Nextcloud version: 18.0.2
Operating system and version: Ubuntu 18.04 LTS
Apache or nginx version: Apache/2.4.29
PHP version: 7.4
The issue you are facing: Pretty much nothing works except uploading files, moving them around, deleting and downloading them. Any action from the notification panel returns “Failed to perform action”, no setting is getting saved, i can’t log out etc. The log is so full of errors and warnings that the Chrome webpage locks up. The installation went well and without any errors or hiccups whatsoever.
Is this the first time you’ve seen this error?: Yes
- Install the latest version on Ubuntu 18.04
- See behaviour
https://i.imgur.com/i2NIXAL.png
'instanceid' => 'XXXXXXX',
'passwordsalt' => 'XXXXXXXXXXX',
'secret' => 'XXXXXXXXXX',
0 => 'XXXXXXXXXX',
'datadirectory' => '/storage/files/',
'version' => '18.0.2.2',
'overwrite.cli.url' => 'XXXXXXXXXXX',
'dbname' => 'XXXXXXXX',
'dbhost' => 'XXXXXXXXX',
'dbuser' => 'XXXXXXXXXXX',
'dbpassword' => 'XXXXXXXXXX',
'overwrite.cli.url' => 'XXXXXXXX',
[Tue Mar 17 13:37:03.291905 2020] [core:notice] [pid 31829] AH00094: Command line: '/usr/sbin/apache2'
[Tue Mar 17 13:37:06.204804 2020] [autoindex:error] [pid 31835] [client 162.158.18.124:33380] AH01276: Cannot serve directory /var/www/files/apps/files/: No matching DirectoryIndex (index.php,index.html) found, and server-generated directory index forbidden by Options directive
I cannot find anything useful online regarding the errors or a way to fix them, so any help would be appreciated.
