Hello
i have installed on my NC14.03 elasticsearch and the 3 search apps. When I create the first index on the command line this works without error messages.
Unfortunately I only see “No results” in the Nextcloud when i perfomed a search.
I have already uninstalled the 3 apps, deleted tables and reinstalled. Unfortunately, no change.
The files are all in PDF format. I have also installed the AddOn for Elasticsearch.
What else can I do?
Test Elasticsearch:
~$ curl -XGET 'localhost:9200/?pretty'
"name" : "DRuPAvx",
"cluster_name" : "elasticsearch",
"cluster_uuid" : "8wMByPh2QTO37bgeWbwYbw",
"version" : {
"number" : "6.4.2",
"build_flavor" : "default",
"build_type" : "deb",
"build_hash" : "04711c2",
"build_date" : "2018-09-26T13:34:09.098244Z",
"build_snapshot" : false,
"lucene_version" : "7.4.0",
"minimum_wire_compatibility_version" : "5.6.0",
"minimum_index_compatibility_version" : "5.0.0"
"tagline" : "You Know, for Search"
create Index:
Options: []
Memory: 25 MB
┌─ Indexing ────
│ Action: indexDocument
│ Provider: Files Account: Testuser
│ Document: 296
│ Info: httpd/unix-directory
│ Title: flowupload
│ Content size: 0
│ Progress: all/383
┌─ Results ────
│ Result: 416/416
│ Index: files:296
│ Status: ok
│ Message: {"_index":"myfiles_idx","_type":"standard","_id":"files:296","_version":1,"result":"created","_shards":{"total":2,"successful":1,"failed":0},"_seq_no":81,"_primary_term":1}
┌─ Errors ────
│ Error: 0/0
│ Index:
│ Exception:
│ Message:
## x:first result ## c/v:prec/next result ## b:last result
## f:first error ## h/j:prec/next error ## d:delete error ## l:last error
## q:quit ## p:pause
A fulltextsearch:test:
.Testing your current setup:
Creating mocked content provider. ok
Testing mocked provider: get indexable documents. (2 items) ok
Loading search platform. (Elasticsearch) ok
Testing search platform. ok
Locking process ok
Removing test. ok
Pausing 3 seconds 1 2 3 ok
Initializing index mapping. ok
Indexing generated documents. ok
Retreiving content from a big index (license). (size: 32386) ok
Comparing document with source. ok
Searching basic keywords:
- 'test' (result: 1, expected: ["simple"]) ok
- 'document is a simple test' (result: 2, expected: ["simple","license"]) ok
- '"document is a test"' (result: 0, expected: []) ok
- '"document is a simple test"' (result: 1, expected: ["simple"]) ok
- 'document is a simple -test' (result: 1, expected: ["license"]) ok
- 'document is a simple +test' (result: 1, expected: ["simple"]) ok
- '-document is a simple test' (result: 0, expected: []) ok
Updating documents access. ok
Searching with group access rights:
- 'license' - [] - (result: 0, expected: []) ok
- 'license' - ["group_1"] - (result: 1, expected: ["license"]) ok
- 'license' - ["group_1","group_2"] - (result: 1, expected: ["license"]) ok
- 'license' - ["group_3","group_2"] - (result: 1, expected: ["license"]) ok
- 'license' - ["group_3"] - (result: 0, expected: []) ok
Searching with share rights:
- 'license' - notuser - (result: 0, expected: []) ok
- 'license' - user2 - (result: 1, expected: ["license"]) ok
- 'license' - user3 - (result: 1, expected: ["license"]) ok
Removing test. ok
Unlocking process ok
How long does an Index running for the first time? Can i check if the index running?
Thx.
Hermann
