The fourth beta of Nextcloud 34 is now available on download servers! ![]()
If you notice anything out of order, please report back on the appropriate GitHub repository! ![]()
We will follow up with frequent betas over the next weeks.
Downloads
Changelog
Nextcloud 34.0.0 beta 4
server
- Refactor(appstore): migrate to Typescript and Vue 3 (server#57290)
- Add ‘user_migration’ to relevant quick presets (server#58754)
- Fix(public.scss): increase footer width (server#59452)
- Fix(previews): fix chunking for querybuilder (server#59477)
- Feat(user_ldap): Add option to check all seen users (server#59671)
- Fix since checker (server#59940)
- Chore: Increase page load timeout for oracle setup tests (server#60023)
- Fix(comments): Add an action to comment notification that dismisses it (server#60150)
- Fix(settings): Fix admin delegation for hidden sections (server#60160)
- [local] feat(files): support .HIF file (server#60161)
- Fix(core): prompt for password once when installing recommended apps (server#60165)
- Chore(deps): Bump axios from 1.15.0 to 1.16.0 (server#60166)
- Feat(TaskProcessing): add TextToTextReformatParagraphs task type (server#60171)
- Feat(core): app menu waffle launcher (server#60180)
- Build: Remove testing app during packaging (server#60181)
- Docs(config): clarify overwrite.cli.url description (server#60185)
- Test(cypress): defer ResizeObserver callbacks to next frame (server#60189)
- Build: ship files_lock with 34 (server#60192)
- Fix: correct typo ‘occured’ to ‘occurred’ in SetupCheckManager (server#60202)
- Chore(AppStore): Add translations to REUSE.toml for app store (server#60205)
- Ci: Add deprecated getEvent to psalm baseline (server#60217)
- Chore(deps): Update @nextcloud/vue legacy bundle to 8.39.0 (server#60227)
activity
- Fix(notifications): mark activity notifications as read when viewing … (activity#2532)
- [master] Update nextcloud/ocp dependency (activity#2536)
- [master] Fix npm audit (activity#2539)
- Chore(deps-dev): bump the dev group with 4 updates (activity#2543)
- Chore(deps-dev): bump dockerode from 4.0.10 to 5.0.0 (activity#2544)
- Docs: explain the optional dedicated activity database (activity#2550)
- Fix(cypress): ensure activity app is enabled and fix file list row se… (activity#2554)
- Chore(deps): bump the prod group across 1 directory with 4 updates (activity#2555)
- Chore(deps): bump axios from 1.15.0 to 1.16.0 (activity#2556)
- Ci(deps): bump the github-actions group across 1 directory with 2 updates (activity#2557)
- Chore(ci): include full audit report and environment info in npm audit PRs (activity#2558)
- Test(cypress): improve e2e test stability (activity#2559)
- Refactor: flatten nesting with early returns in FilesHooks and ViewInfoCache (activity#2565)
- Refactor: clarify fileCreate() condition by making the specific case explicit (activity#2568)
- Refactor: replace magic batch-time seconds with named constants (activity#2569)
notifications
- [master] Update nextcloud/ocp dependency (notifications#2988)
- [master] Update nextcloud/ocp dependency (notifications#2990)
password_policy
- Chore(deps): Bump axios from 1.15.0 to 1.16.0 (password_policy#935)
- Chore(deps): Bump postcss from 8.5.6 to 8.5.14 (password_policy#936)
photos
- Fix: Adjust to API change of “getDavPermissions” in Nextcloud 34 (photos#3475)
- Fix downloading files from public share (photos#3476)
- Chore: Update workflows (photos#3502)
recommendations
- [master] Fix npm audit (recommendations#1012)
- Perf(recommendations): avoid scanning all commented files (recommendations#1019)
- Perf(recommendations): reduce memory usage when ranking shared files (recommendations#1020)
- Refactor(recommendations): simplify recommendation deduplication (recommendations#1021)
serverinfo
survey_client
text
- Build: update .nextcloudignore to current state (text#8531)
- Chore(performance): use async components properly (text#8534)
- Chore(deps): bump axios from 1.15.0 to 1.16.0 (text#8537)
twofactor_nextcloud_notification
- Fix: Add NoTwoFactorRequired attribute to poll method (twofactor_nextcloud_notification#1151)
- [main] Fix npm audit (twofactor_nextcloud_notification#1312)
- Ci(rector): Add rector (twofactor_nextcloud_notification#1313)
