example
longer
example
here
Nextcloud version (eg, 18.0.6): 18.0.6
Operating system and version (eg, Ubuntu 20.04):nc18-nextcloud-hub
PHP version (eg, 7.1):
The issue you are facing:upload file size limit
Is this the first time you’ve seen this error? (Y/N)
- attempt to load files larger than 2.8GB
PASTE HERE
'apps_paths' =>
0 =>
'path' => '/usr/local/www/nextcloud/apps',
'url' => '/apps',
'writable' => true,
1 =>
'path' => '/usr/local/www/nextcloud/apps-pkg',
'url' => '/apps-pkg',
'writable' => true,
'passwordsalt' => 'GO38xBLKqk50TYDgo3OD7Z4y75BVo3',
'secret' => 'm4GsX96yasVKYY5DJFyMs/pIefx+YPCKLbfYI5BxF0DebUl0',
0 => 'localhost',
1 => 'private',
2 => 'private',
3 => 'private',
4 => 'private',
'datadirectory' => '/usr/local/www/nextcloud/data',
'version' => '18.0.6.0',
'overwrite.cli.url' => 'http://localhost',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => 'oc_ncadmin',
'dbpassword' => 'private',
'instanceid' => 'private',
'mail_from_address' => 'Nxtcloud',
'mail_smtpmode' => 'smtp',
'mail_domain' => 'private',
'mail_smtpauthtype' => 'PLAIN',
'mail_smtpauth' => 1,
'mail_smtphost' => 'mail.private.net',
'mail_smtpport' => 'private',
'mail_smtpname' => 'private',
'mail_smtppassword' => 'private',
'updater.secret' => 'private',
'theme' => '',
'loglevel' => 2,
nothing found without too much personal data
PASTE HERE
