f0f0daa52435ee634d/2023-01-31T05:34:43.305517834Z], OS[Linux/5.15.0-60-generic/amd64], JVM[Oracle Corporation/OpenJDK 64-Bit Server VM/19.0.2/19.0.2+7-44]" }
{"type": "server", "timestamp": "2023-02-19T19:30:12,891+01:00", "level": "INFO", "component": "o.e.n.Node", "cluster.name": "docker-cluster", "node.name": "eb31b1b69b22", "message": "JVM home [/usr/share/elasticsearch/jdk], using bundled JDK [true]" }
{"type": "server", "timestamp": "2023-02-19T19:30:12,892+01:00", "level": "INFO", "component": "o.e.n.Node", "cluster.name": "docker-cluster", "node.name": "eb31b1b69b22", "message": "JVM arguments [-Xshare:auto, -Des.networkaddress.cache.ttl=60, -Des.networkaddress.cache.negative.ttl=10, -XX:+AlwaysPreTouch, -Xss1m, -Djava.awt.headless=true, -Dfile.encoding=UTF-8, -Djna.nosys=true, -XX:-OmitStackTraceInFastThrow, -XX:+ShowCodeDetailsInExceptionMessages, -Dio.netty.noUnsafe=true, -Dio.netty.noKeySetOptimization=true, -Dio.netty.recycler.maxCapacityPerThread=0, -Dio.netty.allocator.numDirectArenas=0, -Dlog4j.shutdownHookEnabled=false, -Dlog4j2.disable.jmx=true, -Dlog4j2.formatMsgNoLookups=true, -Djava.locale.providers=SPI,COMPAT, --add-opens=java.base/java.io=ALL-UNNAMED, -Djava.security.manager=allow, -XX:+UseG1GC, -Djava.io.tmpdir=/tmp/elasticsearch-10759558789316526557, -XX:+HeapDumpOnOutOfMemoryError, -XX:+ExitOnOutOfMemoryError, -XX:HeapDumpPath=data, -XX:ErrorFile=logs/hs_err_pid%p.log, -Xlog:gc*,gc+age=trace,safepoint:file=logs/gc.log:utctime,pid,tags:filecount=32,filesize=64m, -Des.cgroups.hierarchy.override=/, -Xms1024M, -Xmx1024M, -XX:MaxDirectMemorySize=536870912, -XX:G1HeapRegionSize=4m, -XX:InitiatingHeapOccupancyPercent=30, -XX:G1ReservePercent=15, -Des.path.home=/usr/share/elasticsearch, -Des.path.conf=/usr/share/elasticsearch/config, -Des.distribution.flavor=default, -Des.distribution.type=docker, -Des.bundled_jdk=true]" }
{"type": "server", "timestamp": "2023-02-19T19:30:16,523+01:00", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "eb31b1b69b22", "message": "loaded module [aggs-matrix-stats]" }
{"type": "server", "timestamp": "2023-02-19T19:30:16,523+01:00", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "eb31b1b69b22", "message": "loaded module [analysis-common]" }
{"type": "server", "timestamp": "2023-02-19T19:30:16,523+01:00", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "eb31b1b69b22", "message": "loaded module [constant-keyword]" }
{"type": "server", "timestamp": "2023-02-19T19:30:16,524+01:00", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "eb31b1b69b22", "message": "loaded module [frozen-indices]" }
{"type": "server", "timestamp": "2023-02-19T19:30:16,524+01:00", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "eb31b1b69b22", "message": "loaded module [ingest-common]" }
{"type": "server", "timestamp": "2023-02-19T19:30:16,524+01:00", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "eb31b1b69b22", "message": "loaded module [ingest-geoip]" }
{"type": "server", "timestamp": "2023-02-19T19:30:16,525+01:00", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "eb31b1b69b22", "message": "loaded module [ingest-user-agent]" }
{"type": "server", "timestamp": "2023-02-19T19:30:16,525+01:00", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "eb31b1b69b22", "message": "loaded module [kibana]" }
{"type": "server", "timestamp": "2023-02-19T19:30:16,525+01:00", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "eb31b1b69b22", "message": "loaded module [lang-expression]" }
{"type": "server", "timestamp": "2023-02-19T19:30:16,525+01:00", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "eb31b1b69b22", "message": "loaded module [lang-mustache]" }
{"type": "server", "timestamp": "2023-02-19T19:30:16,525+01:00", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "eb31b1b69b22", "message": "loaded module [lang-painless]" }
{"type": "server", "timestamp": "2023-02-19T19:30:16,526+01:00", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "eb31b1b69b22", "message": "loaded module [legacy-geo]" }
{"type": "server", "timestamp": "2023-02-19T19:30:16,526+01:00", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "eb31b1b69b22", "message": "loaded module [mapper-extras]" }
{"type": "server", "timestamp": "2023-02-19T19:30:16,526+01:00", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "eb31b1b69b22", "message": "loaded module [mapper-version]" }
{"type": "server", "timestamp": "2023-02-19T19:30:16,526+01:00", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "eb31b1b69b22", "message": "loaded module [parent-join]" }
{"type": "server", "timestamp": "2023-02-19T19:30:16,527+01:00", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "eb31b1b69b22", "message": "loaded module [percolator]" }
{"type": "server", "timestamp": "2023-02-19T19:30:16,527+01:00", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "eb31b1b69b22", "message": "loaded module [rank-eval]" }
{"type": "server", "timestamp": "2023-02-19T19:30:16,527+01:00", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "eb31b1b69b22", "message": "loaded module [reindex]" }
{"type": "server", "timestamp": "2023-02-19T19:30:16,528+01:00", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "eb31b1b69b22", "message": "loaded module [repositories-metering-api]" }
{"type": "server", "timestamp": "2023-02-19T19:30:16,528+01:00", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "eb31b1b69b22", "message": "loaded module [repository-encrypted]" }
{"type": "server", "timestamp": "2023-02-19T19:30:16,528+01:00", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "eb31b1b69b22", "message": "loaded module [repository-url]" }
{"type": "server", "timestamp": "2023-02-19T19:30:16,528+01:00", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "eb31b1b69b22", "message": "loaded module [runtime-fields-common]" }
{"type": "server", "timestamp": "2023-02-19T19:30:16,529+01:00", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "eb31b1b69b22", "message": "loaded module [search-business-rules]" }
{"type": "server", "timestamp": "2023-02-19T19:30:16,529+01:00", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "eb31b1b69b22", "message": "loaded module [searchable-snapshots]" }
{"type": "server", "timestamp": "2023-02-19T19:30:16,529+01:00", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "eb31b1b69b22", "message": "loaded module [snapshot-repo-test-kit]" }
{"type": "server", "timestamp": "2023-02-19T19:30:16,529+01:00", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "eb31b1b69b22", "message": "loaded module [spatial]" }
{"type": "server", "timestamp": "2023-02-19T19:30:16,529+01:00", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "eb31b1b69b22", "message": "loaded module [transform]" }
{"type": "server", "timestamp": "2023-02-19T19:30:16,530+01:00", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "eb31b1b69b22", "message": "loaded module [transport-netty4]" }
{"type": "server", "timestamp": "2023-02-19T19:30:16,530+01:00", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "eb31b1b69b22", "message": "loaded module [unsigned-long]" }
{"type": "server", "timestamp": "2023-02-19T19:30:16,530+01:00", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "eb31b1b69b22", "message": "loaded module [vector-tile]" }
{"type": "server", "timestamp": "2023-02-19T19:30:16,530+01:00", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "eb31b1b69b22", "message": "loaded module [vectors]" }
{"type": "server", "timestamp": "2023-02-19T19:30:16,531+01:00", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "eb31b1b69b22", "message": "loaded module [wildcard]" }
{"type": "server", "timestamp": "2023-02-19T19:30:16,531+01:00", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "eb31b1b69b22", "message": "loaded module [x-pack-aggregate-metric]" }
{"type": "server", "timestamp": "2023-02-19T19:30:16,531+01:00", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "eb31b1b69b22", "message": "loaded module [x-pack-analytics]" }
{"type": "server", "timestamp": "2023-02-19T19:30:16,531+01:00", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "eb31b1b69b22", "message": "loaded module [x-pack-async]" }
{"type": "server", "timestamp": "2023-02-19T19:30:16,532+01:00", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "eb31b1b69b22", "message": "loaded module [x-pack-async-search]" }
{"type": "server", "timestamp": "2023-02-19T19:30:16,532+01:00", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "eb31b1b69b22", "message": "loaded module [x-pack-autoscaling]" }
{"type": "server", "timestamp": "2023-02-19T19:30:16,532+01:00", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "eb31b1b69b22", "message": "loaded module [x-pack-ccr]" }
{"type": "server", "timestamp": "2023-02-19T19:30:16,532+01:00", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "eb31b1b69b22", "message": "loaded module [x-pack-core]" }
{"type": "server", "timestamp": "2023-02-19T19:30:16,533+01:00", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "eb31b1b69b22", "message": "loaded module [x-pack-data-streams]" }
{"type": "server", "timestamp": "2023-02-19T19:30:16,533+01:00", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "eb31b1b69b22", "message": "loaded module [x-pack-deprecation]" }
{"type": "server", "timestamp": "2023-02-19T19:30:16,533+01:00", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "eb31b1b69b22", "message": "loaded module [x-pack-enrich]" }
{"type": "server", "timestamp": "2023-02-19T19:30:16,533+01:00", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "eb31b1b69b22", "message": "loaded module [x-pack-eql]" }
{"type": "server", "timestamp": "2023-02-19T19:30:16,534+01:00", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "eb31b1b69b22", "message": "loaded module [x-pack-fleet]" }
{"type": "server", "timestamp": "2023-02-19T19:30:16,534+01:00", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "eb31b1b69b22", "message": "loaded module [x-pack-graph]" }
{"type": "server", "timestamp": "2023-02-19T19:30:16,534+01:00", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "eb31b1b69b22", "message": "loaded module [x-pack-identity-provider]" }
{"type": "server", "timestamp": "2023-02-19T19:30:16,534+01:00", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "eb31b1b69b22", "message": "loaded module [x-pack-ilm]" }
{"type": "server", "timestamp": "2023-02-19T19:30:16,535+01:00", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "eb31b1b69b22", "message": "loaded module [x-pack-logstash]" }
{"type": "server", "timestamp": "2023-02-19T19:30:16,535+01:00", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "eb31b1b69b22", "message": "loaded module [x-pack-ml]" }
{"type": "server", "timestamp": "2023-02-19T19:30:16,535+01:00", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "eb31b1b69b22", "message": "loaded module [x-pack-monitoring]" }
{"type": "server", "timestamp": "2023-02-19T19:30:16,535+01:00", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "eb31b1b69b22", "message": "loaded module [x-pack-ql]" }
{"type": "server", "timestamp": "2023-02-19T19:30:16,536+01:00", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "eb31b1b69b22", "message": "loaded module [x-pack-rollup]" }
{"type": "server", "timestamp": "2023-02-19T19:30:16,536+01:00", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "eb31b1b69b22", "message": "loaded module [x-pack-security]" }
{"type": "server", "timestamp": "2023-02-19T19:30:16,536+01:00", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "eb31b1b69b22", "message": "loaded module [x-pack-shutdown]" }
{"type": "server", "timestamp": "2023-02-19T19:30:16,536+01:00", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "eb31b1b69b22", "message": "loaded module [x-pack-sql]" }
{"type": "server", "timestamp": "2023-02-19T19:30:16,536+01:00", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "eb31b1b69b22", "message": "loaded module [x-pack-stack]" }
{"type": "server", "timestamp": "2023-02-19T19:30:16,537+01:00", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "eb31b1b69b22", "message": "loaded module [x-pack-text-structure]" }
{"type": "server", "timestamp": "2023-02-19T19:30:16,537+01:00", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "eb31b1b69b22", "message": "loaded module [x-pack-voting-only-node]" }
{"type": "server", "timestamp": "2023-02-19T19:30:16,537+01:00", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "eb31b1b69b22", "message": "loaded module [x-pack-watcher]" }
{"type": "server", "timestamp": "2023-02-19T19:30:16,538+01:00", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "eb31b1b69b22", "message": "loaded plugin [ingest-attachment]" }
{"type": "server", "timestamp": "2023-02-19T19:30:16,594+01:00", "level": "INFO", "component": "o.e.e.NodeEnvironment", "cluster.name": "docker-cluster", "node.name": "eb31b1b69b22", "message": "using [1] data paths, mounts [[/usr/share/elasticsearch/data (/dev/mapper/ubuntu--vg-ubuntu--lv)]], net usable_space [78gb], net total_space [97.8gb], types [ext4]" }
{"type": "server", "timestamp": "2023-02-19T19:30:16,595+01:00", "level": "INFO", "component": "o.e.e.NodeEnvironment", "cluster.name": "docker-cluster", "node.name": "eb31b1b69b22", "message": "heap size [1gb], compressed ordinary object pointers [true]" }
{"type": "server", "timestamp": "2023-02-19T19:30:16,623+01:00", "level": "INFO", "component": "o.e.n.Node", "cluster.name": "docker-cluster", "node.name": "eb31b1b69b22", "message": "node name [eb31b1b69b22], node ID [ZsGIcJ67R1S0YXwDTvk9cw], cluster name [docker-cluster], roles [transform, data_frozen, master, remote_cluster_client, data, ml, data_content, data_hot, data_warm, data_cold, ingest]" }
{"type": "server", "timestamp": "2023-02-19T19:30:34,430+01:00", "level": "ERROR", "component": "o.e.b.ElasticsearchUncaughtExceptionHandler", "cluster.name": "docker-cluster", "node.name": "eb31b1b69b22", "message": "uncaught exception in thread [main]",
"stacktrace": ["org.elasticsearch.bootstrap.StartupException: ElasticsearchException[Failure running machine learning native code. This could be due to running on an unsupported OS or distribution, missing OS libraries, or a problem with the temp directory. To bypass this problem by running Elasticsearch without machine learning functionality set [xpack.ml.enabled: false].]",
"at org.elasticsearch.bootstrap.Elasticsearch.init(Elasticsearch.java:173) ~[elasticsearch-7.17.9.jar:7.17.9]",
"at org.elasticsearch.bootstrap.Elasticsearch.execute(Elasticsearch.java:160) ~[elasticsearch-7.17.9.jar:7.17.9]",
"at org.elasticsearch.cli.EnvironmentAwareCommand.execute(EnvironmentAwareCommand.java:77) ~[elasticsearch-7.17.9.jar:7.17.9]",
"at org.elasticsearch.cli.Command.mainWithoutErrorHandling(Command.java:112) ~[elasticsearch-cli-7.17.9.jar:7.17.9]",
"at org.elasticsearch.cli.Command.main(Command.java:77) ~[elasticsearch-cli-7.17.9.jar:7.17.9]",
"at org.elasticsearch.bootstrap.Elasticsearch.main(Elasticsearch.java:125) ~[elasticsearch-7.17.9.jar:7.17.9]",
"at org.elasticsearch.bootstrap.Elasticsearch.main(Elasticsearch.java:80) ~[elasticsearch-7.17.9.jar:7.17.9]",
"Caused by: org.elasticsearch.ElasticsearchException: Failure running machine learning native code. This could be due to running on an unsupported OS or distribution, missing OS libraries, or a problem with the temp directory. To bypass this problem by running Elasticsearch without machine learning functionality set [xpack.ml.enabled: false].",
"at org.elasticsearch.xpack.ml.MachineLearning.createComponents(MachineLearning.java:844) ~[?:?]",
"at org.elasticsearch.node.Node.lambda$new$17(Node.java:731) ~[elasticsearch-7.17.9.jar:7.17.9]",
"at java.util.stream.ReferencePipeline$7$1.accept(ReferencePipeline.java:273) ~[?:?]",
"at java.util.ArrayList$ArrayListSpliterator.forEachRemaining(ArrayList.java:1625) ~[?:?]",
"at java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:509) ~[?:?]",
"at java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:499) ~[?:?]",
"at java.util.stream.ReduceOps$ReduceOp.evaluateSequential(ReduceOps.java:921) ~[?:?]",
"at java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:234) ~[?:?]",
"at java.util.stream.ReferencePipeline.collect(ReferencePipeline.java:682) ~[?:?]",
"at org.elasticsearch.node.Node.<init>(Node.java:745) ~[elasticsearch-7.17.9.jar:7.17.9]",
"at org.elasticsearch.node.Node.<init>(Node.java:309) ~[elasticsearch-7.17.9.jar:7.17.9]",
"at org.elasticsearch.bootstrap.Bootstrap$5.<init>(Bootstrap.java:234) ~[elasticsearch-7.17.9.jar:7.17.9]",
"at org.elasticsearch.bootstrap.Bootstrap.setup(Bootstrap.java:234) ~[elasticsearch-7.17.9.jar:7.17.9]",
"at org.elasticsearch.bootstrap.Bootstrap.init(Bootstrap.java:434) ~[elasticsearch-7.17.9.jar:7.17.9]",
"at org.elasticsearch.bootstrap.Elasticsearch.init(Elasticsearch.java:169) ~[elasticsearch-7.17.9.jar:7.17.9]",
"... 6 more"] }
	at java.base/java.util.stream.ReferencePipeline$7$1.accept(ReferencePipeline.java:273)
	at java.base/java.util.ArrayList$ArrayListSpliterator.forEachRemaining(ArrayList.java:1625)
	at java.base/java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:509)
	at java.base/java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:499)
	at java.base/java.util.stream.ReduceOps$ReduceOp.evaluateSequential(ReduceOps.java:921)
	at java.base/java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:234)
	at java.base/java.util.stream.ReferencePipeline.collect(ReferencePipeline.java:682)
For complete error details, refer to the log at /usr/share/elasticsearch/logs/docker-cluster.log
si_signo 4, si_code: 2, si_errno: 0, address: 0x7f2e1bf71308, library: /usr/share/elasticsearch/modules/x-pack-ml/platform/linux-x86_64/bin/../lib/libMlCore.so, base: 0x7f2e1be4d000, normalized address: 0x124308
When the Fulltextsearch addons is not activated, all containers start and everything seem to work.
How can I fix this bug?
Hi, I’ve found this:
Which cpu do you have?
I have an AMD Phenom™ II X4 810 Processor. It supports SSE4a but I am unsure about SSE4.2.
Yeah, that is likely the reason then. Can you try to disable fts for now again and check if that makes things work again?
Yeah, it still does. Thank you for you support !
