I am running Nextcloud on FreeBSD 14.4 with the Documentserver running in an Virtual Machine (also FreeBSD 14.4). The ONLYOFFICE connector in the Nextcloud Admin Account seems to connect to the Documentserver but I still cannot open any documents in the user accounts. I have not yet figured out how the nextcloud communicates with the documentserver but the docserver firewall is open as the docserver is internal.Are there anyone that have got Onlyoffice to work with an external server in Nextcloud? There are no error logs to help me anywhere. Thanks for any help!Open ports on the docserver: #sockstat -4
USER COMMAND PID FD PROTO LOCAL ADDRESS FOREIGN ADDRESS
onlyoffice metrics 2014 16 tcp46 *:8126 :
onlyoffice metrics 2014 17 udp4 *:8125 :
onlyoffice docservice 2013 14 tcp46 *:8000 :
root sshd-sessi 961 7 tcp4 192.168.25.248:22 192.168.25.245:34835
root sshd 939 7 tcp4 *:22 :
stunnel stunnel 864 8 tcp4 *:443 :
nobody nginx 859 8 tcp4 *:80 :
root nginx 857 8 tcp4 *:80 *:
33.0.5 - Operating system and version (e.g., Ubuntu 24.04):
FreeBSD 14.4-p7 (nextcloud and docserver) - Web server and version (e.g, Apache 2.4.25):
Apache 2.4.68 (nextcloud), Nginx 1.30.3 (docserver) - Reverse proxy and version _(e.g. nginx 1.27.2)
Nginx1.30.3 - PHP version (e.g, 8.3):
8.3.31 - Is this the first time you’ve seen this error? (Yes / No):
I still haven't got it to work. - When did this problem seem to first start?
I still haven't got it to work. - Installation method (e.g. AlO, NCP, Bare Metal/Archive, etc.)
Various - Are you using CloudfIare, mod_security, or similar? (Yes / No)
No
I cannot open any documents in nextcloud even though the connection is present in the nextcloud admin / onlyoffice configuration.
Installed ONLYOFFICE Documentsserver from FreeBSD ports (compile from source). Installed, activated and configured ONLYOFFICE App in the admin page.
Try to open a document as a local user.
Nextcloud shows a “simulated” document without any contents (Firefox) or an blue screen with text “ONLYOFFICE cannot be reached, contact system admin” (Edge).
No error logs shown in nextcloud admin logs
I have tried Firefox (prefered browser) and Edge.
No error logs shown in nginx logs (docserver)
"apps_paths": [
"path": "\/home\/httpd\/htdocs\/nextcloud\/apps",
"url": "\/apps",
"writable": true
"path": "\/home\/httpd\/htdocs\/nextcloud\/apps-pkg",
"url": "\/apps-pkg",
"writable": false
"loglevel": 3,
"logfile": "\/ram\/nextcloud\/log\/nextcloud.log",
"cache_path": "\/ram\/nextcloud\/cache\/",
"session_lifetime": 3600,
"session_keepalive": false,
"minimum.supported.desktop.version": "2.3.0",
"localhost:8386"
"dbtype": "mysql",
"version": "33.0.5.1",
"overwrite.cli.url": "https:\/\/timewind.se\/nextcloud",
"overwritehost": "timewind.se",
"overwriteprotocol": "https",
"dbport": "",
"filelocking.enabled": true,
"redis": {
"port": 0,
"timeout": 0
"default_phone_region": "SE",
"theme": "",
"lost_password_link": "disabled",
"auth.webauthn.enabled": false,
"ldapIgnoreNamingRules": false,
"mail_smtpsecure": "",
"mail_smtpmode": "sendmail",
"mail_smtpport": "25",
"mail_smtpauth": false,
"app.mail.verify-tls-peer": false,
"app.mail.imap.timeout": "60",
"app.mail.smtp.timeout": "10",
"app_install_overwrite": [
"groupfolders",
"apporder",
"impersonate",
"passwords",
"hsts",
"bookmarks",
"files_rightclick"
"allowNightlyUpdates": [],
"mysql.utf8mb4": true
audioplayer: 3.9.0
bookmarks: 16.2.2
bruteforcesettings: 6.0.0
calendar: 6.5.0
cloud_federation_api: 1.17.0
comments: 1.23.0
contacts: 8.7.3
contactsinteraction: 1.14.1
dav: 1.36.0
federatedfilesharing: 1.23.0
files: 2.5.0
files_downloadlimit: 5.1.0
files_external: 1.25.1
files_pdfviewer: 6.0.0
files_sharing: 1.25.2
files_trashbin: 1.23.0
files_versions: 1.26.0
logreader: 6.0.0
lookup_server_connector: 1.21.0
mail: 5.10.7
oauth2: 1.21.0
onlyoffice: 10.1.2
password_policy: 5.0.0
passwords: 2026.6.10
privacy: 5.0.0
profile: 1.2.0
provisioning_api: 1.23.0
recommendations: 6.0.0
related_resources: 4.0.0
serverinfo: 5.0.0
settings: 1.16.0
systemtags: 1.23.0
text: 7.0.1
theming: 2.8.0
twofactor_backupcodes: 1.22.0
twofactor_totp: 15.0.0
user_ldap: 1.24.0
user_status: 1.13.0
viewer: 6.0.0
webhook_listeners: 1.5.0
workflowengine: 2.15.0
activity: 6.0.0 (installed 2.8.2)
admin_audit: 1.23.0
app_api: 33.0.0 (installed 32.0.0)
circles: 33.0.0 (installed 22.2.0)
dashboard: 7.13.0 (installed 7.0.0)
encryption: 2.21.0
federation: 1.23.0 (installed 1.5.0)
files_reminders: 1.6.0 (installed 1.6.0)
firstrunwizard: 6.0.0 (installed 2.4.0)
nextcloud_announcements: 5.0.0 (installed 1.15.0)
notifications: 6.0.0 (installed 2.14.0)
photos: 6.0.0 (installed 1.0.0)
sharebymail: 1.23.0 (installed 1.5.0)
support: 5.0.0 (installed 1.0.0)
survey_client: 5.0.0 (installed 1.3.0)
suspicious_login: 11.0.0
twofactor_nextcloud_notification: 7.0.0
updatenotification: 1.23.0 (installed 1.6.0)
weather_status: 1.13.0 (installed 1.6.0)
