Hey,
I made a NAS with my FritzBox 7590, Only if I create a file or create a folder in NextCloud then I can't do anything and need to reconnect to the ftp server. It is very annoying and only have it in NextCloud. How can I solve this?
Nextcloud version (eg, 12.0.2): 18.0.3
Operating system and version (eg, Ubuntu 17.04): Directadmin
Apache or nginx version (eg, Apache 2.4.25): Apache
PHP version (eg, 7.1): 7.1
Hey,
I made a NAS with my FritzBox 7590, Only if I create a file or create a folder in NextCloud then I can’t do anything and need to reconnect to the ftp server. It is very annoying and only have it in NextCloud. How can I solve this?
Error PHP stat(): stat failed for ftp://xxx:xxx@(MY IP)/GMP/cmfmdrive/ at /home2/cmfm/domains/drive.cmfm.nl/public_html/apps/files_external/lib/Lib/Storage/StreamWrapper.php#127 2020-04-21T16:21:47+0200
Error PHP stat(): connect() failed: Connection refused at /home2/cmfm/domains/drive.cmfm.nl/public_html/apps/files_external/lib/Lib/Storage/StreamWrapper.php#127 2020-04-21T16:21:47+0200
Error PHP opendir(ftp://...@(MY IP)/GMP/cmfmdrive/muziek): failed to open dir: FTP server reports 550 No files found. at /home2/cmfm/domains/drive.cmfm.nl/public_html/apps/files_external/lib/Lib/Storage/StreamWrapper.php#66 2020-04-21T16:21:42+0200
Error PHP stat(): stat failed for ftp://xxx:xxx@(MY IP)/GMP/cmfmdrive/ at /home2/cmfm/domains/drive.cmfm.nl/public_html/apps/files_external/lib/Lib/Storage/StreamWrapper.php#127 2020-04-21T16:20:58+0200
Error PHP stat(): connect() failed: Connection refused at /home2/cmfm/domains/drive.cmfm.nl/public_html/apps/files_external/lib/Lib/Storage/StreamWrapper.php#127 2020-04-21T16:20:58+0200
Error PHP mkdir(): Unable to connect to ftp://xxx:xxx@(MY IP)/GMP/cmfmdrive/muziek at /home2/cmfm/domains/drive.cmfm.nl/public_html/apps/files_external/lib/Lib/Storage/StreamWrapper.php#40 2020-04-21T16:20:56+0200
Error PHP mkdir(): connect() failed: Connection refused at /home2/cmfm/domains/drive.cmfm.nl/public_html/apps/files_external/lib/Lib/Storage/StreamWrapper.php#40 2020-04-21T16:20:56+0200
Error PHP file_exists(): connect() failed: Connection refused at /home2/cmfm/domains/drive.cmfm.nl/public_html/apps/files_external/lib/Lib/Storage/StreamWrapper.php#74 2020-04-21T16:20:56+0200
Error PHP stat(): stat failed for ftp://xxx:xxx@(MY IP)/GMP/cmfmdrive/ at /home2/cmfm/domains/drive.cmfm.nl/public_html/apps/files_external/lib/Lib/Storage/StreamWrapper.php#127 2020-04-21T16:20:56+0200
Error PHP stat(): connect() failed: Connection refused at /home2/cmfm/domains/drive.cmfm.nl/public_html/apps/files_external/lib/Lib/Storage/StreamWrapper.php#127 2020-04-21T16:20:56+0200
Error PHP mkdir(): Unable to connect to ftp://xxx:xxx@(MY IP)/GMP/cmfmdrive/muziek at /home2/cmfm/domains/drive.cmfm.nl/public_html/apps/files_external/lib/Lib/Storage/StreamWrapper.php#40 2020-04-21T16:20:50+0200
Error PHP mkdir(): connect() failed: Connection refused at /home2/cmfm/domains/drive.cmfm.nl/public_html/apps/files_external/lib/Lib/Storage/StreamWrapper.php#40 2020-04-21T16:20:50+0200
Error PHP file_exists(): connect() failed: Connection refused at /home2/cmfm/domains/drive.cmfm.nl/public_html/apps/files_external/lib/Lib/Storage/StreamWrapper.php#74 2020-04-21T16:20:50+0200
Error PHP stat(): stat failed for ftp://xxx:xxx@(MY IP)/GMP/cmfmdrive/ at /home2/cmfm/domains/drive.cmfm.nl/public_html/apps/files_external/lib/Lib/Storage/StreamWrapper.php#127 2020-04-21T16:20:50+0200
Error PHP stat(): connect() failed: Connection refused at /home2/cmfm/domains/drive.cmfm.nl/public_html/apps/files_external/lib/Lib/Storage/StreamWrapper.php#127 2020-04-21T16:20:50+0200
Error index BadMethodCallException: 2020-04-21T16:20:25+0200
Error PHP fopen(ftp://...@(MY IP)/GMP/cmfmdrive/jeremy_20200420-140011.mp3): failed to open stream: operation failed at /home2/cmfm/domains/drive.cmfm.nl/public_html/apps/files_external/lib/Lib/Storage/FTP.php#113 2020-04-21T16:20:25+0200
Error PHP fopen(): connect() failed: Connection refused at /home2/cmfm/domains/drive.cmfm.nl/public_html/apps/files_external/lib/Lib/Storage/FTP.php#113 2020-04-21T16:20:25+0200
Error PHP stat(): stat failed for ftp://xxx:xxx@(MY IP)/GMP/cmfmdrive/ at /home2/cmfm/domains/drive.cmfm.nl/public_html/apps/files_external/lib/Lib/Storage/StreamWrapper.php#127 2020-04-21T16:20:19+0200
Error PHP stat(): connect() failed: Connection refused at /home2/cmfm/domains/drive.cmfm.nl/public_html/apps/files_external/lib/Lib/Storage/StreamWrapper.php#127 2020-04-21T16:20:19+0200
Error PHP stat(): stat failed for ftp://xxx:xxx@(MY IP)/GMP/cmfmdrive/jeremy_20200420-140011.mp3 at /home2/cmfm/domains/drive.cmfm.nl/public_html/apps/files_external/lib/Lib/Storage/StreamWrapper.php#127 2020-04-21T16:20:18+0200
Error PHP stat(): connect() failed: Connection refused at /home2/cmfm/domains/drive.cmfm.nl/public_html/apps/files_external/lib/Lib/Storage/StreamWrapper.php#127 2020-04-21T16:20:18+0200
Error index BadMethodCallException: 2020-04-21T16:20:07+0200
Error PHP fopen(ftp://...@(MY IP)/GMP/cmfmdrive/jeremy_20200420-140011.mp3): failed to open stream: operation failed at /home2/cmfm/domains/drive.cmfm.nl/public_html/apps/files_external/lib/Lib/Storage/FTP.php#113 2020-04-21T16:20:07+0200
Error PHP fopen(): connect() failed: Connection refused at /home2/cmfm/domains/drive.cmfm.nl/public_html/apps/files_external/lib/Lib/Storage/FTP.php#113 2020-04-21T16:20:07+0200
Error PHP stat(): stat failed for ftp://xxx:xxx@(MY IP)/GMP/cmfmdrive/jeremy_20200420-140011.mp3 at /home2/cmfm/domains/drive.cmfm.nl/public_html/apps/files_external/lib/Lib/Storage/StreamWrapper.php#127 2020-04-21T16:20:07+0200
Error no app in context Symfony\Component\Routing\Exception\RouteNotFoundException: Unable to generate a URL for the named route "photos.page.index" as such route does not exist. 2020-04-16T17:15:50+0200
Error no app in context Symfony\Component\Routing\Exception\RouteNotFoundException: Unable to generate a URL for the named route "calendar.view.index" as such route does not exist. 2020-04-16T17:15:50+0200
Warning no app in context Login failed: stan.m (Remote IP: 83.85.206.169) 2020-04-12T13:12:04+0200
Warning no app in context Login failed: julian.b (Remote IP: 172.69.54.150) 2020-04-12T13:07:28+0200
Warning no app in context Login failed: kevin.c (Remote IP: 213.127.107.44) 2020-04-10T12:19:13+0200
Error PHP stat(): stat failed for ftp://xxx:xxx@(MY IP)/GMP/cmfmdrive/ at /home2/cmfm/domains/drive.cmfm.nl/public_html/apps/files_external/lib/Lib/Storage/StreamWrapper.php#127 2020-04-10T12:03:16+0200
Error PHP stat(): connect() failed: Connection refused at /home2/cmfm/domains/drive.cmfm.nl/public_html/apps/files_external/lib/Lib/Storage/StreamWrapper.php#127 2020-04-10T12:03:16+0200
Error PHP stat(): stat failed for ftp://xxx:xxx@(MY IP)/GMP/cmfmdrive/ at /home2/cmfm/domains/drive.cmfm.nl/public_html/apps/files_external/lib/Lib/Storage/StreamWrapper.php#127 2020-04-10T12:02:42+0200
Error PHP stat(): connect() failed: Connection refused at /home2/cmfm/domains/drive.cmfm.nl/public_html/apps/files_external/lib/Lib/Storage/StreamWrapper.php#127 2020-04-10T12:02:42+0200
Error PHP stat(): stat failed for ftp://xxx:xxx@(MY IP)/GMP/cmfmdrive/ at /home2/cmfm/domains/drive.cmfm.nl/public_html/apps/files_external/lib/Lib/Storage/StreamWrapper.php#127 2020-04-10T12:02:39+0200
Error PHP stat(): connect() failed: Connection refused at /home2/cmfm/domains/drive.cmfm.nl/public_html/apps/files_external/lib/Lib/Storage/StreamWrapper.php#127 2020-04-10T12:02:39+0200
Error PHP file_exists(): connect() failed: Connection refused at /home2/cmfm/domains/drive.cmfm.nl/public_html/apps/files_external/lib/Lib/Storage/StreamWrapper.php#74 2020-04-10T12:02:38+0200
Error PHP stat(): stat failed for ftp://xxx:xxx@(MY IP)/GMP/cmfmdrive/ at /home2/cmfm/domains/drive.cmfm.nl/public_html/apps/files_external/lib/Lib/Storage/StreamWrapper.php#127 2020-04-10T12:02:38+0200
Error PHP stat(): connect() failed: Connection refused at /home2/cmfm/domains/drive.cmfm.nl/public_html/apps/files_external/lib/Lib/Storage/StreamWrapper.php#127 2020-04-10T12:02:38+0200
Error PHP stat(): stat failed for ftp://xxx:xxx@(MY IP)/GMP/cmfmdrive/ at /home2/cmfm/domains/drive.cmfm.nl/public_html/apps/files_external/lib/Lib/Storage/StreamWrapper.php#127 2020-04-10T12:02:30+0200
Error PHP stat(): connect() failed: Connection refused at /home2/cmfm/domains/drive.cmfm.nl/public_html/apps/files_external/lib/Lib/Storage/StreamWrapper.php#127 2020-04-10T12:02:30+0200
Fatal webdav Sabre\DAV\Exception: Could not rename part file to final file 2020-04-10T12:02:29+0200
Error PHP unlink(): Unable to connect to ftp://xxx:xxx@(MY IP)/GMP/cmfmdrive/Sollicitatie Procedure CMFM! (1).docx.ocTransferId1666651718.part at /home2/cmfm/domains/drive.cmfm.nl/public_html/apps/files_external/lib/Lib/Storage/FTP.php#98 2020-04-10T12:02:29+0200
Error PHP unlink(): connect() failed: Connection refused at /home2/cmfm/domains/drive.cmfm.nl/public_html/apps/files_external/lib/Lib/Storage/FTP.php#98 2020-04-10T12:02:29+0200
Error webdav renaming part file to final file failed $renameOkay: false, $fileExists: false) 2020-04-10T12:02:29+0200
Error PHP file_exists(): connect() failed: Connection refused at /home2/cmfm/domains/drive.cmfm.nl/public_html/apps/files_external/lib/Lib/Storage/StreamWrapper.php#74 2020-04-10T12:02:29+0200
Error PHP rename(): connect() failed: Connection refused at /home2/cmfm/domains/drive.cmfm.nl/public_html/apps/files_external/lib/Lib/Storage/StreamWrapper.php#123 2020-04-10T12:02:29+0200
Error PHP stat(): stat failed for ftp://xxx:xxx@(MY IP)/GMP/cmfmdrive/ at /home2/cmfm/domains/drive.cmfm.nl/public_html/apps/files_external/lib/Lib/Storage/StreamWrapper.php#127 2020-04-10T12:00:41+0200
Error PHP stat(): connect() failed: Connection refused at /home2/cmfm/domains/drive.cmfm.nl/public_html/apps/files_external/lib/Lib/Storage/StreamWrapper.php#127 2020-04-10T12:00:41+0200
Error PHP stat(): stat failed for ftp://xxx:xxx@(MY IP)/GMP/cmfmdrive/ at /home2/cmfm/domains/drive.cmfm.nl/public_html/apps/files_external/lib/Lib/Storage/StreamWrapper.php#127 2020-04-10T12:00:38+0200
Error PHP stat(): connect() failed: Connection refused at /home2/cmfm/domains/drive.cmfm.nl/public_html/apps/files_external/lib/Lib/Storage/StreamWrapper.php#127 2020-04-10T12:00:38+0200
Error PHP stat(): stat failed for ftp://xxx:xxx@(MY IP)/GMP/cmfmdrive/ at /home2/cmfm/domains/drive.cmfm.nl/public_html/apps/files_external/lib/Lib/Storage/StreamWrapper.php#127 2020-04-10T12:00:34+0200
Error PHP stat(): connect() failed: Connection refused at /home2/cmfm/domains/drive.cmfm.nl/public_html/apps/files_external/lib/Lib/Storage/StreamWrapper.php#127 2020-04-10T12:00:34+0200
Error PHP stat(): stat failed for ftp://xxx:xxx@(MY IP)/GMP/cmfmdrive/ at /home2/cmfm/domains/drive.cmfm.nl/public_html/apps/files_external/lib/Lib/Storage/StreamWrapper.php#127 2020-04-10T12:00:27+0200
Error PHP stat(): connect() failed: Connection refused at /home2/cmfm/domains/drive.cmfm.nl/public_html/apps/files_external/lib/Lib/Storage/StreamWrapper.php#127 2020-04-10T12:00:27+0200
Fatal onlyoffice Config: 561 File not found 2020-04-10T12:00:22+0200
Error PHP stat(): stat failed for ftp://xxx:xxx@(MY IP)/GMP/cmfmdrive/ at /home2/cmfm/domains/drive.cmfm.nl/public_html/apps/files_external/lib/Lib/Storage/StreamWrapper.php#127 2020-04-10T12:00:17+0200
Error PHP stat(): connect() failed: Connection refused at /home2/cmfm/domains/drive.cmfm.nl/public_html/apps/files_external/lib/Lib/Storage/StreamWrapper.php#127 2020-04-10T12:00:17+0200
Error PHP stat(): stat failed for ftp://xxx:xxx@(MY IP)/GMP/cmfmdrive/ at /home2/cmfm/domains/drive.cmfm.nl/public_html/apps/files_external/lib/Lib/Storage/StreamWrapper.php#127 2020-04-10T12:00:16+0200
Error PHP stat(): connect() failed: Connection refused at /home2/cmfm/domains/drive.cmfm.nl/public_html/apps/files_external/lib/Lib/Storage/StreamWrapper.php#127 2020-04-10T12:00:16+0200
'instanceid' => '(SECRET)',
'passwordsalt' => '(SECRET)',
'secret' => '(SECRET)',
0 => 'drive.cmfm.nl',
'datadirectory' => '/home2/cmfm/domains/drive.cmfm.nl/public_html/data',
'version' => '18.0.3.0',
'overwrite.cli.url' => 'https://drive.cmfm.nl',
'dbname' => 'cmfm_drive',
'dbhost' => 'localhost:3306',
'dbuser' => 'cmfm_drive',
'dbpassword' => '(SECRET)',
'app_install_overwrite' =>
0 => 'files_external_gdrive',
1 => 'files_external_dropbox',
2 => 'files_clipboard',
3 => 'files_external_onedrive',
have i not.
