I am running Nextcloud AIO in docker. The problem is web frontend works very slow. It takes about a 1-2 min to load a page. Sometimes it starts to work normal, but it lasts for a few minutes.
docker-compose
version: "3.8"
volumes:
services:
nextcloud:
restart: always
volumes:
ports:
- 3388:8080
- PUID=1000
- PGID=1000
# - AIO_DISABLE_BACKUP_SECTION=false # Setting this to true allows to hide the backup section in the AIO interface.
# - APACHE_PORT=11000 # Is needed when running behind a web server or reverse proxy (like Apache, Nginx and else). See https://github.com/nextcloud/all-in-one/blob/main/reverse-proxy.md
# - APACHE_IP_BINDING=127.0.0.1 # Should be set when running behind a web server or reverse proxy (like Apache, Nginx and else) that is running on the same host. See https://github.com/nextcloud/all-in-one/blob/main/reverse-proxy.md
- NEXTCLOUD_DATADIR=/mnt/cloud/nextcloud-aio/data/
- NEXTCLOUD_MOUNT=/mnt/
- NEXTCLOUD_UPLOAD_LIMIT=50G
- NEXTCLOUD_TRUSTED_DOMAINS=******* 192.168.31.127
- OVERWRITEHOST=*******
- OVERWRITEPROTOCOL=https
- TRUSTED_PROXIES=192.168.31.127
nginx conf
map $http_upgrade $connection_upgrade {
default upgrade;
'' close;
server {
listen 80;
if ($scheme = "http") {
listen 443 ssl http2;
# listen [::]:443 ssl http2; # comment to disable IPv6
server_name *********;
location / {
proxy_pass http://127.0.0.1:11000$request_uri;
proxy_set_header X-Forwarded-Port $server_port;
proxy_set_header X-Forwarded-Scheme $scheme;
proxy_set_header Accept-Encoding "";
proxy_set_header Host $host;
client_body_buffer_size 512k;
proxy_read_timeout 86400s;
client_max_body_size 0;
# Websocket
proxy_http_version 1.1;
proxy_set_header Connection $connection_upgrade;
ssl_certificate /etc/letsencrypt/live/**********/fullchain.pem; # managed by certbot on host machine
ssl_certificate_key /etc/letsencrypt/live/**********/privkey.pem; # managed by certbot on host machine
ssl_session_timeout 1d;
ssl_session_cache shared:MozSSL:10m; # about 40000 sessions
ssl_session_tickets off;
ssl_protocols TLSv1.2 TLSv1.3;
ssl_ciphers ECDHE-ECDSA-**********;
ssl_prefer_server_ciphers off;
Nextcloud version : 26.0.3
Operating system and version: Debian 11
Nginx version: nginx 1.18.0
